Grr666's S3 quattro.
Duly noted gentlemen.
The refurb is a few months away yet anyhow.
I'll probably change my mind 3 or 4 times before then
40th birthday is in April. :( I'll cheer myself up with the refurb then I reckon.
  • Replies 177
  • Views 15.3k
  • Only had time today for a quick clean in the end. But here she is Can't wait to get the bumper/grille/fogs sorted. :p
  • Only a mobile phone pic but here you go.
  • Well I hope you lot are satisfied, I've just been outside in the rain to get these for you all. For contrast I've re posted the front view already on here to show the differences easier. Before, wi
Better than Pasty's effort. :D
Looks evil Garry - love it!
On the lookout for replacement mirror covers so I can lose the silver earrings next. As much as I love them
a set of OE replacement silver caps will cost over £500 I kid you not.
This means there's a significant market out there for used ones so they get nicked
a lot. Some people want to make a S3 replica out of their A3. I'm doing the opposite ;)
What's more the thieves just tend to rip the whole mirror from the car so add to that the
led indicators and heated and dimming glass and motors etc and you've got an expensive repair
to pay for. I'll get some plain ones and have them sprayed to match the car.
My mates S3 mirrors got nicked loads of times and as you say they just rip the whole unit off which does loads of other dmaage including electrical wires.
He got fed up of it and each time was costing between £500 & £800 per mirror depending on what damage had been done.
Car looks fantastic BTW :rock:
I needed a speed camera/SC zone warning system as the RNSE doesn't
really accomodate this(You can apparently add them as custom POIs but there
is no audible warning so unless you were constantly watching the screen you'd
probably miss them anyway). it would be daft to have my garmin set up as
well to be warned of cameras coming up.
My mum bought me an Inforad K2 GPS based camera detector
for Christmas which arrived today. It's very simple but should give me a heads
up when I need one. I'm still very unfamiliar with the area in which I live and
it's easy to be going quicker than you think in this car. Particularly after owning a diesel
for years :/
I've just finished updating it (Free lifetime updates, sirf star 3 technology, uses pocket gps database)
I'll review it here once I've given it a whirl. :)
Sounds good. Always good to have something keeping an eye out for you :)
You going to hardwire some power in for it?
No need really, battery life is 4-5 hours, and I rarely drive anywhere
that far away but it came with a usb cigar lighter converter and still works
when plugged into that if needed. It can even find a satellite inside my house.
I took Mrs Grr out for a meal at a nice pub in the countryside last night.
18 miles each way so I thought I'd give it a tryout.
First impressions are very good, on the way I drove past a fixed camera that I
know and it gave me plenty of warning. (You can set how much warning
on the downloadable device manager, which is a nice feature)
Also, the warning is speed sensitive.To test this I deliberately approached
the (30) camera at 35 and it continued beeping and flashing until I slowed
to 30 then the light stopped flashing but remained on until I was clear
of the camera. You then get an 'all clear' beep and the light returned to static
green. I never went into an average speed zone but it spotted several
mobile camera zones on the journey which I would have otherwise been
unaware of. They use the vans round my way a lot so this is very useful.
There are 2 LEDs on the unit, and that's it, the unit itself is not much bigger
than a standard memory stick and weighs 1oz with a cap on one end which
you remove to charge/update. It plugs straight into the computer so no wires
at all. It has a small switch which can set one of 3 volume settings and a small
on off switch.
Flashing green = searching for satellite (After initial switch on it takes about
10 seconds to get a fix)
Static green = on and monitoring.
Red and 3 beeps = Approaching fixed camera. Flashing red and continued beeping
if travelling too quickly
Amber and 3 beeps = Entering mobile camera zone. Flashing amber and continued
beeping if travelling too quickly.
Green and amber and 3 beeps = Entering average speed camera zone. Flashing together
and continued beeping if going too quickly.
A very simple system to get your head around. You can set to silent via the software
but I prefer it to beep personally. I got the deluxe kit. In the box there was a uk usb
3pin adaptor, a continental usb 2 pin adaptor (Which can both be used to charge other devices too)
A dash clip (the sticky pad is a bit crap though) a cigar lighter usb converter, the device of course
and a small fitted leather pouch to keep it in. The software is downloadable directly from inforad
website and takes up just 5mb on your computer.
The best bit for me after the initial disappointment of the sticky pad failing to stick
to my dash was that I discovered that it fits perfectly between and slightly under
the two buttons protruding from the face of my dash pod. It doesn't move at all
(I tried ;) ) from there and puts the display right in front of your face. Also it doesn't
obscure the DIS at all. The cowl should also provide some shade in bright sunlight
which after reading other online reviews seemed to be the main complaint about
the unit.
But luckily it's almost made to measure for this spot on my car and very discreet there.
It functions perfectly from this position so the bracket will be going in my van.
(after I put some decent tape on it)
I'll add some pics when I get the chance. But to sum up for the £40 odd quid it cost
I will certainly be getting one for Mrs G as it's very easy to use and works well.
(She also has a factory usb port in her Fiat so she could leave it plugged in
permanently if she wanted) It's definitely better than setting up the sat nav just
to warn of cameras.
Good write up and made me check them out on the web. Only £32.49 via Amazon, though not very helpful with telling you what's in the box. I would assume it's going to have what you mention above though. :thumbup:
I've got one of them k2 detectors. Good little thing for the money really and got me out a few potential tickets with my awareness!
I have the deluxe kit, It comes with all the accessories mentioned above
http://www.ebay.co.uk/itm/Inforad-K2-DELUXE-GPS-Speed-Camera-Detection-/181053330851?pt=UK_In_Car_Technology&hash=item2a279e95a3
but I think you can just buy the basic unit too. The link here is to buy direct
from the manufacturer which is where my Mum ordered mine from.
£39.99 plus £2.99 postage for the full kit or £34.99inclusive for the basic pack.
They sell the accessories separately but they charge a tenner for the
leather case alone, in my book it's worth the extra £8 for all the
extras. 2 year warranty if bought from inforad directly as well :)
Cheers Grr. :)
The Amazon one is most likely just the basic then. :thumbup:
Fantastic looking motor!
Fan washer jets on order.
(Can't believe they aren't this type already, cheapskates.)
Got triple single jets either side and one is blocked up so
I have 3 squirters on the left and just 2 on the right.
(Sounds like a dodgy porno film lol )
Hopefully the wirings there already as the new ones are heated too.
Great little mod mate
Got to love a good squirter! :D
Where did you get the fan type jets from? Will change the ones on SWMBO'S A3.
Let me check they fit first, they aren't really for a A3 type car.
If they go on okay I'll post the link, they are bought on the advice of
others via Audi sport and I don't want you to waste your money if
they are the wrong type.
But to answer your question... Ebay. £24 for the pair delivered
How much???
I replaced both of them on my Fabia and it come to a total of £2 something
I suppose anything Audi is 10x the price?
How much???
They won't be heated though, although I dont know if they
are on mine until I get the old ones off.
They are off of a Passat actually.
But I take your point, for example a new mirror glass is 200 quid.
I was under the impression that the Fabia's jets were heated too?
Could be wrong though!
Nope. Was an option in some countries, but not here.
Just extend the washer fluid hose and wrap it round a coolant one a few times.
Always worked for me in Land Rovers.
Bonus is the warm water cleans the screen better too. :)
So, she's in having the MOT, a bit of a pricey one this year.
Turns out there was a broken coil spring drivers side rear.
I had noticed it wasn't sitting level but put that down to my drive
not being level. Asked my indy to investigate before testing the car.
It's in a week before the current cert expires.
Two new OE rear springs and fitting coming in at about £320,
add to that 4 new Pilot sport 3's at £110 each plus fitting.
There's a chunk out of one of the front tyres on the car and
the two rears are on the wear indicators (as they were when I bought
the car) = a full set needed in my book...
Also, the front brake pads are 90% worn and are the ones it
left the factory with, so about 50k on them.
A replacement set of genuine Audi ones add another
£80 plus fitting to the bill. And finally the mirror covers,
£50 for the respray plus removal of the brushed alu S3 ones
and refitting of the black ones.
So total spend will be just over a grand, there goes my remap :(
No further mods planned until my wallet recovers from this lot...
Pics of the car with the new mirror covers when I get it back.
I also owe you guys a pic of my speed camera detector in position.
I expect it will still be a wheel refurb and retro fitted cruise
next. Birthdays coming up ;)
Quite a few bits to do, but the prices don't sound that bad.
It is a hot hatch with over 200bhp after all.
Your first post says it's got Audi MOT cover. You've only had it five months.
You shouldn't have to pay for the springs then...
