Rob's 2004 Octavia vRS
lol good stuff i might get on it,pics of you wearing it needed :giggle: if it turns up :giggle:
  • Replies 767
  • Views 99.7k
  • On our way to the Cannonball Run
  • One last drive...
  • RobClubley
    RobClubley
    Tried out my new Chemical Guys Black Light polish. I recommend it!! I'm very happy with the results. It was easy to apply and buff off. After leaving for 15 minutes I expected it to be difficult to sh
Had to take the headlight out to get to the MAP sensor, because for some reason the wire runs through the middle of the fuel rail!
Rob,
Awesome work my friend!!
Craig
Good luck with the hybrid.
Hope you sort out the diff.
Bit more done.
Still to do:
Fill oil
Catch can - mount and pipework
Intercooler pipes - fit and tighten joints
Fuel pump swap
Install new map.
Clean.
rob seening as your a mod please can you close this thread?
it makes me jealous :giggle: :giggle: :giggle: :giggle: :giggle:
Hi Rob,
Is it possible to tell wish paint you used for your front grill ?
Type and color. :)
Hi Rob,
Type and color. :)
It's just semi-gloss black in a rattle can from the DIY shop. Nothing special.
Catch can refitted. Not where I planned but it wasn't going to work where I wanted it.
Happy with it here though.
Fuel pump swapped. Easier than expected.
Engine bay done for now.
Just need to upload the map and test!
Rob,
Coming along great i see!.... Bet you cant wait for the first test run :devil: ..... mwaahhhh.
You got any links to DIY info for fittng a catch can at all?....
Cheers Craig
It moves!
Pop pop!
Some fixing to do.
Doesn't sound to healthy at first is that leaking at the dp ?
Gonna be quick ;-)
Gonna be quick ;-)
Yeah it is. I'm over laying under the car for now, going to take it to a garage with a ramp on Monday and get it sorted.
sounds like mine did with 3 studs lol i know how that feels :sweat: engine bay looks bang on :rofl:
Very tastey looking car, May i ask the first thing you did to get rid of all the grease in the Bay, Steam wash?, ....??????
It has never got that greasy. I've only ever used damp cloths or dry cloths to dust it down.
Nice.
Dropped it at my favourite independent garage today so they can get the exhaust sorted. No weird codes, nothing disconnected so I'm hoping it's just the downpipe gasket leaking and causing the weird running.
Exhaust is sorted. There was a pinhole near the O2 sensor but my joints were okay. Must have been spilled liquids evaporating off that I thought was a leak.
I tested it a bit today, made the turbo glow in the dark:
Goes like a rocket in first, not quite right in other gears.
Seems to be running lean and does lots of popping on lift-off.
This was more for noise than anything, it picked up the popping at the end.
Silly question rob but have you had it mapped to your setup ?
And have you logged it to check ??
Yes - Got an ECU with the kit with an R-Tech map, which I sent to Ben at Shark, and he has used it as the basis for an STS map.
I thought I was logging yesterday but I managed to just save a snapshot of values when idling - will work that one out :D
Working with Ben on refining it, at great distance :D
