Brake caliper carriers for 288mm->312mm upgrade Octavia Golf Leon
These are the most wanted caliper carries for front 288mm to 312mm ATE brake upgrades in Golf , mk5, Octavia mk2, Leon mk2, Passat B6, Audi etc..
In most cases all you need to do the upgrade are new 312mm discs and caliper carriers (you can still use your old calipers)
£80 delivered a pair
(I do also have the rear carriers available to upgrade from 255/260mm to 282mm)
They have been sand blasted and powder coated in red as you can see in the picture
(there might be some small paint chips here and there from handling and shipping)
they are identical and fit both sides
The calipers fitting them have numbers 581 and 582 printed on them but there can be some other compatible out there depend on the vehicle make/model most likely any 288mm brake calipers will fit just fine) .
here is how one of the compatible calipers looks like:
Compatible part numbers:
3C0 615 125 passat B6
1K0 615 125C leon mk2
1K0 615 125E octavia mk2 RS
5N0 615 125A octavia mk2 RS
5N0 615 125 superb a3 golf
The carriers you are about to replace should have number 801 printed on them.
the distance between the fixing holes on your hub should be around 145mm
Edited by XMANTURBOS
will I be able to use this with ma 280mm calipers?? will post a photo of ma caliper I think its ATE..and how much
u haven't mentioned any pricing
Which cars have 252mm rear brakes?
  • 4 months later...
bump
  • 2 months later...
Are these the same carriers needed to fit my mk2 fabia? Same front setup at MK4 golf with 288mm discs
Are the calipers with 582 on from the 288mm setup or the 312mm
I have a 140 Golf GT TDI and wanted the bigger calipers like on the 170/GTI
Tanks
  • 7 months later...
Are the carriers still available? Wanting to do the 312mm conversion on the Yeti, cash waiting :)
Brilliant.
Any idea what partno is the rear caliper carrier for 282mm rotors please?
Is there a way of identifying thet the rear caliper is interchangeable with 255m / 282mm rears?
Thank you
  • 2 months later...
Hi, do you have any calliper carriers for the Yeti rear brakes? It currently has 255mm discs and would like to fit 282mm.
Hi,
I need a pair of carriers for my fabia, i have mk1 octavia vrs brakes fitted, can you help?
Dave.
  • 4 months later...
Hi, do you still have calliper carriers available?
  • 2 months later...
Hi I have a 2003 1.8 vrs without looking do,you know if mine has the fixed carriers or is mine the simple upgrade,thanks
  • 3 months later...
up
How much for the 312 carriers posted to Ireland?
Edited by countryboyhaha
  • 3 months later...
more available
Anymore available?
Interested in a front pair of you have?
What do I have on my octy mk2 vrs? Definitely need bigger ones
All sorted now thanks.
XMANTURBOS, on 26 May 2016 - 12:03, said:
more available
Is that still true, as I would like a pair for my estate (see left for details)?
I want a front and rear set if they are available, don't need them powder coating red though
PS to my earlier post - it is the front ones that I need, to go from 288 to 312mm disks.
Done some searching on ebay, and this supplier did list them there at some time, but has now withdrawn the ad - so I think he does not have these calliper carriers anymore.
Edited by jeallen01
It's ok found a pair for 50 anyway
