Everything posted by JD52
Ride height
As far as I am aware, DCC only has an effect on the shocks and not the suspension height.
TPMS Set, cannot store?
As far as I am aware you can't set TPMS while the engine is running. This should ensure that you have stopped the car and checked the pressures.
Who's at fault?
Totally the Merc at fault. Reversing out without checking what's there.
Memory seat
Do you have personalisation eneabled?
Missing SD card in 2016 Skoda Octavia 1.4 TSi sport
A good USB cable is a must, but will wear out the phone connection eventually. There are several wireless adapters that will give you wireless carplay.
Android Auto Wireless on Skoda Octavia MK3
Purely from personal experience, I would recommend the AA Wireless dongle. Had one for several years and had no issues whatsoever. Itregularly updates and reboots without problems.
- Key Fob not flashing when button pressed
People saying my car doesn't exist
Apologies, my mistake. It's the VRS that was diesel only.
if 4x4 it will have a differential at the back. Has it been written off?
Are you checking reg plate or chassis number?
A quick look under the rear should clarify 4x4. The 4x4s only had the diesel engine.
- Coding mirror dip
AA Wireless
I'm not sure why you think that the 2.5Ghz and 5Ghz bands should have different names but they should be part of the same network allowing the phone, and other devices, to connect to the best signal.
AA Wireless
Sadly, my brain can't remember the details, but I probably used the website. However, your phone only connects to one wifi network at a time. Your home network may be stopping your phone connecting to the AA Wireless network.
AA Wireless
I have used the AA Wireless device for some years and have not had any issues. Once setup it simply connects to my phone when I get in my car. There are some cheaper options which have been used by others without problems. Good luck with your search.
- Navigation & Firmware Update Issue – 2020 MK3.5
Extended warranty. Is it worth the money?
Agreed, although some owners have issues with their dealer. Personally, I have had no issues with my dealer and am happy to continue for the next couple of years.
It's like insurance, great to have and costly. Until something breaks and then it's worth it. My car will be 8 years old when the warranty expires. Despite my low mileage, 24000, keeping contact with Skoda must be a good idea?
- Problem with new Navigations maps
Skoda Octavia stop start not working and high battery charging
It. Could be worthwhile going for a longer drive to see whether the stop/start kicks in when the battery gets to a decent level. If it does kick in, then the battery is falling. Good luck.
Elm327 Bluetooth reader
Yes, it is, and it's a drain on the battery. If you leave your car with the reader plugged in, it can drain your battery faster than normal.
warning in stop start system
Have you checked in the car staus in your MIB unit? This will tell you why the stop start is disabled.
Keyless Issue - Leaving car running…
Get used to looking at the dash, if it's all lit up, the car is switched on. 😀😀👍👍
Skoda Columbus, Extract GPX tacks possible?
What sort of camera are you using? Some cameras automatically add the GPS coordinates to the photos.
