JR RS
Joined
Last visited
Currently
Viewing Forum: Skoda Superb Mk3 (2015 - 2023)
Everything posted by JR RS
Converting the Superb 3 Pre FL to the Superb 3 FL Matrix Light any experience?
@Waylon- wat is the byte/bit u r changing, and to wat? When I retrofitted SLA headlights, I had to modify Byte 21 Bit 5. Assuming ur playing with the facelift matrix LED headlights, u'll need to select the right option for u. Mine is set to Hex 40 as I have SLA. These r the available options with the 4B module:-
DCC Slider adjustment option mod
That is correct, given the current version of modules u have listed.
Rear Canton speakers replacement
How to remove cup holder?
As per @ApertureS comments earlier above, u need to remove the entire centre console.
Adding USB ports in armrest?
The push in version which goes into the existing 12v socket will sit too high. Hence why I replaced the existing 12v socket with the USB socket. If u want to simply convert the socket, then yes it does require u to remove the bottom compartment/console/ashtray. If u want to run a USB cable from it to the inside of ur armrest centre console, then yes u need to remove the surround, air vents and controls.
@Danoid - here u go.... https://www.ebay.com.au/itm/204100212481?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=52kk8DS-SF2&sssrc=4429486&ssuid=lD_jGR-4Tj6&var=&widget_ver=artemis&media=COPY
hey hey. the usb cable length was 1.2m - Mcdodo USB Type-C data, charging cable. with the 12v USB socket, yes it sits fairly flush. it needs to b if u intend to keep the console closed. u also need a low profile usb head (end connector), which is why i got a 90 degree version of the usb cable. i'll have to find the link to the 12v usb socket and share it with u. i got it from eBay.
These r not standard or upgrade for Superb, let alone any other Skoda models, hence it's not right to put the details on that post. It's something that I made up myself. I bought slim 2.7mm LED strips from AliExpress, cut them into 12mm length, soldered the wiring & plugs, then stuck them to a grove inside the door pocket, along the top edge. I spliced into the door warning lights for power. It involves removing the door cards, so u can drill a tiny 3mm hole in the corner of the door pocket.
Gandalf's Evolution
Latest project completed on Gandalf - added ambient lighting to the inside of the door pockets, so I can actually see wat stuff is in there. Wiring is piggy backed off the door warning light, so it turns on and off with the door open/close. All 4 door pockets now have ambient lighting 😁
How to remove front top panel to get to horn
That top panel is secured by torx screws as well as being clipped in across the top edge of the grill. See pic below - circles r torx screws. Dashes r clips. It is very difficult to remove from the top alone. I would recommend removing the entire front bumper, then u can easily access the two horns.
They exist now 🙂 They were introduced with the facelift Superb. Prior to that, ventilation was only available on the leather seats.
Skoda Superb DCC missing or not
I don't know for sure, but I believe all OEM DCC shocks r Monroe, across Skoda, VW, Seat etc. etc.
A company in the US, called DSC Sport performed some shock dyno testing a few years ago on the Bilstein Damptronic B16's and they found that the Bilsteins only are able to control the rebound, while the factory DCC shocks are able to control both compression and rebound with their valving. "This means the Bilstein Damptronics are a less capable setup when looking at compression adjustment, but still happen to have slightly greater rebound range. Basically the only benefits to the Damptronics are adjustable spring perches to change ride height and stiffer springs. But are not beneficial when looking at the "active" functionalities of the shock. This is due to the valve used in this specific shock, however in other Bilstein kits we have tested, like the Porsche Kit, the valve is different and was able to control both rebound and compression."
Rear window wiper
U don't have to agree. I prefer practicality over appearance. If I had the option, I would prefer looking out a clean rear window than a dirty window. This is based on my experience of having a liftback with a rear wiper, and now having one without.
Rear window wiper
i miss having a rear windscreen wiper on my Superb hatch. i had one on my Octavia RS hatch, and it was great. the rear windscreen is so large, and mostly flat - it gets filthy, and i hate that. sadly we (in australia) never had the option to spec a rear windscreen wiper for the mk3 Superb. stupid. retrofitting one is not an option either, otherwise i would've done it.
Starting to really dislike my Superb - Blower, Clean Air sensor, Missing Databus etc etc - Good NW/Stockport/Manc person required
I ordered a genuine AQS recently, 5Q0907643F, from ECS Tuning. Waiting for it to arrive. I currently have 5Q0907643D, from factory. My AirCare doesn't work, and occasionally I'll get an AQS error in Module 08, but no side effects. Am hoping this version will stop the errors and AirCare will b good. I too have read on various other forums of people buying the cheap AliExpress version, and then running into worse problems, and removing them in the end. My original AQS.....
245 tyres and scraping?
I've got 245/40/19 tyres on the factory 19x8 rims. Car is also lowered and on 10mm spacers at the rear & 12mm at the front. No scrapping or scrubbing issues.
ACC Question
I always keep a finger or two on the steering wheel because I can't trust it 100%. However it's much much more relaxing to have, especially on long straight highways & freeways.
Garage full of goodies!
ACC Question
with the pre-facelift, on mine at least, having the start-stop active or not makes no difference - it is 3 secs for ACC to auto resume. i mostly drive around with Start-Stop inactive as its annoying in start stop traffic. i'm used to it now. i'm glad i got the lane assist duration changed from 12 secs to 60 secs would highly recommend it to anyone.
DSG 7-speed gearbox complete failure - are Skoda UK likely to pick up repair costs?
A 7 yr old Superb will not have the 7-speed DQ381 gearbox. That variant didn't show up until recently. It will have the 6-speed DQ250 gearbox. Either way, hope u have a happy ending n u get to keep the car.
VCDS options on Superb III
Did u have a look at @MartiniB link above? He has put together a lot of Codings for the facelift Superb. It's great.
Gandalf's Evolution
I couldn't resist Kopacek's recent 22% of sale, so i added some "aero fins" to Gandalf's rear end....diffusser. Removed the diffuser so i could paint it gloss black, then the aero fins glued on as a single piece. As a result, my drag coefficient has dropped now and my fuel consumption has improved remarkably!! ....yeah, and pigs fly too!!! 😝
