ABS/wheel speed sensor and faults
It depends how the ABS software calculates the speed signal it sends to the instruments, most likely it does some kind of majority voting so a single sensor failure won't affect the speedo.
Digital Service Record - How do you access this?
Skoda UK used to say 5 years, but that was out of line with the rest of the VAG empire, so now there's an inspection after 120,000km and replacement after 15 years or 180,000km.
And that's the 4 ABS wheel speed sensors.
the truth about electric cars
The reactors in them are the same design as the ones that Rolls-Royce are trying to get permission to create local nucelar power stations with.
Kangaroo, Start/Stop & Fuel Economy - Am I going mad?
If you have the original battery it will be around 5 years old, and as the car has only averaged less than 5000 miles per year it's quite possible that the battery is not in prime health and able to hold charge as well as it should - this could be a factor in the inconsistent start/stop performance. Might be worth getting a proper battery condition check done, not just a voltage check!
Could be a problem in the wiring, especially I'm thinking a connector as it's gone from intermittent to permananent?
Advice on tyres
So did mine, but they were an option on my 2015 model which the previous owner specified.
Boarding/puddle lamps
As a general rule VAG only fit the wiring for factory fitted options (only exception I know is the satellite radio option in the USA).
New "Smart" TV Advice Sought
I've been using a 43" JVC Fire TV which has built-in Amazon Fire for quite a few years - for me the deciding factor was the 4 HDMI inputs (FreeView, FreeSat, BluRay and Apple TV).
O4 RS 2020 / Columbus / V1941 / Bug with sound
Best to post in the Octavia 4 forum, there is plenty of discussion there about infotainment system issues.
But still suffers from the drawback that it doesn't take you from where you are to where you need to be when you need to be there at an affordable cost. When I lived in South Molton the nearest mainline station was Tiverton Parkway which was a 40 minute drive away with infrequent buses to get there and parking fess so high that even with a Senior Citizen railcard it was cheaper to drive to London for a weekend visit to family. For mass transit to be a realistic option for many people it needs to provide more frequent services at more affordable prices and be part of an integrated travel network of trains and buses. The severe cutting back of HS2 and the lack of willingness to integrate mass transit systems means that it cannot become a viable alternative to personal transport without a total change in mindset in the UK.
Roof Bars / Box
Thule Wing Bars and 900 roof box when I had an estate. Just changed the feet on the roof bars now I have a hatchback.
Short to ground front airbag switch.
You can get the full factory repair information, including wiring diagrams, for a 24 hour subscription to the Skoda erwin website https://erwin.skoda-auto.cz/erwin/showHome.do Download everything you're offered as pdf files.
The UK Government Transport Minister said in an interview this morning that they will support ALL Councils in England wanting to implement LTNs (Low Traffic Neighbourhoods) and 20mph zones - not necessarily promising funding though. So it's not a Bristol specific or ICE specific policy.
Where´s my battery?
As previously said that is only the software of the infotainment system - it says nothing about the software level in the other 30+ modules in the car! Stating the infotainment software level as though it applies to the whole car is such a common misunderstanding, and one that's been commented on here more times than I can remember.
Where´s my battery?
Those are updates to only the infotainment system of the car, so I very much doubt they will solve this problem. There have been several posts/threads in this forum about this 12V battery problem on PHEV versions, so your best plan is to search/surf this forum to find those posts and ask the owners what fixed it for them. Then armed with that information go back to your dealer and tell them what they should know (but either don't or can't be bothered) about what needs updating.
Where´s my battery?
Very true, but given the number of owners having problems with the 12V batteries dying on VAG PHEVs we have to assume that the early versions of the hardware & software do NOT have well written software! Why are you so reticent to tackle the root cause (modules not turning off) and so insistent on only tackling the symptom (a knackered 12V battery)? When fault finding the only sensible method is to identify, and then solve, the root cause. Repeatedly tacking symptoms is just expensive, frustrating and ultimately pointless.
OCU - Update
- Where´s my battery?
I think your priority should be to get the cause of the battery draining solved, then you wouldn't need to know where the 12V battery is as you wouldn't need to keep replacing another damaged battery!- I need your inputs - TSI buyer's guide - Help me choose
When I had to "give" it to my ex (as part of the divorce settlement) it had done approx 45,000 miles with no unplanned maintenance (just annual servicing) and only 1 warranty job when the front inner left parking sensor failed. It never failed to get us from A-to-B without drama. It was a 6 speed manual estate and averaged around 45mpg mainly rural and motorway driving, which was far better than my previous Audi RS4 (4.2V8, 420PS, 6 speed manual). According to the online MOT check it's now done just under 72,000 miles and the only MOT failure has been when a new owner hasn't checked the tyre condition. I enjoyed driving it so much that's why at the first opportunity I traded my Toyota Aygo for another Octavia, I would have liked another estate but this 1.8 L&K hatchback tempted me too much!- Where´s my battery?
I think you've just confirmed that your car has a parasitic drain problem, which Skoda need to solve under warranty.- MK3.5 vRS washer fluid leak from right (driver's) side of front bumper
Then I suspect the leak is related to the connection to the right side headlamp washer, you may be able to access it by removing the wheelarch liner (someone may be able to confirm or deny that suggestion).- Erwin has some answers. Copyright though.
You have not posted enough times to earn the privilege of being able to edit your posts yet.- Help!! My Vrs is going through oil too fast.
Yellow "Check Oil Level" is a notification to top up the oil as soon as possible. Red "Low Oil Pressure" is a warning not to be ignored, stop as soon as safe and turn the engine off.- Alarm fault
Added clarification for you! That to me suggests either the interior motion sensor or the tilt sensor is triggering the alarm. - Where´s my battery?
