Octavia mk2 canbus lines
Hi!
I'm looking for can bus lines (CAN H and CAN L)in Octavia 2009. I would like to connect GPS tracker.
I know, I should take a look on Can Gateway module - blue connector near pedals but there are a lot of PINs and cables.
I need informations which PIN is Can L and Can H.
Could you help me?
Regards,
Damian
Mike, from CAN I need informations about fuel consumption and fuel level. I didn't know that CAN lines are at the back of the radio.
Do you have experience with this kind of connection? What data are available?
Maybe somebody have scheme of Can Gateway module (blue connector)?
Damian
That is an option if it is the infotainment CAN you need (which I guess is likely), but you would need to be sure as there are three CAN networks joined at the gateway.
If you have a Columbus see for the pin assignments: http://www.my-gti.com/529/volkswagen-rns-510-pin-assignments.
Adam
