What did you do to your Skoda today?
Bottom half wash; waste of time giving it the full Monty with the rain and filthy roads. It's tractor and slurry time.
  • Replies 7k
  • Views 513.8k
  • Picked up the new VRS: 2013 Fabia VRS by Graeme_Smith, on Flickr
  • Popped to the garage at lunchtime to swap coolant temp sensor. I don't think it's the problem but it can't hurt. Going to swap O2 sensor later for the spare I have. Went well, all sorted in 5 mins. T
  • modified the cup holder     It's now a hobnob holder
Went to see it last night at the garage... Must still be inside in bits :(
Replaced the high level Led trim surround, I wanted to clean the glass inside by led :giggle::blush:
I cleaned what appeared to be an explosion of salt off the bonnet. I had to get the nasty t-cut out. Thought it best to do it before I go on holiday
left it on the drive and took the wifes A2 :D
Wanted to give it the economy drive test. Previously tried on a motorway run 40 miles at 60ish, managed 63.9 on the display
changed from 17's with 205/40 tyres that weighed in at 40lb each to 15" peperpots with 185/60 Kleber Quadraxers that total at 30lb each
Now on the way I was sat behind a wagon bouncing off its limiter so sat nav showed a steady 55 and it returned 88.8 over 30ish miles
on the way back sat at 70-75 and got 62.5
so all in all very happy with the improvement :D
Nice results!
P.S. Love your signature quote :D
Nice results!
You should really quote whoever you're talking to :p who were you talking to? Lol
Sent from my iOS EcoSystem
Drove it to the motor ractors to get some DOT4 fluid to top up the clutch reservoir on the MX5 so I could get it to the garage when the slave cylinder gave way. Then used it to get me into work...
Just changed it! :p
Did nothing, just admired it any time I passed by.......
Got my pesky cigarette lighter working.
Washed it after coming back from Knockhill and getting it covered in s....
My weekend job.
Inlet blanked
Oil catch tank and filter
Finished
Not really, I think I've got the hang of this forum lark by now! Quotes aren't generally required unless you're multi-quoting or are referring to a post further up the thread.
As I wasn't doing either of those things, it referred to the post directly above mine.
Carlack 68, what's it like? Use rainx myself and been recommended mer stuff but was awful, really difficult to get off.
Sent from my HTC Desire S using Tapatalk 2
Sorry for the delay in replying, the Carlack glass treatment package (cleaner, which can be a bugger to get off if you leave it on for too long) and then repellant is great stuff, performs much better and lasts much longer that Rain-X.
Car serviced , all filters including fuel too
failing to get my bluetooth to work with the bloody phone *grumble*
You sure it's got a Bluetooth module fitted? ;)
Yeah! it seems to find my phone and then says it's not compatible.. grr!
Pressure washed all the sheep muck off it after staying at a farm cottage in North Wales. The drive up to it appeared to be the the place all the sheep went to deposit their second-hand grass - the fields were pristine 'cos it was all on the drive! - and then it all transferred onto my wheels and arches. The tyres were still green when I got home :( On a positive note that Bilberry wheel cleaner is good stuff :)
Took (some) of it to bits to fit my sub and headunit, only for the heavens to open. Plan adandoned until tomorrow.
Sent it to the garage to fix speakers and parktronic :sweat:
Put a coat of Meguiars Gold class paste wax on :happy:
Bought a black rubber protector strip for Roomster back bumper. Fun fitting begins tomorrow.
Done, in about 15 minutes (including 'thinking time'). There are templates to aid positioning which you can order separately but I didn't bother.
Guest
