Neily03
Everything posted by Neily03
  1. DSG has been standard for while, the manual gearbox was dropped from last June's brochure iirc.
  2. Benny's Emblem Design on instagram does fantastic repainted OEM badges.
  3. you just need to scroll through the settings for the individual gauge on the VC and select it.
  4. erm, it’s the gauge on the left, opposite side to the fuel gauge. Either way you don’t have a problem. It’s just water condensing in cooler weather.
  5. Autoglym interior shampoo for all interior cleaning 👍 https://www.amazon.co.uk/AUTOSTYLE-AG-035001-Autoglym-Interior/dp/B00114WOBC/ref=sr_1_5_pp?crid=34M6TBC71F0L6&keywords=autoglym%2Bshampoo%2Binterior&qid=1707305566&sprefix=autoglym%2Bshampoo%2Binter%2Caps%2C90&sr=8-5&th=1
  6. it's on my vRS which is standard spec, trying putting it into sport mode, it's much more noticeable. Unless your talking about cornering fog lights which is also standard and easy to see if it's working or not.
  7. Why do all threads on briskoda end up like this 🙄
  8. Yep, for this reason I never buy a new car within first year after launch at the least.
  9. Voice options are at the very bottom of all the languages
  10. Sounds like faulty to me, it’s spring loaded so should always naturally retract.
  11. Yep, never been on a forum like this, does it even have moderators?...
  12. I've honestly never known a more hostile forum that Briskoda.... Back on topic, problem solved and no more annoying message. 😃
  13. Erm yes it can, I did it with my ODB11.
  14. Cheers, I suspect that's the one as it's also shows that icon on the VC at the same time. Took me a bit of searching to find, it's a bit hidden. Hopefully that's sorted it now 😃
  15. Eco tips switched on and back off again and all options in the factory satnav switch off (I use google maps anyway) and I still get the message. Never mind, it's a very minor annoyance in an otherwise great car.
  16. It usually does it when approaching roundabouts and also displays a graphic of a roundabout.
  17. I'm sure i've got Eco tips switched off but will double check.
  18. Anyone know how to turn the above off? Ive been through every setting i think might have something to do with it to no avail. Cheers
  19. Do you have Auto Hold switched on? Is the button illuminated orange?
  20. Do you have Auto Hold enabled? The car won’t start until you press the accelerator.
  21. No, it's no different to any modern car, secure. I just don't lock anyone inside it as that would be silly.
