Remap without rolling road...
Just had my car booked in for timing belt and water pump (£336 all in, not too bad I don't think), and they also offered me a remap too, I asked if they did a rolling road and said no, they also said outright that I would get 50bhp increase. Now I know that most people with a stage one map on here see roughly an extra 30bhp, What do you think? I think a rolling road would be better as they can see the power and how it's being deployed and smooth it out, am I right in thinking this?
You don't need a rolling road to have a remap, all it will do is show you the output on a more accurate scale. You will feel the difference once the map is applied on a normal road.
  • You can have a remap without a RR but it is likely to be a generic plug and play jobby.
    They plug in, chance the map on the ECU - bosh, you drive away
    I had that done on my old PD130 Ibiza
  • You can get a plug & play remap with a RR
    they'd probably run on the RR before and after the remap to show you the differnet figures and curves
  • or you can get a custom map on a RR
    they'll run before and after and then carry out any tweaks to the map, to smooth delivery/limit torque, etc as requested
I'd also agree that a 50bhp increase looks a little optimistic
You are not going to get 50bhp extra without more work than just a remap, generic or custom.
Thats what I thought when I heard 50bhp. What are these plug and play maps like? I would prefer a rr before and after I think, just to know what I have! Also, would a down pipe, decat and cai be good to get before the map?
+50 Bhp is to sell you it realistically I got 33 when I had it rrd some time after but it depends what they are charging
I sent my ecu off and had it done and it was £99
I've never looked back best value for money mod ever
They can certainly take that into account but you'd be looking a more specific remap, and to be honest if you add a FMIC you'd be stage 2 ready (correct me if I'm wrong)
With just a remap you'll be happy,if you won't more(ie stage two) really you need to start looking at brake and suspension upgrades first then turbo back exhaust,intercooler and then the map....
Have a look at the Performance Upgrades section. AmD is the heading.
Dyno test is a must!
All my mapping is done "live" on the road.  I go out and run logs using VCDS, email mapper, get file, flash car, go out, run logs with VCDS whilst I monitor smoke, EGTs, boost spikes, exhaust manifold pressures and eventually you get a good map.
This reminds me, I need to flash my car with the latest map.... :D
There's nothing wrong with some mappers' plug and play maps. APR and Revo (I'm fairly sure Revo don't write custom maps) to name two offer maps at stages 1, 2, 2+, 3 and beyond with their own additional hardware.
All very fine and dandy if 'one' has VCDS!
The theory behind not needing a dyno run is all development work to write the file for stage 1-2-3 etc
This is very much more apparently on newer 2.0 TFSi TSI engines.
So is that a 'Yes' for dyno or 'No'?
Interesting stuff! Not looking for mad power, and handling will get a look in too yes. They offered it for £249, but didn't ask what brand of map it was. Seems the majority would say a rr is quite important, besides, how will I know what to say when someone asks how much power I got?!
RR is unnecessary for a stage 1.
Since they said "+50", your what to say is "180 + 50 + fudge factor" or "makin' toofifty brake eezee wif the map innit". :giggle:
and flashing cable/software. :)
Some of the very best mappers around actually only use rolling road to get base map on and then tune live on the road using live emulators and det cans ;-)
