List of VCDS Owners (Previously known as VAG-COM) & VCP Owners
I am in Wiltshire close to Pewsey, not sure if that is any better but happy to help
John
  • Replies 136
  • Views 121.6k
  • @Gizmo Could you add me to the list? I’ve HEX-V2 and based in Carrickfergus, Northern Ireland.
  • It seems that the Wild West of England isn't very well represented here so I'll add myself to the list being in Newquay on the North coast of Cornwall.    I have Hex Can.
  • Welsh_kai_boy
    Welsh_kai_boy
    As already stated by Mike we do not advocate the use of counterfeit VCDS cables which put other peoples cars at risk. We don't mind if you break your own
Is there anyone in the South central area (Oxford - Winchester corridor), who could change the region on my Superb II to Australia and enable the digital speedo in the Maxidot display?
Cheers,
Greg
Anyone In bristol?
Any one from midlands can clear epc light as fitted new aucator
No longer in Bangor north Wales   moved to Rhyl north wales  and now have Hex-V2
anyone in oxfordshire area able to work on my octy mk2 please
On 15/01/2013 at 14:14, Gizmo said:
Golfman
Hi would you be able to help me with my kufatec fiscon  stereo on my octavia been told I need it plugged into a VCDS to get it back to standard Bluetooth
Have you tried PMing someone close to you on the map? You usually get a far better response.
Again Golfman is unlikely to see this, PM him directly
If you want to contact a member for help with VCDS please either hover over their username, a window will appear with “Send message” either click on this or click on their username and the hyper-link will take you to their profile, from there you can send them a PM.
Before you send a message look at the ‘Last Active’ date, if the member has not visited Briskoda for several months then it will be unlikely that they will reply to your PM, in this instance try another local member.
It is also worth satisfying yourself that the VCDS owner has sufficient knowledge and experience before they make any changes to your car and what costs are involved, some will do it for free, others will ask for ‘a drink’ and there are a few that offer this as part of their job so will have a set fee.
How do i do that?
3 hours ago, Gizmo said:
Doesn't do anything when I click on his name
Do we have anyone arround Birmingham ?
Look at the map...
36 minutes ago, wg100 said:
Look at the map...
Yeah, I checked it, but that member not active since 2006.
You might need to look a bit further afield in that case.
Bmbmdmb
Hex v2 purchased 2019 nov
Location
S63
Barnsley / Doncaster area
Experience - little at present
Good morning all, could l be added to the list please .
I have the hex v2 lead and live in the ruislip area of north west london
Have been using vcds since about 2006 when l had an hex can lead.
Many thanks
Mmm
I may also be added to map. Clearest location would be Tallinn, Estonia. Own HEX-V2 cable.
Hi I have Hexnet v2 VCDS and have just ordered Vag Can Pro. I am in South Lincolnshire / Peterbrough area if you like to add me to the list.
HEX-V2 in Bettyhill, Scotland KW14 7SZ
Just wanted to say thank you to @rover220 today for helping me out coding my reverse camera to my car. He didn’t want anything for  helping and was really nice and helpful. Also has cracking taste in old rovers too. Once again thank you, and thanks for not laughing too much at my dodgy wiring, which turned out to be okay apart from a dodgy rca connector 👍 kindest regards
No problem, happy to help where I can.
hi, i'd like to ask what is the difference between vcds v20.4.1 and 20.4.2 ?
