The LED Lights Thread...
Hi!
I have just installed my LED intrior lights in my Roomster 2008.
The problem is that when I lock my car the lights are still glowing a little even if the engine is off.
Why?
Will this drain my battery or do any damage?
My bulbs:
http://www.ebay.com/...=item415d2c2376
http://cgi.ebay.com/...=item1e64fcae69
.....i just changed my 2 interior side and middle one too and i am getting this problem but only on the middle one the side ones go off, should i look for a new middle one??????????
These are the ones i got:
http://www.ebay.co.uk/itm/330449638336?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.co.uk/itm/270764914173?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Edited by john123
  • Replies 305
  • Views 53.4k
  • Visibility is poor. Can't see a thing  :think:
  • To me the Mtec looks like a typical blue light emitting bulb which will perform worse than the original.   Surely first and foremost, brighter with better visibility should be the aim.
  • This is what I've got installed:-   Main interior light 44mm Festoon: http://www.ebay.co.uk/itm/271006347961?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649   Map readers X 2 and side light
The ones for the rear light interior are the first one and in the middle of the fronts, the rear comfort light ones are slightly shorter
Anyone got a guide on how to get the front sidelight bulbs in the headlights to go on with the VRS?
.......but is the glowing issue a led issue or a car issue???????????...........and i tend to not get all 3 glowing only the middle one, will posta a pic tomorrow.
Edited by john123
Because LED need only a fraction of the power of an incandescent filament bulb.
The circuit already has a small current running through it and the LED bulb can be partially lit by this current.
Getting a 'true' canbus bulb with a 12v resistance built in is VERY few and far between.
Even the ones that say they do, tend to always have a disclaimer that not all cars are covered, then offer a refund.
Been there and done it. :think:
Replaced my Rear Numberplate bulbs a few days ago - already had some bulbs for these from my last car
Just ordered the interior w5w bulbs for the map/reading lights - will post some pics when i get them and they are all installed :)
Paul
....Thanks Jonny boy you are right after googling this problem..... its seems to be everywhere out there ...seems not to be a big issue whith batteri drainage though...... so can live with it :happy: :happy: .......as the leds light realy nice up comparing to the halogen oem ones..........
Nice one marTTyn..I ordered the interior led's as per the ebay links (or similar) Good and cheap little mod with useful results !!
Lads, will this work with a MONTE CARLO.? Looks sweet as.
Yes all the same
Would someone in the know be kind enough to list the bulb requirements for all interior lights of the Fabia II please? (The requirements that would allow anyone to know which sized led replacements to get.)
I've not even picked mine up yet, but if the bulbs were here by Friday that would be convenient...  :happy:
IIRC The main interior festoon is 36-38mm, the outer lamps and glovebox are both 501s / W5Ws
Thank you
I don't understand why there's no aftermarket LED rear light units been produced for the Mk2 Fabia by now ?
There are and you don't have to check China for it...:)
Black LEDs:
http://allegro.pl/lampy-tyl-skoda-fabia-2-06-led-tube-czarne-tuning-i3524453012.html
Or Standard Look Like ones:
http://allegro.pl/lampy-diodowe-skoda-fabia-ii-07-red-white-led-bar-i3537133787.html
Works out about £210.00/215.00 for the pair...
If someone's interested I'm more than happy to help with the buying these. I'm going to Poland on the 4th of October, back to England on the 8th and can bring some back with me...
:rock:  :rock: :rock:  :rock:  :rock:  :rock:  :rock:
There are and you don't have to check China for it... :)
Black LEDs:
Love the black LEDs  :happy:
I assume that they don't interfere with the canbus on the car then?
Nope as you'll need to repalce the shole unit inc the wires:
The breakdown adn the picture is below:
Side lights: LED-LED bar
Stop lights: LED
Fog lights: Bulb
Reversing lamp: Bulb
Indicator lights: LED
These units are EU Road Approved with the E Certificate.
If someone is interested I'm more than happy to help with buying these units.
Matty
Today my pal had put my spi vision on my rear lights, I think she had done a good job. ....
Posted Image
Posted Image
Posted Image
Posted Image
Might still save for the replacements but the difference is just great imo
Jon
Sent from my GT-N7105 using Tapatalk 4
Screenshots_2013-09-13-15-38-23_zps4d76f
Screenshots_2013-09-13-15-35-27_zps2f14f
Jon
How much and where did you get that from..? Fleebay..? Link if possible pretty please...:)
Matty
Is there any better place than fleebay?
It wasn't quite as easy as we thought and given the chance I may do it again some time, don't think we used enough heat when applying.
Still pleasing results!
http://pages.ebay.com/link/?nav=item.view&id=200806668933
Edited by jonro2009
www.flyeyeskit.co.uk
Didn't tinting rear lights go out in the 80's?
Give me brighter rear lights over the Knightrider look any day of the week.
I'm an 80s kid :p
I had clear lights on my silver vauxhall, looked great and on my red/black monte clear is not better. went for tinting as it is the cheaper option and if I didn't like it is easy to reverse.
Luckily, I like it so it stays. ..... for now. The front lights are smoked with the DE module so ive gone for matching at the back. ..you're not a fan then?
Can anyone help me?
i want to put white headlight bulbs on my monte.. as in really strong, can anyone link me to some?
and i would like to change the interior ones to red.. i just don't know what ones i can use?
A lot of people use Osram Nightbreakers for their headlights.
The interior lights are a 43mm festoon bulb and 2 of the W5W bulbs for the map lights. Make sure you get the short stubby W5W bulbs or the dome won't go back on.
If you're putting better headlights in don't forget to upgrade the side lights too or they may look yellow in comparison. They are also W5W.
I will link some examples for you.
