SOLVED: Fabia cranks but won't start - sometimes!
Which engine does your car have @lalwong? I've looked at all your posts without discovering that.
Fuses 17 and 56 look to be ones to focus attention on, permanent and ignition switched 12V supplies to engine ECU on the 1.4/16v. Unfortunately the OP's photo isn't working and he/she hasn't logged in for more than 9 years so I doubt that a mention will work... @Al115, how's it going?
Some bare wires and bad connectors in poor conditions
Can you put the battery on a charger for a few hours to get some energy into it? I think it will not have been getting charged well by the alternator with all these broken wires and bad connections.
Does the battery light now come on with ignition?
In this photo, there's a red wire going through a blade fuse just hanging around near the right-hand one of the two thick black wires. From what I can see, the top end of that wire might be attached underneath the connection of the big black wire to the fuse? If that is how things are, swap those over so that the big wire is straight onto the fuse, the red one on top, under the nut. That will improve the connection of the big black wire, which supplies everything in the cabin.
7Zap Parts diagram help
Take the one off the TB and see if there's a part number on that. Then get the other number.
Apologies for inadvertently muddying the waters. Listen to Tech1e.
Look at the part on the car, see if there is a part number visible on it. (Almost certainly easier said from this sofa than done in practice). Failing that, look at the next hose that it connects to on the way to the intercooler and compare its resemblance to items 11 or 6.
Yeah, it all looks a bit scary round that area. The wires going to the actual battery positive clamp look to be held in by not much more than a prayer in one of your previous photos. The latest photo shows three fuses that have been bypassed, including the one that the wire in your fingers (alternator output) should be going through. The crimp termination on that looks 'amateurish' so there is probably a significant contact resistance there which explains the heat. That will be lowering the voltage getting to the battery from the alternator too. Try to find someone with the tools and knowledge to make some better terminations on these wires. This is the type of tool needed to do these jobs properly, not something that many garages or amateurs are going to have. 16.0mm² - 120mm² Heavy Duty Crimp Tool (tlc-direct.co.uk)
MK2 fabia vrs. Excessive front tyre wear new to fully bald 3000 milesBala
Set the steering wheel central, look at the driver's side front wheel from in front of the car and make any adjustments to the steering wheel to get that pointing straight ahead, in line with the rear wheel. Drive the car forwards a yard or two without moving the steering wheel. Then take a look at the both front wheels and see how straight they look relative to the rears. For wear that fast I think you'll see a misalignment with mk1 eyeball.
Mustn't be pointing in the same direction.
Mk1 vRS BLT Crank (G28) sensor wiring / loom issue
Pin 1 white to ECU 110 Pin 2 brown to ECU 102 Pin 3 black to ECU 101 (colour change to brown white on the way after merging with another wire)
Fabia mk1 exhaust replacement
Have a look through the packaging at the pipe profiles at the ends where you'd be joining with coupler sleeves. I had one from ECP, not sure which brand, with a bleeding great lump of weld seam down one side that was never going to allow a good seal without being fettled.
EGR Valve P1440 - 35-10 - Open Circuit
Yep, green/white from pin 6 of EGR to engine ECU pin 100.
In the mean time, can I damage the car driving it with the EGR valve not functioning correctly? No. Will double check right now. Short-cut wire will be fine.
Biceps tendon rupture, anyone 'been there'?
Massage guy was quite pro-surgery on the basis that if the other - now more heavily used - half of the biceps were to have a tendon failure down the line I'd be needing surgery anyway, or my arm would not work well at all. That's swayed me back towards thinking the op may be worthwhile. He also reckoned I might find it quite limiting to be without that 'cep' for my sailing hobby; it might even be a safety concern on the racecourse if something failed while on the water. GP surgery have referred me now on the basis of the physio report. Wonder how long it'll be before I hear from a hospital.
Another Dipped Beam Problem
Something as cheap as this would suffice: https://www.amazon.co.uk/gp/slredirect/picassoRedirect.html/ref=pa_sp_atf_aps_sr_pg1_1?ie=UTF8&adId=A02336471JUNE0E508DO4&url=%2FMultimeter-Resistance-Transistor-Continuity-Electrical-Black-Yellow%2Fdp%2FB07BMQ578Z%2Fref%3Dsr_1_2_sspa%3Fcrid%3D2AOFC233UQ3CE%26dchild%3D1%26keywords%3Dmultimeter%2Btester%26qid%3D1606747123%26smid%3DACF3DDDQW388N%26sprefix%3Dmultimete%2Caps%2C156%26sr%3D8-2-spons%26psc%3D1&qualifier=1606747123&id=5219059326645010&widgetName=sp_atf
- 3 replies
- dipped bulbs
- fuse
- ground fault
- headlight
Tagged with:
Inlet manifold
@GULF1 Is that what you're referring to?
Inlet manifold
There's an unconnected one on yours @TheClient pointing off towards nearside of the car at that end? Presumably there's a blanking bit of plastic inside?
Check with a multimeter for volts at pin 1 (yellow/black wire) of the 10-way connector (disconnected from light module) relative to pin 10, brown wire, when the dipped beams are turned on. Does the car have bulb-failure warning system?
- 3 replies
- dipped bulbs
- fuse
- ground fault
- headlight
Tagged with:
Not sure about that one. Insulate the cut end with waterproof tape and investigate further when something doesn't work?
Octavia Vrs airbag light
- Octavia Vrs airbag light
Lots of non-specific fault readers will only talk to a limited number of control modules.- Octavia Vrs airbag light
Airbag light always seems to need VCDS or dealership equivalent to reset. It's one of the few that doesn't go away when the fault is resolved.- Some bare wires and bad connectors in poor conditions
This must be the engine speed sensor connection, also known as crank sensor. Can you see any pin numbers on the housing of the broken part? If so match pin 1 on broken part to brown wire end. I can just see the numbers in the photo above, on the loom connector close to where the wires emerge, look in equivalent position of other half. The brown is 0V, the black is cable screen, white is signal. Brown and black may be connected within the engine ECU even though they go in on different pins. You can probably measure a small resistance between the pins of the sensor that are supposed to connect to pins 1 and 2 of the connector in this photo. Does that make sense? I can draw a little diagram if it doesn't. - Octavia Vrs airbag light
