4x4 Turbo - Sleeper-ish :o)
Hi All,
Well 4 boxes arrived this morning......
Heres a sneaky picture of whats inside :peek:
Comments ???
Cheers Craig
  • Replies 319
  • Views 51.9k
  • Hi All, Just a quick photo of the Wagon looking guilty........... :think: Craig..
  • Hi All,   Well unfortunately the skoda did sell and went to a local VAG guy not far from me whom has already fitted Audi S3 leather and Brembo BBK......   Im going to be working away in Norway alo
  • Hi All, Well i have finished of the coilovers! and its low low low!...... The front bumper is only 2.5" of the ground which may cause problems in my area due to bloody speed humps so tomorrow night g
:drunk: very nice not for me but nice!!
Wheels are different from the norm, good choice! Was the wheel alignment expensive at Revoloution? I've tried getting a price in the past and no joy from them.
£90 + VAT
£90 + VAT
That's not bad, I'll put it on the ever growing list.
Well this morning I decided to test fit one of the new wheels....
A little closer inspection....
So I will be ordering a set of 15mm spacers with new bolts etc...
Should look pretty cool once there all fitted.
Craig
15mm over-kill imho
Use a 8mm hubcentric
Personally I'd go for H&R
15mm over-kill imho
Do you think that £60 is for a pair or all four??
No, thats for two + longer wheels bolts
The H&R in a double-side hub-centric - eg you still get an external locating ring to aid fitting the wheel
The cheaper ones (FK etc) are flat faced, making fitting wheels not as actuate or easy
Iv just had another measure up and your right.... 15mm will be OTT and stick out to far.
Those 8mm ones should give a safe amount of calliper and shock clearance but not look to sticky outie so to speak lol.
Hey All,
Fitted the mesh in the lower bumper vent and sprayed it black...
New piece of black silicone tube from the MAF to the induction pipe.... loads better than the cheap blue one i got with the kit.
BEFORE
AFTER
Craig
One rear Neuspeed ARB delivered this morning..... Cheers Clive (CNTUNING).
This will be off for shot blasting and a fresh coat of paint this week before fitting.
Craig
Cool it arrived ;-)
Hey All,
Some advise please..
My current Audi TT wheels are 17" x 7.5" et32 and running 215/45/17 rubber.
My new wheels are 17" x 7.5 et35.
My plan is to just swap over my current tyres to the new wheels as they have only covered 1500 miles.
"Do people think my current tyres will look suitable on my new alloys??..."
Craig
Hi All,
My spacers arrived 8mm H&R.
Got one concern though, If you notice in the picture there is no locating lip but im guessing the standard hub lip will sit through but will it be enough to locate the alloy correctly??? im guessing based on 8mm space i will have about 2mm of the original hub lip sticking through?? and if not will this cause any problems??.... help please.
Helps peeps...
Cheers Craig
That's odd
Mine look like so:
The H&R part number is 162555716
That's odd
Mine look like so:
Mine has part number 16255571.
I rang DPM and the guy said the ones like yours are £80 a pair not £60 but the only way you can tell on their web site is by the part number, The descriptions for both spacers are the same.... :wall:
A guy at work as the flat spacers on his MK2 golf 8mm also and he says enough of the standard hub lip comes through to fit correctly so i am hoping this will be the same on the Skoda other wise looks like im stuck with these..
Cheers craig
No seen those flat ones before. All the research I did before replacing my Creations Motorsports ones indicated H&R's all had the lip at 8mm
£80 is really taking the pee
Well I test fitted the spacers and what a surprise they don't allow enough of the hub lip to come through so the alloy just floats about.
Al be on the phone tomorrow to exchange them for the lipped version.
Is there anything straight forward these days??
Cheers Craig
Hi All,
My replacement spacers and bolts arrived today...Yehhhhh.
Thanks to Damian @ DPM Performance.
Will be ordering my tyres tonight and hope i might get the lot sorted and fitted over this weekend.
Also got a 3 point harness on the cheap... £12 squids.
Craig
:dance:
Hi All,
Well i did order some front bumper side vents from SuperSkoda but after 2 weeks and still no items i noticed they refunded my money.... i guess they dont have stock anymore?? i mailed but no responce??..
Anyways i then picked up these bad boys for a £5.00 and thought i would attempt my own version, I will be also painting these matt black to match the other grills / vents etc. Might cut the bumper and fit these over the weekend.
Craig
Hi All,
Well iv getting round to fitting my wheels & spacers, just need centre caps to finish off.
BEFORE
AFTER
Well what's the verdict then????.......
Cheers Craig
Ohh Bentley or Skoda? lol
Craig
Love it dude
