Citigo steering problem
Rule 252 in the UK Highway Code:
Parking on hills. If you park on a hill you should
Park close to the kerb and apply the handbrake firmly
Select a forward gear and turn your steering wheel away from the kerb when facing uphill
Select reverse gear and turn your steering wheel towards the kerb when facing downhill
Use 'park' if your car has an automatic gearbox
This suggests that drivers 'should' turn the wheels when parking.
  • Replies 55
  • Views 15.2k
  • Very interesting article in today's Auto Express.  I hope there's not a problem with posting this scan of the particular page in question, on here?  Thank you to Auto Express for this article and than
  • Thanks for the update   Glad they are treating it as a serious issue and not just fobbing you off   Keep us informed   Cheers   Damo
UPDATE..........
Nothing
Maybe there is a difference between turning your wheels to the side and leaving them on/near full lock. Several makes of car have had problems with leaving the steering on/near full lock. Which has caused sensor failures and leaking seals?
I wonder why? I can't understand.
If the hand brake fails the car will roll towards the kerb rather than rolling down the hill?
Of Course. I meant those gears. It doesn't make sense. Those will turn the engine wrong direction. Though it doesn't blow the engine right away, it still doesn't make sense. Do they think that engine cannot turn wrong direction? It surely can, and it's not good.
Edited by Emil
