Gaz
Everything posted by Gaz
  1. How do you know there’s definitely’ water coming in if you can’t find it? Have you checked under the carpets? Have you checked your pollen filter? - they can get mouldy and manky quite quickly. Agree with JD52 about aircon and using a cleaning/sanitising bomb. Gaz
  2. Without wishing to tempt fate, the high volume of junk stopped, all of a sudden, five days ago. I've not adjusted anything, and I've had no junk at all (other than than which should be being deleted without me seeing it, which I obviously won't know about). Weird. G
  3. I've made four insurance claims over the years, two at fault, two non fault, and I've never been asked to prove my occupation. G
  4. I hate you (not really 😘) See, this is the type of post I really don't need to read. A recent solar installation and I'm exporting loads to the grid (double what we use). It's got me thinking that maybe it's time..... but a recent 900 mile round trip and my very comfortable GTI managed 50mpg at some points, which I was really happy about. But then long term (30k miles) it's cost me 19.1ppm, so almost three times your ID.4. I've already got an e-bike, a mobility scooter, so EV should only be a small step. But I like my petrol car, and I want to not like EV's, but all three I've driven have been great, which is not helping 🙄 Gnarrr, harrumph, grumble, whinge...... I don't wanna take my head out of the sand 😳 G
  5. Ah, I see. If it were me, I wouldn't be saying or writing anything in relation to occupation 'X' if it's not the case, for the very reason you note. A quick Google would seem to provide a host of answers to your question, and potentially confirm your concerns. FWIW I've had several jobs where my job title or employment don't directly match the list of options available. So it's not an exact science, and insurers have taken the approach of the most logical match. The difference between employed and self employed is more significant I'd think. Gaz
  6. Not sure I'm seeing the problem. Your insurance says you are both employed and self employed. The incident happened during the time that you are self employed. Have you specified the hours for each? If you have I could see that might be an issue. If you haven't, then part time can presumably mean anything from zero, to a gnats whisker of full time. If you are self employed, are your full time hours (e.g.) 50, but you're currently working 49, so therefore are still part time? Either way, the rest is surely semantics and you have insurance for the purpose the vehicle was being used for. Gaz
  7. You've tried switching it off and on again? (Was a serious question - reboot might reconnect summint) I think getting a new card might just provide it with a new list of places and stuff, but if the problem is that it doesn't know where it is, then something else is up. Agree with langers2k. Gaz
  8. Is it a Mk2 or Mk3 Octavia you're looking at? I would imagine it'll have the DQ200 seven speed dry clutch DSG. More of an automated manual than an automatic. We have the DQ200 in our Polo and it's been faultless over 49,000 miles. The DQ200 from that era had an issue with the fluid in its transmission. A Service Campaign '34H5' was initiated to rectify the matter. @ toot (amended-ish to avoid any confusion) might be able to provide further info on this. You can search 34H5 on here and find plenty of reading material. I'd be wary if the car you're looking at hasn't had the SC applied to it. Gaz
  9. Gaz replied to cliff7's topic in Hellos and Goodbyes
    Hello and welcome Cliff Gaz
  10. Don’t the 2.0 TSI’s only come with a cam chain, rather than a belt? My 2018 one is certainly chain driven. Gaz
  11. Good clouds and sunset from Beachy Head tonight: Gaz
  12. Hello Dave, and welcome to Skoda ownership Gaz
  13. Could it be the smell is there on 'Lo', but is more noticeable when 'above Lo' because you are blowing more of it into the cabin? The heater itself is ostensibly a small radiator inside the dash area. It doesn't do anything clever. Faults are more usually a blockage (no heat) or rupture, in which case you should see leaking coolant and have the sweet smell of hot coolant. The fan motor, resistor block (per @J.R.), and motorised heater control flaps are another matter, and any of these might be causative. Have you checked your pollen filter to make sure it's not rank and stinky? They can produce some odd smells when going off 🤮 And just one further thought; The Mk1 can have issues when the pollen filter foam seal degrades. A fix is obviously to reseal the pollen filter with the appropriate cord or sealant. The two rubber bungs in the plenum chamber are often removed to stop them getting clogged with leaves and other detritus. With these out, more hot engine smells can find their way into the cabin. Gaz
  14. Uckfield carnival this afternoon. I got buzzed by a hot air balloon. I heard people talking, but it was coming from a 'wrong' direction. Then they were waving at me 😎 G
  15. Glad you've not got any plans to mess around or mod it then Gaz
  16. My first Skoda was a Mk1 V6TDI and was a cracker. Very reliable and wafted along lovely. But I think you're right in looking for a 1.9. I think the biggest thing in my ownership was water getting in through the dreaded pollen filter and drowning the CCM. Easy enough to check and quite straightforward to remove the filter housing and seal it properly. Early signs are odd electrical gremlins associated, and of course water under the carpet in the passenger front footwell. Good luck with your hunting. Gaz
  17. Possibly your blower motor starting to wear/burn out? Can be serviceable, but it's more usually a take it out and replace the unit jobbie. It depends on how much fiddling you want to do. Is it an acrid electrical burning smell, and only there when the motor is spinning. Just wondering if it's something else, but either way it needs investigating to be on the safe side. Gaz
  18. Mercedes EV coming off the Freemantle Highway gets dunked: As said, and noted in the comments, it didn't look particularly damaged, so I wonder why this one, and not other EV's that are being offloaded. Gaz
  19. Hello and welcome HH Gaz
  20. https://www.briskoda.net/forums/about/
  21. Have you checked the pollen filter and air entry prior to it? Is the fan actually blowing (as oppose to the motor spinning, but not the impeller)? Gaz
  22. Sky? what sk..... ohhhh 😇 Is that the Seven Sisters at 9 o'clock to Jupiter? G
  23. Hello minky, from the South Coast too Gaz
  24. It's not far off doing a sub seven minutes at the Nurburgring either. Pretty impressive bit of kit 😎 Gaz
