Help please, how can I tell if a lead is a clone or genuine
The solar sunroof was also offered on the B6/B7 Audi A4/S4/RS4 - I nearly ordered one as a factory option until I realised that you don't get light coming through it like a normal sunroof. Just make sure the VCDS cable you buy IS genuine not a clone, if it's too cheap then 99.999999999% it's a clone!
Car Locking by Itself
Do you have kessy? If you don't have kessy then the car has no means of knowing whether the key is inside or outside the car.
VRS tractor sound
If there is a leaking injector then the excess diesel can get past the piston rings and then into the sump, diluting the oil.
Octavia III randomly braking on the highway
I've never noticed the brake drying have any noticeable effect on vehicle speed.
Elegance model tail light
Then it's just the standard halogen tail lights - the Elegance doesn't have anything different.
Which size battery for a 1998 Rav4
+1 On my Toyota Aygo petrol there were 3 battery sizes - petrol, diesel and cold climate diesel - each getting larger and higher Ah and CCA. hen the battery needeing replacing I fitted the cold climate diesel battery as I had fitted a fairly power hungry ICE upgrade.
What type of rear lights do you have - halogen, LED low or LED high?
Erwin problems.
Could this be worked around by using a VPN?
That's not unusual - my previous 1.4 Octavia had a battery smaller than the tray but was the correct battery for the car as the tray is sized for the largest battery needed for all engine sizes/types. So just because the battery is smaller than the tray doesn't mean it's the wrong battery.
Do you have a fault code scanner, such as VCDS or OBD11? It would be useful to see if there are any fault codes related to braking etc.
Fuel flap lock
Is that a plug'n'play direct replacement?
On my previous estate which was an Elegance they were the standard all halogen tail lights. IIRC there are 3 types of tail light - halogen, LED low and LED high - fitted to various different models and years.
Fuel flap lock
IMHO at the very least there should be an emergency manual release - like on my ex's Mk1 Fabia where you could access the lock via an access hatch in the boot.
Do you have ACC or Front Assist? The symptoms sound to me like it could be the front radar believing something is too close in front and applying the brakes?
Skoda recall in Israel
Exactly my point, this isn't a DVLA Safety Critical Recall (despite the possibility of unncesssary injury to the driver) so Skoda won't be getting driver details from DVLA.
Mobile phone speedcam app
The UK Government, and even more so the NHS, does not have a great history of designing decent IT systems - so I won't be holding my breath for this to happen!
The difference is that it is described in Israel as a "recall" but in the UK it is just a "recall campaign" not a "safety recall", so there is no legal requirement on Skoda to inform owners. My L&K falls in the affected VIN range but since I'm not the original purchaser and I didn't purchase it through a Skoda dealer Skoda UK do not know I am the owner so are unable to write to me!
What concerns me is what are the Police going to do with (likely) all the videos sent to them, I suspect most of them will just sit in an inbox due to lack of resources to check them - which means the ones that are worthy of warning/prosecution will get lost in the mass of those sent in by someone annoyed by someone else doing something perfectly legal. Seems like it's a good idea but only IF properly resourced, which given the cutbacks on Police spending isn't going to happen IMHO.
Best way is to ask Ross-Tech by email to support (at) ross-tech.com
What does the (K) stand for in the model name?
Here's a theory: NYHET (NEWS) = 2017 models being sold at full price KANPANJE (CAMPAIGN) = 2016 models being sold at a discount to clear stock The way to know if this is theory is plausible is for @jobjor to look at the Model Year digit in the VIN and see it he has a 2016 or 2017 model.
VCDS what do I need? - READ BEFORE BUYING
It does refer to the vehicles VIN number. Modern VCDS cables come in 3 versions, 1 most expensive for businesses which can be used on any number of vehicles and 2 cheaper aimed at enthusiasts which have a limit (3 or 10) of the number of different vehicles they can be used with. They detect the vehicle by using the VIN that they read from the vehicle electronics, and remember that whenever you make changes to settings - note NOT when you just scan a vehicle or clear fault codes (DTCs). So when you read "2 VINs left" that means they bought a limited version of the cable, and have used it on either 1 or 8 vehicles depending on whether they bought a 3 or 10 VIN limited version. Note that for security reasons previous VINs cannot be cleared or read.
Canton Sound System and head unit / firmware upgrades.
@pab567
GPS map card
Skoda always spell it "Simply Clever" so I would strongly suspect that the one with "Symply Clever" is a poor quality fake. Check also that what you end up purchasing really is a 32GB card when it arrives, recently I purchased a genuine Skoda SD card from eBay that had been described as 32GB but when I checked on arrival it was only 16GB. The seller refunded me and changed the description!
Heavy corrosion around the Turbo and I am still within 6 months of the purchase
Turbo can get really hot, so it's not surprising that they rapidly show signs of rusting/corrosion. An example:
Octavia vrs hatchback 2023 mud guards.
It doesn't, there are many items I have previously purchased from Kopacek before Brexit which they now will not ship to the UK.
