Stolen Recoverd Octavis vRS II on ebay
It's Hedge's old one that was nabbed.
I think a mod should remove this post Ians had a gut full of this keep on springing up to haunt him.
They keys from the house gag? thieving scum.
It will be interesting to see what it finishes on.
What is it with Ebayers and a complete lack of spellin & grammer (sic). Would I buy a car off this man? no thanx
Agreed - it's been on nearly as much as the Octy going through the church roof !
It supposedly sold once.
Possibly a good buy for someone if its been fixed properly. :)
If Ian wants it deleted then I'm more than happy to do it.
hmmm, engine is sound... did the insurers ever sort the engine out after the thieving scum ragged the f--- out of it?
There was, IIRC nothing wrong with the engine and it ran fine. The problem was a fault code on the ecu, that stated that "max engine speed had been exceeded warranty void". Having seen how easy it is to generate the fault, having done it a few times on my old vRS with no problems I dont think its a real issue. Once cleared with VAG-COM nobody would ever know.
Is that a common problem?! If its over reved, the it voids the warrenty?! Wow, what happend to making a car build to be driven hard.
But I think that fault code was on there a number of times along with a distinct lack of oil in the sump it wouldn't have done it any good at all
I didnt think the overspeed condition fault could be cleared via VAG-COM, I thought it always came back
As for being built to be driven hard, this isn't a Honda VTEC, it's an Octavia. The only way to do it is to accidentally (or maybe in this case deliberatley) change into a higher gear when going too fast. The engine wont be fuelling though so it probably isn't damaged in any way
There was a lack of oil in the sump and the garage feared for the condition of the Turbo. It was driven hard enough to melt the Lambda sensor in the downpipe.
I take that back :D
:wave23d: Yes I'm here.
Car was deemed to be a write off as the garage wanted to add an engine and turbo to the bodywork bill of 4.5k.
The engine overspeed had occured 8 times.:eek:
All gone now but it seems not forgotten. I just hope whoever buys it doesn't come on here.
"The engine wont be fuelling though so it probably isn't damaged in any way"
That's got nothing to do with it - If you massively exceed the designed RPM you may get valve/piston contact and other damage regardless.
It sounds like a basket case.
So sad to see what was an immaculate car in such a state :(
Yeah, but what I meant was if you accidentally changed from gear 5 to 2 instead of 4, and say accidentally touched 8-9k (Did this once by accident) then the chances of instant or long term damage are not that high, engine braking will bring the speed down very quick
On the other hand if you removed the rev limiter and acually drove it up to (And Sustained) those RPM's it's not going to last long
Either way that particular car sounds like it was being deliberatley driven to destruction, theiving scum:mad:
of course it was, as the phrase goes "drive it like its stolen", they certainly were not going to take it for a potter down to the shops.
Enjoy:-
2 Faults Found:
004243 - Bank 1; Fuel Measuring System 2: Malfunction
P1093 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 65758 km
Time Indication: 0
Date: 2000.00.00
Time: 17:09:57
Freeze Frame:
RPM: 1295 /min
Load: 17.6 %
Speed: 11.0 km/h
Temperature: 89.0°C
Temperature: 38.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
000537 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
P0219 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 8
Mileage: 66095 km
Time Indication: 0
Date: 2000.00.00
Time: 17:54:02
Freeze Frame:
RPM: 7265 /min
Load: 9.4 %
Speed: 221.0 km/h
Temperature: 90.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
Readiness: 0000 0000
awww, they only got it 221 km/h? Not trying hard enough. ;)
changing into 6th at 140mph... lovely.
Hope you got the plate back on retainer to sell on.
