Everything posted by gav_is_con
Thermostat help
It’s definitely the one in @Gremlin170post. I followed instructions on here to change mine a few years back. Find my old post, plus plenty of others some very good guides on here.
Abused pork
I like absorbs puke 🤮
Dashboard repair mk3 octavia
Wow amazing repair
Who has owned their Octy for the longest?
I forget I also had to have a couple of rear calipers replaced, about 2 years ago now. It’s had several cambelt changes
I thought this was a different thread, given all the responses , time for me to chip in proudly. Owned a 55 Plate 1.9 Elegance hatch, since May 2008, about 3.5 years old. Purchased with about 29k on it from a Main dealer. Now sitting with just over 250k on the clock, SORN on the drive. The Superb needs more use than this to keep going. Had one new SMF clutch. Original turbo. 2 sets of glow plugs. 1 set of rear shocks. One replacement front spring due to a breakage. One front rad. Cupra console bushes upgrade. Nothing more I think other than 10k oil and filter changes and other filters to suit time and distance.
Problems with car once it’s warmed up
Even if it’s the mechatronics unit of the best box this can be repaired a lot cheaper than 1k. You need to find a DSG specialist.
Strange osf wheel wobble and brakes jamming on
If you have particularly badly lipped disks and meaty pads they could be sticking badly on the disk lip. I had an issue with mine, once disks and pads changed issue went away. I never had vibration, just a smokey front wheel it stuck on quite bad even after a clean and grease.
You could always try cleaning the caliper pad guides and especially guide pins. Doing back up and see how it goes?
MFD gremlins
Flat or dying battery can cause gremlins
- Low mileage Coolant Leak
Rear suspension essentric washer and bolt help!
When my Octy was done many years ago the mechanic took the whole arm off and pressed the bush out in a press to change the seized bushes and essentric nut and bolt.
Time to change
The 2lt turbo was known to be a little weak on the mk2 from what I have read on here 1.9 a little lesser known. The outlay on a new car and depreciation could be just as big a cost as say a turbo or clutch/DMF. The road tax is a factor I suppose but the savings aren’t massive. Our 1.2 105 TSI Leon is a good replacement for a 1.9TDI I love the turbo charged pull, still I love the PD shove against my Superb 2 170 CR. Please drive a CR engine see if you like it.
Replacement boot gas struts for Superb mk 2 combi
There is a company called SGS engineering people go on about when replacing electric ones for gas.
Time to change
If the Octy has been mostly trouble free hang on to it. They go on for miles as I am sure you know. As you say when looking you come back to Octavia again. Otherwise consider a petrol to avoid all the diesel related issues. 1.5TSi looks like a decent engine, although that appears to be fairly young cars which may be outside your budget. I personally considered a 2010 100k 1.9tdi as a potential replacement for my 2005 1.9tdi 250k, if it ever came to it.
Superb 2017 or Octavia 2019?
Once you’ve had a superb you can’t go backwards 😜 I am the same as you S2 estate and Octy hatch. The estate comes in handy once in a while
What's it worth? 2005 Estate
I would say around 1k private is where a lot of cars seem to hang around after certain age or miles. You do have the option to stick it here in the classifieds
Vehicle not reaching optimum temperature
Plus one for DSG stat and an easy DIY change. Loads of write ups on this forum too.
1.9 TDI static flywheel on a 2.0tdi?
I don’t believe the 1.9 and 2lt are compatible clutch or flywheel wise. I hope someone will come along and confirm that also.
Fast tick-over (2.0 TDI 150hp)
I performed a test on mine only a local 2 mile journey today. From start it was running at 1k rpm, all the way to the destination. On the way back I turned off the climate and fans. By the time I got home the revs had settled down. After pulling on to the drive I turned the climate inc AC back on and the revs rose back up to 1k again. Turning off within 30 seconds made no diffence. I turned the engine off after a minute of high idle. So for me on a S2 170 TDI DSG 2011, non stop start. This is the behaviour
Octy 2 VRS seats - is there a market for them?
Don’t know until you try. If you are freedom list them here for free first?
Not sure if it’s linked is the air con on? Try turning it and the fan controls to off.
Which bulb type and how?
Could they be bendy beam Xenon bulbs ?
How many? Does anyone know???
Isn’t there a website that shows how many cars are left on the road or sorn? Just googled it www.howmanyleft.co.uk Not sure if it will give you precisely what you want.
Driving mannerisms recommendations for a 1.9tdi bxe
My own view plus what I have read in here. Keep below 2k rpm until warm. Meaning engine temp. Although as soon as I get on the motorway within 1 mile it’s over that in 5th. I believe its a warning not to thrash engine when cold. Let the engine idle after a long drive for a minute before turning off. This could be turbo advice in some cases. Give it some beans now and again when up to temperature. Keep the internals clean. I don’t mean the red line. These engines certainly don’t rev easy past a certain point. I don’t think low local miles does these cars any favours, but then again not heard any bad news either. Diesels are well suited on long drives for economy and longevity. Regular 10k or annual oil changes help. Coming from over 20 years of turbo diesels, I find the lack of grunt in modern petrols disappointing and even more so the CR diesels In VAG. I just got used to the torque at low revs and anything over I felt like I was a boy racer. We have a 1.2TSI in the family and it’s quite close MPG wise to a TDI and the added turbo means on paper it delivers the same BHP but differently, feels sprightly all the same. Diesel tax means these old trusty 1.9 cars may not be around for long, I still have a soft spot for them. Rant over.
Replacing elegance headunit with a newer OEM headunit
Skoda wise Columbus depending on age may need a new additional component(BCM)? to prevent battery drain issues. Not sure if the later models Amusden or Swing are compatible. Some people go Kenwood aftermarket or Android with very mixed reviews. It all depends what you want. Bluetooth, Nav, SD card etc etc?
