Everything posted by numskull
- Can somebody help me with the wiring from comfort module?
Coming Home lights function
Yeah, I think that’s what I used to do.
Dsg thermostat
If the engine temp is going up and down, what makes you suspect it’s the DSG thermostat that needs to be replaced?
Boot open warning randomly comes on
Have the same issue with the ones I fitted in the boot….. but I’m only get the boot open warning and bongs when the glovebox is opened! 😁
Inside front offside wheel arch vents
Interesting AS; what’s the cost of the bits?
Gawd how I’d love one of those at 04.30 this morning when I’m up ‘n’ out!
Dunno. Hopefully this bumpy might elicit a response or two from those in the know!
Superb Sportline or L&K 272 or 280
The cheap L&K badging went in the first few days I had the car... and the rest followed a few minutes later!
DSG Reset (Basic Settings)
What an absolutely ridiculous thing to say. Where’s the next closest dealer?
Dashcam on the iV
Yeah,, sorry, off a switched live. Here is a the step-by-step guide I used. Position of fuses may not be the same but these are the fundamentals.
Dashcam on the iV
Hard wire it to the fuse box. It’s not hard.
So where is the BS when the tech told me that is was not possible to change or reset the shift patterns on a DSG box? Ahhh right, I see. So its actually like an automatic gearbox, responding to the demands of the throttle position and it is not actually a sentient being is it, “knowing the road it’s is travelling on”, so it does not ”learn” anything at all. Phew… I’m pleased we cleared that one up as I thought the 280 would suddenly decide to drive all the way to Aldi in 1st….for a laugh.
Is there any way to adjust the shift patterns? Also, how can it “learn” driving characteristics when the requirements of the road conditions dictate driving characteristics?
Discovering AFS headlights after installing LED bulbs
Well, OK, brighter in longer distance would be great. It’s all irrelevant anyway, as VOSA almost certainly won’t approve them.
Obviously Xenons have those. I’d be disappointed if there wasn’t a true performance upgrade too, in terms of additional light on the road.
I’ve had sunroofs fitted at build in the past and would never have one again. They’re a PITA to keep the drains clear and never used them once AC became the norm.
Our March 2016 280 is is Euro 6 compliant.
- Windscreen Rain Deflectors on A-Pillars
We have a March 2016 reg LK 280 and love it. It’s the best, most comfortable and fastest car I’ve owned bar none. Don’t bother thinking about economy if you’re in the market for one of these, as in true urban, I get around 25 (and even less if you blip away at the lights now and again!) and the very best mpg I’ve got is about 37, on a 1k round trip.
Windscreen crack, no obvious damage (chip): Is this common?
Let me be clear about what I meant. You are not actually “repairing” a windscreen with injected resin, you’re providing a cosmetic finish to mask the damage and to stop water penetration, but the actual structure of the glass remains compromised in that position and that’s why there are rules on the sizes of a fix applied to damage. Granted, things have probably changed, but when I worked with them, neither AW or AG would repair anything over 40mm, so 1.5 inches in the D Zone and they would never attempt a repair if it emanated from anywhere on the outer edge either, as it would inevitably just continue to spread with the constant stress the glass is under and in the case of an airbag deployment or should the car turn over, this could cause the glass to fail completely which is not something you want in either scenario.
Most insurers use reputable glass installers as the costs of getting poorly fitted units rectified is high, especially those which are heated and have camera units fitted, which need to be set up and adapted to the car. Unfortunately no, I’m afraid cracks cannot be repaired.
Enough is enough...2.5 years and still faults
Interesting comparisons, albeit comparing the Arteon, A6 and 5 Series to a Superb is a bit ridiculous, on RRP alone. Is the Enyaq really that expensive; I thought the coupe vRS was around €65k? (Which is still utterly ridiculous). IMO, the tyre roar and transmitted noise, so potholes and expansion lines on the M25 concrete section, were the most annoying “features” of the 280, but now the original P6’s are off and the Conti All Season are on, I estimate both have been reduced by 70%.
In the mid ‘80’s, I got rid of a 2 y/o Fiat Argenta as it was such a lemon (and Fiats biggest dud I should add) and I had a Friday night cocar Escort XR3i which was SO bad, Ford took it back. I see you’ve kept the Superb and it hasn’t put you off obtaining another. 😊
Well, to be fair, Skoda products have been in the top 15 of the U.K. JD Power Reliability Survey for the last 10 years so I guess that’s not too bad. Kodiaq was #1 this year for reliability and #5 overall. Warranty direct state Skoda comes 4th overall in their experience for reliability, with the Superb being the most reliable model.
