Mileage computer resets
Have the garage done a load test on the battery? - eliminate the simple before searching for the complex (and expensive).
Ajuda Skoda
... and remind you to post in English.
Lack of spoilers
Unfortunately post-Brexit Kopacek won't ship large item (anything bigger than Accepted by Royal Mail) so I have doubts they will accept an order for a spoiler from @Skodatavia who is based in Co. Down.
When Adaptive Cruise Control slows to avoid approaching a car in front, do the brake lights turn on?
It would perform like the place name used by Dylan Thomas , Llareggub (read that place name backwards).
Interior console Lights colour change possible Octavia 2016?
Probably not - single colour LEDS only have 2 wires but RGB (multicolour) LEDs usually have four wires (common, R, G & B ) so it seems unlikely that VAG would include extra driver circuitry that will never be used in most vehicles. Plus the drive voltages for different colour LEDs are not the same (due to the different bandgap to produce the different colour) so there's an added complication there.
Since ACC relies on the forward facing radar it would need to see through the car to work in reverse...
High Mileage Club
That will be an Octavia II not an Octavia III.
If the open circuit voltage is good but the battery has high internal resistance then the voltage will drop when cranking - that's my thoughts? I'd suggest a load test on the battery as this will either prove or eliminate this as a possible cause.
Low battery voltage caused by an engine restart, suggesting a battery with high internal resistance and in poor health?
Does L&K Show on V5?
I've owned both a 2015 Octavia 3 Elegance and a 2016 Octavia 3 L&K and neither Elegance or L&K appeared on the V5. On the Octavia 3 it's easy to tell at a glance if it's an L&K from the Laurin & Klement badges on the front wings, not sure if that's also true on a Superb?
Amundsen 2 SD card
The eBay adverts says it has AS maps so maybe it's the larger 32GB version not the smaller 16GB version - check with the seller (I bought a Skoda SD card off eBay that was advertised as 32GB but was actually 16GB so returned it to the seller for a refund).
- SKODA OCTIVIA TYRE BURST WHILE RUNNING IN CRUISE CONTROL
The front right tyre bursting is not the fault of the car - it's a problem with the tyre. Was it inflated to the correct pressure (had you checked it or relied on someone else?)? Was there any existing damage to the tyre - not just on the visible outer wall but also the tread and inner wall?
Bleed breaks skoda fabia 2003
@Natalie1982 You posted a .heic format file, you need to convert to .mp3 before posting for most people to be able to see photos (I can see it at the moment because I'm currently on a MacBook which can open .heic files but very few Windows PCs can open them).
Removing number plate adhesive
I've used methylated sprits with success at removing glue residue on car paintwork.
Vehicle charging all over the place
Initially it will continue to charge the new battery like the old one but it will soon learn that the battery SOC changes differently and adapt to the new battery. Coding just starts this learning process immediately.
That voltage varition is 100% normal on an Octavia 3 - it's how the micro-regenerative braking system works. Nothing to worry about in any way.
Intermittent ACC and ABS faults
Parking sensors are turned on/off based on vehicle speed, so if the ABS sensors have a problem the vehicle speed is not reliable and hence the parking sensors report a fault. Multiple ABS sensors reporting an intermittent problem suggests an intermittent connection at a common point, such as the connector on the ABS module possibly due to corrosion, or (worst case) a failing ABS module. Obviously check the connections first!
Buying a new Enyaq
... and can't afford to do the PDI properly in some cases.
the truth about electric cars
It's not just about cost of the charger, it's also about the cost to change from an ICE to a BEV. It seems to me many members on here are in a much better financial position than millions of people in the UK who are struggling to feed themselves or pay their energy bills - so the cost of borrowing to change to a BEV is for them simply not affordable. Just because (it seems to me) many posters in this thread don't have those worries doesn't mean it's right to assume everyone is in that enviable position [/rant]
If you can't afford the upfront cost then the lower unit cost is irrelevant, and you'll keep driving an ICE.
At least we agree on something. The point I'm making is that for many people upfront costs are the problem to switch from ICE to BEV, and grants need to ofer more help if Net Zero targets are to be met.
£350 off the cost of installing both a chargepoint AND a cross-pavement charging solution will still result in a fairly large bill (£2000 - £350 = £1650). These grants don't seem to come close to the actual costs - same as the grants for installing heat pumps don't come close to the cost or replacing a gas boiler (and upgrading some radiators and fitting a hot water storage system if you have a combi boiler). The move to greener homes and vehicles is going to be slow unless and until grants come closer to matching the costs.
Correct usage of DSG shift stick
Not on the Octavia 3 which still has a proper manual handbrake not a complicated EPB (which can be a nightmare when replacing the rear brake pads).
Seems to me you are both agreeing that the brake lights are on with Auto Hold?
