skomaz
Everything posted by skomaz
  1. Yep that's it. I'm coming from the South West so not much better. I don't head straight in but go round the outer ring to the south east and then in form the direction of the station to the Apcoa car park.
  2. In order .. All Cantab degrees used to be classed as BA or MA. No Yes but expensive And finally thats all a bit off topic.
  3. You have my sympathy!!! I'm a born and bred Sheffielder and work in the city centre but still struggle to get to some locations given the mess the LA have made of the roads... Hope you didn't get fined (I assume the M-car is compliant?).
  4. And a totally unnecessary jibe at me as usual... For your info drainage is different to sewage treatment. Ive done drainage, not sewage treatment and discharge.
  5. It's been reported a number of times in the local press but through my work I've also seen local monitoring and AQ modelling data. To keep up the 'about me' I'm a Chartered Civil Engineer with a general engineering Masters from Cambridge University. I have over 33 years experience of the design and construction of projects ranging from flood defences, water supply and drainage schemes to concrete and steel structures but mostly in highway design and construction, transport planning and environmental impact assessments.
  6. Oooh. Not sure. The Swift has that too but i can't say ive ever checked or ever had someone following me i knew who could check either...
  7. Probably the rear fog light warning
  8. That is slmost what my swift hybrid seems to do... Lift off and you get a bit of engine and low level regen braking, touch the brake pedal and the lights come on with a higher level of regen braking, press harder and the mechanical braking kicks in too.
  9. Just as a quick aside to these discussions, the worst areas in Sheffield for pollution are Arundel Gate and Sheaf Street - the former as it is a main bus thoroughfare (cars only allowed in one direction due to bus gates) and the latter due to proximity to the rail station and train lines. I believe the same applies to Oxford Street in London that is bus only. The M1 speed reduction for air quality mentioned in earlier posts was a trial to see whether it had an impact - the results are still awaited but data I have seen suggests the impact has been minimal. As for the Sheffield CAZ it is quite clear from its geography and the business case that it was taken forward in preference to other options because of the money it would bring in through charges for the Local Authority - the business case shows huge dis-benefits associated with the scheme in multiple assessment criteria.
  10. So surely you should be welcoming Graham's interrogation of the data and news items? There are clearly many false statements being made on both sides of the fence... so a balanced discussion is needed, as opposed to a one sided evangelical 'do as I say' approach. Perhaps you should try to convince Graham rather than belittling him for his point of view and for not sharing your personal opinion on the matter??
  11. My mx5 is 28 years old now and Euro 2... I have no doubt it'll still be around in 2030 albeit probably not doing many miles...
  12. Ok im confused now. If it was a third full and you then put 43 litres in it should nowbe full... You said your gauge was showing one big division below half full after filling. If so its way out.
  13. Should be about 65litres so filling with 43 should have taken it to two thirds full... So that gauge is reading wrong
  14. Mine went on our Octavia 4x4 at about double that mileage but started as a distinct droning noise under load in high gears. Does yours exhibit that sort of noise? If not how have they determined it is failing as I've seen a number of people suggests that it can look in a bad way with the rubber showing some cracking but not actually be failing... Just showing wear.
  15. For reference the Octavia 4x4 we had definitely had a saddle tank with a 'hump' in the middle and a transfer pump to even out the level across it. However i understand it was a sngle tank that was connected at the top so when it was filling up fuel would naturally flow into the far side. Not sure if the Superb is the same but if it is that upper link would mean the level in the filler would drop as fuel was used... So im still betting on a blocked anti Syphon arrangement
  16. I'd be surprised if it didn't... I used it on pretty much everything black on both cars and that would have included the roof bars on my FILs tourer. I think i have a tiny bit left still so if i get the chance I'll try it on a hidden part of the bars on the kodiaq
  17. On the bumpers try some GTechniq C4. I used it on the black trim on two Civics (my old Mk8 and my FILs Mk9) and it brought them up a treat from that sort of condition and lasted a few years. It's expensive but if the trim is cleaned with isopropyl alcohol before the C4 is applied it seems to work and last really well. Plus it's a nice matt natural finish rather than false shiny black like some stuff is.
  18. I'll stick my hand up to that - yes I do - I generally run the Eco (2.7 bar I think) pressures on a daily basis but up them to the loaded ones (3.0 at the rear from memory) when we're doing long fully loaded runs (eg holiday run to Belfast and back or a run to and from Lancaster to Uni with my daughter - both fully laden). There is a noticeable difference when laden as the back of the car is more stable, presumably due to less tyre squish)
  19. Thanks for posting that test... I have the Falken 310s on my Swift and reckon they are pretty good... Which that test backs up.
  20. Do you mind if I ask who by and rough cost? I'm in a similar situation with respect to no towbar and am getting to the stage where I probably need to remedy this so I can start using my bike rack again...
  21. skomaz replied to awfabia's topic in Skoda Yeti
    If they do that then it needs to be thoroughly dried before application of the Dynax - ideally through a something like a paint oven. That usually makes it more than a two day process.
  22. Had similar on our old Fabia and Octavia 2 Estate - I simply re sealed over the top of the original using a polysuphide sealant (I think it was Tiger Seal)... You can probably check that your assumption is correct by using electrical tape as a temporary 'seal' between screen and body and seeing if that resolves the issue - if it does then you can re-seal properly
  23. ^^ what he said... The white looks much better than the murdered out black.
  24. Niro, grandland or 3008
