Carlodiesel
Everything posted by Carlodiesel
  1. Paul, maybe contact Skoda Customer Services & talk it through it with them. FWIW, yes it should last longer than that. Maybe a duff batch.
  2. Agree that is irritating. Why have you got your "settings" on Assistants.??
  3. aubrey, exactly the same here. When refitting, I always wipe a finger of copper grease round the hub where the disc sits. Also coat the back of the pads & the sliders with Mintex Ceratec anti brake squeal. Does the job well.
  4. I have Bosch Original brake pads on my Yeti. So when & if I ever come to replace them, I'll fit Bosch replacement parts. Bosch Front Discs Pr. £47 Bosch Front Pads, set £20 Bosch Rear Discs Pr. £34. Bosch Rear Pads , set £15 Total Genuine Bosch parts £116 Or EBay have a Complete set Of Discs & Pads F&R for £80. (make not known) So Rod if you are reading this, as others have said, do your homework.
  5. Vimmal Jith Change the Diesel Fuel Filter. See if that cures the problem. And 30kph 1st gear.
  6. Can't help you much here Vimal, but "third gear around 30 kmph"?? Your at a very low speed apprx 20mph, in 3rd gear, which will incline the engine to want to stall. At that speed I would have thought 1st or 2nd gear would be better. Just a thought...might help.
  7. Yes, they are both the same. Do one side at a time it will soon workout ok. Recommended, replace the coil springs as well whilst your there. The state of our roads are appalling what with pot holes & the like, so would be a good idea.
  8. Yes both shocks are the same . Its the stubs that carry the shocks that are handed. Don't forget you will need a coil spring compressor tool to remove them from the springs.
  9. As he was interested in a higher power the ABS was 77ah and with a five year warranty. Still better value than the Tanya. Even if Brijo has a petrol the small extra would still be worth it. (as long as it will fit) IMO.
  10. Again can only recommend after purchasing several batteries from here. Normally next day delivery. https://advancedbatterysupplies.co.uk/product/096xd-advanced/ Advanced 096XD Type Car £75.00 free delivery. With 5 year warranty. Weight 19 kg Warranty (Years) 5 Ampere Hours 77 CCA (SAE) 780 Voltage 12 Length 278mm Width 175mm Height 190mm
  11. Have a look on Asda Tyres site. All in prices, you pay no more than stated. Low price 225/50 R17 tyres | Asda Tyres asdatyres.co.uk
  12. I hope you didn't take my reply as to mean replace the tyres with new ones... Don't replace them if its not needed. Just try the Spare wheel first. It's a question of illimitation.
  13. Quote "was wondering about using the space saving spare wheel I have. Fitting it initially to the ROS" Yes try it. If still there try to N/S. Its a question of illimitation.
  14. I just read your earlier post about the noise.. The only thing I can think of is the tyres. I see you have changed them F-R but is there anyway you can fit another set of wheels, no matter what the tyres are like. It will be only for testing. Without hearing the noises its very difficult to know.
  15. Just one small tip for the damp interior windscreen. I have an old bed padded under blanket in the garage covering up my bike. On suspect very cold nights I drape that across the dash top & tuck in well up to the screen. In the morning, I carefully remove & screen is as normal. If you experience sticking doors on the rubber seals, I have used dry chain lube, spray a little on to cloth & wipe over the seal.
  16. Well I must admit, when it comes time to replace the Yeti, I will be off to look at the Toyota Yaris Cross. And, the Volvo XC40. But it wont be this year. So far since March only used a tank & a half of fuel. But not full EV, maybe a hybrid. Thinking how things are going with finances, I am sure the Gov, will be putting the boot in with whatever we go for. So, maybe the Yeti will stay for some time to come.
