The LED Lights Thread...
  • Replies 305
  • Views 53.4k
  • Visibility is poor. Can't see a thing  :think:
  • To me the Mtec looks like a typical blue light emitting bulb which will perform worse than the original.   Surely first and foremost, brighter with better visibility should be the aim.
  • This is what I've got installed:-   Main interior light 44mm Festoon: http://www.ebay.co.uk/itm/271006347961?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649   Map readers X 2 and side light
Does that say nine pounds to deliver an LED bulb from Northampton??????
£9 for the bulb and free p&p..... pricey but it was just an example of a bulb. Saying that I do have a pair as I knew they where error free by recommendation.
As you may have seen from my other posts I tend to spend a bit on lights.
Sent from my GT-N7105 using Tapatalk 4
Nope as you'll need to repalce the shole unit inc the wires:
The breakdown adn the picture is below:
Side lights: LED-LED bar
Stop lights: LED
Fog lights: Bulb
Reversing lamp: Bulb
Indicator lights: LED
These units are EU Road Approved with the E Certificate.
If someone is interested I'm more than happy to help with buying these units.
Matty
Waste of time these. I contacted the seller and they're for the 'European community' (fog on left)
Obviously the UK's not included  :finger:
I was only trying to help mate...didn't know these were only for the European Community and that fog lights are on the left...
Brilliant use of the UKIP emoticon Jonny Boy :)
I'm not venturing into my External Lights yet!! (might do the DRL's and possibly the Fogs next year!).
But as the Internal lights ain't monitored by the CANBUS, I've just purchased:
http://www.amazon.co.uk/gp/product/B009SZFEX6/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
and
http://www.amazon.co.uk/gp/product/B004W7O1WK/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
to do my internal lights  :)
Plus I've just found these: http://www.amazon.co.uk/29-40mm-Spring-Interior-Festoon-Adapter/dp/B00B2ZC686/ref=sr_1_9?ie=UTF8&qid=1381329100&sr=8-9&keywords=FESTOON+ADAPTOR so I can put a pair of these: http://www.amazon.co.uk/WMA-Flexible-BLUE-Strip-Light/dp/B005MX2ECC/ref=wl_it_dp_o_pd_nS_nC?ie=UTF8&colid=ETQ4LPK64M9P&coliid=I2RO0ZBAN8HHOD in the Boot of my GL-II Estate without much fuss!!  B)
I'll get some Pics up once done!!
Edited by Simoneale1973
Is it a festoon bulb in the boot of the estate? In the hatch it's a W5W.
Some good prices on Amazon there, I don't tend to look on Amazon but I will from now on!
Dunno... I've not had a look... I just assumed as it's an interior light!! There's always these :D
http://www.amazon.co.uk/Truck-Auto-Light-Harness-Adapter/dp/B00B2ZC5MI/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1381385946&sr=1-2-catcorr&keywords=w5w+bulb+adaptor
Both sets my Bulbs for my interior light have been shipped!! :rock:
Don't need them right now but I've saved them so I can buy them when I embark on the next project.
Better late than never :
Edited by Confide
hi
ive got a 13plate roomster and really want to fit some leds inside and on the numberplate.
ive read that many of the leds fitted inside continue to run even if the ignition is off and the car is locked, are there any bulbls out there that have enough resistance for this not to happen??? and does this problem extend to the numberplate leds??
really keen to get some answers cause its a brilliant effect and if i can get around the problem il definately be going for this mod.
cheers
ruairidh
hi
cheers
ruairidh
The residual current on the number plate lights doesn't happen on my car. In all honesty though, the bulb failure warning light on the dash is the issue  :wonder:
Teeny Mod to my car: (took 2 weeks from China via Amazon)
Should make it easier to plug all my stuff in at 5am now it's very dark in the mornings!
Plus as the rest of the Dash is White LED's I thought it only fitting!
thanks for the advice jhonny, might get some of these for the plate, were yours canbus free ones? if they were im suprised you are getting a warning light on the dash. :sweat:
simon ur interior lights look great keep me posted as to whether you too develop this residual current glow or not.
I hope not!. The w5w's were marked 'CanBus' (I know the interior lights are not monitored!) and had an array of Diodes and Resistors all over them!, the Festoon was just a 4x LED 42mm non canbus.
I'll keep you posted!..
I must say the w5w's weren't the easiest to fit when you have mahoosive meat-hooks with Chipolata fingers for hands!, I managed to squish one of the contacts, and had to straighten it!, which involved a pen knife, torch and a lot of swearing!!  :doh:
Now to raid my Piggybank, and pluck up the courage to do the DRL's, Fogs, Sides and possibly the H7's, though I might just get a pair of Nightbreakers in there!! Oh and some Silver Indicators!!  ;)
Does anyone know 'exactly' how the Front lights on a 2013 Greenline (and some of the other new models) work?? there's only one 'w5w' and one 'H7' in each unit, plus a mahoosive lens thing!! I believe the Lens thing is the 'dipped beam' but where does it get it's light source from?? is it some sort of Sorcery or Alien technology??  :think:
It's a mechanical shutter system that cuts out part of the beam for dip and opens up fully for high beam.
worst system in the world! Projector lens good.....shutter bad!
I still don't understand how the reflector is illuminated (dipped beam) when the H7 is not (main beam only)
I can see the Side light (innermost) the H7 (central) and then the reflector with the Indicator above. it's the black arts I tells ye!!
I'm not sure but here goes.
The lens under the indicator is a projector, this is your dipped beam. H7 bulb.
The bulb in the reflector housing is also an H7 and is the main beam.
You do not have the DE module housing so therefore no shutter system.
If you could post another picture showing the whole unit as the inner part is not so clear.
Happy to be corrected if I'm wrong.
So I have 2x H7 bulbs in each unit??
But the Brochure say's the 2013 Greenline II has a 'Halogen Projector Headlights with DE Module'  :wonder:
I'll have a look over the weekend, and probly get some more/better pictures up. Then I just need to decide which Bulbs to upgrade to LED's :D
From what I can see there is an H7 bulb under a w5w bulb to the right as you look at that picture, is that right? If so then you have another H7 behind the projector lens.
Easy test, turn on your dipped and the projector lens (on the outside under the indicator) should be lit. Then flick main beam on and the bulb in the reflector lens should also illuminate.
2xH7 is my guess
Yep that's what I saw yesterday (then I couldn't see anything for about an hour!)
So 2 packs of Nightbreakers on the order form!! Along with the Silver Indicators, 2x 1156-CREE DRL's and a set of H8 LED Fogs :)
Where did I put my Piggy Bank??
