Dip it, dip it real good!..................(a DIY wheel refurb thread)
Test wheel has begun folks, gulp. :)
Ok general boring stuff
Wheel prep was:
Snowfoam
APC
De-iron
De-tar
Wipe down with Meths, ChrisRS' idea
The wheels have some scuffs to the outer edge which I have lightly sanded, this isn't a full refurb, more a temporary job and also experiment until spring when I will have a better chance of painting
I will be applying light coats at fifteen minute intervals.
The plan is five coats gun metal, two coats metallic silver clear coat to add fleck, then final coat of pearlescent clear coat, reaching the magic eight recommended coats.
Never done this before so doing a test wheel first.
Test lab is my kitchen with all the windows open and cold beers in the fridge, pizza break around half eight seems optimum.
Let's see what happens
Couple of before snaps and the wipe down.
9CBBB632-7EB7-4C24-87D6-E5C4A3675FF2-297
66CBDA60-FEDC-47BC-BDA1-E0925DE68BFE-297
B10B85FB-7FEB-44D3-85DE-7255218B21D8-297
47868D94-12AF-4473-B10E-777B5EF88E97-297
C530A0BA-A32A-4AC9-971B-51F063A16D05-297
Fearful, already went too big on layer 1
FD5F2C1C-9501-4C88-BAC3-8B5946FAE853-297
You will note I am masking nothing as the dip in theory (thanks youtube) shouldn't stick to the tyres and can be peeled off at the end, the seats for the wheel bolts I can trim out with a craft knife.
I am only spraying through the wheel face and won't be applying to the rear of the wheel.
  • Replies 149
  • Views 15.9k
  • Beats me, I have tried on many occasions to enlighten her as to the difficulties in finding the correct canbus error free LED 42mm festoon in order to have a better lit rear number plate but she fails
  • Aaaaaaand we're done Pretty happy I replicated the original wheel, which still requires more peeling, sigh. The wheels looked really distinct until the pearl coat, it is insane the change one coat
  • I think this is finally the thread that will convert my wife to accepting that Briskoda is not in fact the nickname of my mistress - especially as my default Christmas present to "her" is a new set of
Coat two, moderate colour change. Updating as I do, will return to fill in the details later
I already think I'm making a mess of it :)
Will be adding beer to the process, see how things improve.
Bu99er, not more up dates
Looking forward to an evening in with this thread
Red wine opened
Looks a bit drippy.  Are you spraying in warm conditions?
After first two coats I have cranked up the heating in the house and am making sure the cans are a shade warmer.
Current ambient is approx 18°c and rising :p
The drip is a concern, so is the paint running :rofl:
Coat two improving as it dries
0EE81CA5-D54D-4F2B-835B-15052AFB4CB2-297
Some drips still showing but generally they all seem to be flatting out more or less ok.
Picture doesn't show the improvement as much
Please go and make little circles of tape and mask the wheel bolt seatings.
Shove some paper in if you like then some little circles of tape.
Then spray only lightly in that area.
I know you can run a Craft Knife carefully and remove the coating on the seating,
but best not to spray them, easier.
Maybe do more can shaking, do it for ages, then do some more.
george
Yep, looks like the trick is plenty of very light coats.  It might be worth warming the other wheels up with a hair dryer before you start spraying them.
Spray wheel flat on the floor
If you have a hair dryer, you could use it to warm the wheel during and after spraying.
You can also insert the wheel bolts and lock them in place with ty raps (behind the wheel).
It is very important to leave the seatings as they are. If there is a layer of paint on them, you could lose the bolts.
And if you want to remove the paint on a later date, be sure you apply lots of layers. The thicker the paint on the wheels, the better you can remove it.
That is a mistake lot of plasti dippers had after applying the dip too thin.
George, thanks for joining us, all advice very well received. Keep it coming
Light coats is the plan.
Other wheels will be tomorrow, this is a test, will warm them tomorrow.
Coal is on the fire and (for pizza) oven is on in the kitchen.
Most sources have claimed thats a no no. Just following t'internet :)
Don't want to come across as teaching grandma to such eggs but have you dipped the can in hot water for ten mins or so to compress the propellant more? Always stopped me dripping!
Going for eight coats, I'm aware of the issue, was going to remove before fitting on the car, currently looking for something to blank them though
They have been sat at safe proximity above a radiator on a shelf
Who's enjoying the near live format?
Guess   :giggle:
This work?
68a66f435ae29128744b373fb41465f1_zps24f2
george
Arm now about to fall off from can shaking :)
Oh and forgot to tape over loo roll, on it now
You can also use the bolts after dipping.
Just put them in and turn them (preferably with a power tool).
I would have put some bolts in the holes and, as written before, lock them in place on the back with ty raps or something similar. (before dipping)
is the wheel standing up ?
Gravity maybe your "run" enemy, lie her down !
Can in moderately hot water will also speed drying time up
6a11fb4d577398716265b5dfc6e96fd5_zpsfee0
Coat three just on wet there, lighting not aiding ipad photography.
Oh and apparently I can't even manage to cut circles in masking tape, does not bode well people
More shaking equalled better spraying that time
Sadly the bolts I have are holding my summer wheels in place.......on my car :rofl:
Again, the Internet said do it like this, and who am I to disagree.
For anyone interested, check out Fonzi on dipyourcar youtube channel. Hero!
IMHO it is so because you can hold the can up straight. Then it sprays better and you get less drips from the can.
And if the layers are thin enough the paint wont run.
