Fitted LED strip 'Puddle lights' to the front doors
Fitted LED strip Puddle lights to each front door
Wired them to the door lights...10 minutes each door in total...Very easy:
1. Cleaned the plastic trim under the door cards with Alcohol.
2. Drilled a small hole
3. Stuck on the LED strip (3M Tape on the back of them) and pushed the wires through
4. Connected the wires to the block connector with scotch locks and put the door light unit back in.
Very happy with the result
Pictures:    (Sorry..not great on the iPad)
Sounds good Chris :thumbup:
Chris
Could you provide and idiot's guide to wiring these into the door lights pls - also what are scotch locks?
Looks good chris, I was only thinking tonight when I got out of mine what a good idea they are but they are not very bright.
So easy to do and very cheap too
just ordered a set, re wiring is it just red to red and then the other two connected?
thanks
Yes. Red to red
Thats looks really good,looks a good cheap mod too! may have to order a set.  :thumbup:
Edit......set ordered!  :rofl:
Edited by mikey vrs
Have you done the back ones as well Chris?
Not yet
Now I know how easy the front ones were..I may well
Can someone tell me what wire is best to use for this? Is it any twin wire or does it have to be a certain type?
Edited by Th3Grinch
Use the existing wire..I didnt use any extra..
You need small scotchlocks though
I dont have the wire, no courtesy lights so i plan to run right up to interior light. Just not sure what wire to use.
If you use the same thickness wire as the LED's...........thats the same thickness of my Door lights' wire
Its a tidy little mod guys - well worth the effort.  A few of points to note:-
1. when purchasing led strips - try and get the black pcb type so it blends in with the door plastic.
2. type shown in the link are 5050-SMD type; if you can get 5630-SMD style - they are twice as bright.
3. if you buy 75cm to 1metre lengths and run them along the bottom then round uptowards the door mirror;
they double as foowell lights when you open the doors.
The above is based on my mates version on his Mazda 6; but applies equally to this thread.   :thumbup:
Edited by samuir1974
Thanks Chris
Yes. Red to red
Thanks Chris, set on order
Thats a good mod. They are double the price now though.
Heres a set of 2 for less.
http://m.ebay.co.uk/itm/400376433883?nav=SEARCH
Got a set ordered.
I got a set of these a couple of days ago and have fitted them. Looks superb.
Don't forget pictures guys..or it never happened
Nasty connectors that connect to the existing wires by cutting through the insulation (and usually some of the existing strands of wire)
For less than £10 a door (I have just bought 4 OE lights for less than £10) you can fit OE lights... BUT they will require a hole cut into the bottom of each door panel.
OE lights?
Original equipment, the type VAG fit to models that have these as std.
