Rear view camera
Hello, i am new to this marvelous forum and deeply impressed with the knowledge here. :hi:
I have a 2011 yeti with Columbus navigation, parkingsensors front and back and parkassist. But it would be nice to have a rear view camera as well. Much easier to attach a trailer and so on...
Does anybody know if a camera from a Golf 2012 with the partnumber: 5N0 827 566 J will fit in thee same hole as the existing handle??
As far as i understand i must have a camera with RGB output to connect it directly to my Columbus. But what kind of cable do i have to get?? car-systems.pl have a complete kit for the Passat-Golf and one for Tiguan-Touran it looks exactly the same but different numbers??
What should i get for my Yeti to have RVC :rofl:
Out of interest, do you still get the ops graphic on screen as well?
No idea, sorry, but maybe the question might be better in the ICE section?
Yes i still have the OPS graphic (the little yeti with graphics in front and rear) the parkassist only show graphics in the maxidot.
Sorry. Didn't make myself clear.
Do you get the ops graphic with the rear view camera as well?
I know about without camera, as had my Yeti for over 2 1/2 years :lol:
Aha  :giggle:
I assume it would look something this.
Reversing-camera-Optional-RNS-510-Naviga
Probably without the lines as it´s the "low" kind that connects directly to the Columbus.
Aha :giggle:
Posted Image
Looks good.
A mod to be done if I keep the car.
Looks good.
And hopefully and easy mod for Škoda to add to the facelift Yeti.
Hi, I looked at the camera you've shown when I was planning my RVC fit (http://www.briskoda.net/forums/topic/279218-reversing-camera-on-amundsen-plus/) it will not fit the yeti without cutting a larger hole than the existing boot release. The fitting I used will also work with a Columbus so I hope the way I ended up fitting a camera (after writing to all those selling different fittings boot release and number plate mount and finding that none would fit correctly).
One other point that may help, the graphics shown on the screen are generated in the RGB camera, not in the head unit, in the case of my camera you can choose to have the lines on and off. I believe that these are known as 'low line' fittings, the graphics do not move. The one shown above is a 'high line' fitting where the graphics are generated in the head unit and are tied into the steering so the lines curve as you turn the steering. The Amundsen+ (RNS 315)  definitely does not support this not sure about the Columbus  (RNS 510) but it will definitely work in low line.
Mark
