RADIOTWO
Everything posted by RADIOTWO
  1. Just to put a spanner in the works, If you are using just a single camera you might be fine, but if you are thinking of both front and rear I don't think the USB supplies enough power for both. But to be honest connecting to the fuse box is not hard and its then just a matter of running the cable under the trim
  2. OK Dave, if you were a bit closer I would recommend East Yorkshire Retrofit as I have had some work done by them and the did a perfect job fitting a reverse camera, but would have liked the electric retracting towbar, but I guess the company in Poole will do the job right (hopefully at the right price) for you, Good luck
  3. Wez Morrell Manchester Wez Morrell Manchester 0161 430 7591 I had mine done by this company I know it not near but give them a ring and see what they say ?
  4. Where abouts are you in the country ?
  5. First thing to check is what your car can tow, a lot have zero Kg limit, and that would stop you towing, you can check on the sticker on the drivers door slam (thats where mine is) and then find a decent towbar fitter that can code as well as fitting the bar, I had a removable one fitted to my VRS estate and had it coded and if it is coded correctly you wont have any problems with reversing, as when you plug in it detects the trailer(Caravan) and switches off the system for reversing !
  6. make sure the radar sensor and windscreen are clean
  7. I know this should not happen but why would you leave your Kessy keyfob in the car, I have never done that, even with the old keyfobs. I put the key fobs in my pocket so when I get out so does the fob
  8. Why go you want a Lockable fuel cap, when there is one all ready on the car !
  9. Yes you assume so, but have you checked for parasitic current draw ?
  10. You don't need any device to do the front, but you need a wind back tool like OBD11 etc to wind the piston in to change the pads
  11. When you got the replacement battery did you code it ?
  12. As I said I have all ready done that, but still did not work ! but funny enough I tried it this morning and it worked correctly without and pressing and holding it it just worked ! (Confused)
  13. Hi all, VRS 2Lt Derv 2021 I had a flat battery this morning, I jump started it and all seems ok other than the one touch drivers window does not work, I tried the press and hold down, and press and hold up but that does not work, and the other three windows work fine with the one touch. Any ideas please
  14. I bought a 21 plate VRS with no towbar prep and had a detachable aftermarket bar fitted and coded, all without problems
  15. As no one has replied, I don't know but is the panel held in with bolts? (cannot tell as the picture is not great, so poss a closer shot of the fastenings), but the other method i have seen in the past, is they are riveted, and you have to drill out and then replace with new rivits
  16. Just my two peneth, I don't think the Halfords one will work correctly but I had one fitted by the guy in Brid and it all works fine
  17. I know this does not help the infortainment side of things but why do you not log both phones on y Bluetooth ?
  18. Just use a memory stick a lot easer, and we know it works, But I guess the reason why the CD players don't work is its the wrong media
  19. What has a standard/electronic dipstick got to do with draining oil from the sump ?
  20. Sounds to as you need to take it to a different dealers, I have never heard of a 60:40 bias to the rear on the brakes ( yes 60-40 on the drive on a four wheel drive) I cannot answer why the rear pads are worn more but have you checked the callipers to see if they are sticking ?
  21. The ACC does not use just the rear brakes it uses all four as its just as if you are using the foot pedal, in fact if you just cover the pedal when the ACC cuts in you will feel the pedal go down !
  22. I know the other guy has attached a link but do not just run a 12 volt feed from the fuse box, as USB is 5 volts !
