4x4 Turbo - Sleeper-ish :o)
Ummm it's tempting In a wild spontaneous purchase!...
But as already advised above I don't think it woud work in the real world.
I defiantly want to change the TT wheels at some point!
Craig
  • Replies 319
  • Views 51.9k
  • Hi All, Just a quick photo of the Wagon looking guilty........... :think: Craig..
  • Hi All,   Well unfortunately the skoda did sell and went to a local VAG guy not far from me whom has already fitted Audi S3 leather and Brembo BBK......   Im going to be working away in Norway alo
  • Hi All, Well i have finished of the coilovers! and its low low low!...... The front bumper is only 2.5" of the ground which may cause problems in my area due to bloody speed humps so tomorrow night g
Should of wet vaxxed those seats before install
Do they not advise against staggered set ups on 4x4 cars?
But even still without arch work I think you may struggle,I run 9.5x18 on the rear of mine with 225/35/18 but mines a hatch with the arches rolled inside and then flared out and I believe that the rear on the estate is a bit tighter for space but if your willing to do the work I'm sure it's possible
Mine rubbed at the rear with 8" wheels and 225 tyres.
Hi All,
Well hopefully this week I will get round to fitting my rear adjustable tie arms and I have 2 new track rods ends to fit also.
Then it will be off to get 4 wheel alignment / full suspension set up correctly.
On a bad note:
Yesterday I started the car up and whilst it was sitting ticking over 2 nice big blue clouds of smoke bellowed out the exhaust, I had a run out and done about 70 miles and did not smoke one bit.
I think this is going to be valve stem oil seals???.....
Cheers Craig.
Hi All,
After fitting my Golf seats i noticed the arm rest now did not match as this was the old grey colour as per the elegance seats.
So i bought some black alcantara material and had a go at recovering.
Results..... i will get it fitted later today.
Cheers Craig
O.K i quickly fitted the armrest whilst "Busy at work" lol.
It looks a million times better now...
And my new cargo net arrived from Skoda today.
Cheers Craig
Hi All,
I dropped the car off this morning to have the rear Neuspeed Tie Arms fitted as I couldn’t find the time lately, Also getting two front track rods end fitted.
Side Note: Picture for Clive…. :thumbup:
Your a legend :-)
Looks awesome buddy
Hi All,
Little update.
I got the car back after track rod ends and the Neuspeed tie arms fitted, The arms have already made a differance and stopped the back end tramlining (they arrived still set from when on Clive's car).
Im off to Revoloution in Newcastle tomorrow and having the tracking set / 4 wheels alignment / ride height set level and the rear camber set up.
I have also bought a Neuspeed rear anti roll bar from CNTUNING which should arrive next week, Cheers Clive.
Also bought an extension solid pipe to move the air filter down behind the bumper vent, This should also arrive next week.
Will update with pics soon as.
Cheers Craig
Hi All,
Little update.
Im off to Revoloution in Newcastle tomorrow and having the tracking set / 4 wheel alignment / ride height set level and the rear camber set up.
Cheers Craig
Hi All,
Little update.
Also bought an solid extension pipe to move the air filter down behind the bumper vent, This should also arrive next week.
Cheers Craig
Hi All,
Well I had all the geo setup on the car yesterday and it drives like a different car!! Can't wait to hit the track now!
Also my solid induction pipe extender came!! Try and get this fitted over the weekend.
Cheers Craig
Update,
I managed to fit the new induction pipe!, just need to cut out the n/s bumper insert to get more air through.
Craig
Hi All,
Well I cut open the n/s bumper vent but it looks a little rough, so I have ordered a proper air duct which I will modify to fit and it comes with mesh so will look loads neater I hope.
Also not to happy with the blue silicone hose from the MAF to the new pipe and its a tad to short. I have ordered a new longer piece in black to tidy the joint up.
Getting there slowly but surely ha ha.
Question: I have noticed a few Octavia's with these side vents in the front bumper, where to I get these from????
Craig
Update,
Well this morning I changed out the old crappy plastic tube that runs from the engine to the boost gauge for some decent silicone tubing.
Also iv painted the two lower vents on the bumper matt black to match my grill etc.
Before
After
Cheers Craig
looks loads better in black :happy:
There's some air feed grill inserts that you can get from superskoda :)
Hi Phil,
I came across them on the Super Skoda site last night, got them ordered!
Cheers Craig
Little update,
My TRS tow strap came so i slung this on last night, pictures are fuzzy from my iPhone sorry....
Still to arrive this week...
SuperSkoda Side vents for the front bumper.
75mm ID Silcone hose to tidy up the joint from the MAF to the new air feed pipe.
Air Duct and Mesh for the n/s lower front bumper vent.
Neuspeed rear ARB & Bushes.
Also i splashed out on something ace for the car last night............. top secret at the mo :bandit:
Cheers Craig
Hi All,
My air vent and mesh arrived, this will be cut to suit the lower n/s vent and then all sprayed black to match.
Craig
Hi. im sure the silicone joiner needs to be 70mm i/d as ive replaced that recently. Or have you got a bigger maf fitted?
Correct 70mm ID.
Luckily this was just a typo and I had actually ordered 70mm ID which slotted straight on :thumbup:
Craig
Good build thread man! Following with interest =]
Correct 70mm ID.
Craig
i thought it might of been a typo. Cars coming along nicely mate, keep it up! ;-)
