DPF Light on
New to the DPF , light has come on and book says drive in 4/5 at x revs for 15 min. Does this work and how long before the filter needs changing and what kind of cost are we talking. Also is it a MOT failure ?
  • Replies 142
  • Views 12.2k
  • No because you need to do a forced regent. Sent from my Nexus 4 using Tapatalk
  • trundlenut
    trundlenut
    Do it once, until they change the mot to include a test for the dpf performance and then buy a new one or scrap the car Sent from my Nexus 4 using Tapatalk
It does indeed work and just hope you never have to replace it as it's not a plug in filter as you seem to think.
If not sorted in the way you've been told then it can lead to bigger problems!
The DPF is part of the exhaust system. If it needs changing you wont get any change from £1000, probably have to add more to it tbh.
Following the method in the handbook does work, basically all you need to do is take it for a quick blast so the dpf can warm up enough for it to perform a regeneration.
The dpf is there mainly so you dont kick out loads of black smoke in the towns/cities. The other reason is to make money for the dealers for when they go wrong.
If the light stays on, the MOT is the least of your worries. I've seen dealer quotes of £1700 for replacement (Passat).
It will be followed by a flashing light, then your car will go into limp mode.
Hi , firstly I don't think the DPF is "a plug in filter" (by the way what is that ?) an MOT failure is the most of my worries as I need my car. So looks like a blast as per the manual should clear it and if not some £££ need to be spent , guy at work has advised some DPF additive or Redex , anyone tried that ? How long does the DPF usually last ? I'm at 128K
Hi,
could just be the G450 exhaust pressure sensor which is ~£50.
Try taking for a good run . If it doesn't cure it then get a diagnostic test done it. It may be a sensor, if it is the dpf then they are very expensive to fix. It is cheaper to have it mapped out but it is illegal..
I agree with taking it for a long run, I have read that you shouldn't thrash the engine as this gives a negative effect and can make matters worse, engine produces even more soot.
Otherwise find a friendly Briskodian with VCDS near you and see if they will scan the car and do a forced regeneration.
Regeneration never fully cleans the dpf, I believe they eventually build up to a point where they have to be replaced, I hope it is not the case here.
They're not so hopelessly doomed to fail. I have over 110,000 on my PD with a DPF and when it was scanned last year by someone with VCDS, the ash content was only at 5%. I've also never seen the light on even once.
*comes back*
They are Dunlop SP 3000A 205's.
I like them...
Confusingly the soot content is recorded as % whilst the ash content is in grams. 5g seems wrong for a car with 110k, mine has 35g after 80k odd. Maximum is 60g so I'm assuming around 150k before I have issues.
The gremlins have struck again, I was trying to respond to Huskoda.
I have VCDS so I'll plug the laptop in and see what's what. What is the max figures prior to replacement ?
60g, its measuring block 068 or around that number that tells you the ash content.
Yes, it surprised me too, but I try keep the car above 2k RPM at all times and very, very rarely sit in traffic during my commute.
Still doesn't seem right, the dpf regeneration is not 100% efficient and even with purely passive regents you would have more ash than that. Unless is what 5% soot loading at the time it was scanned.
There was some DPF work carried out some time before I bought the car, but I don't think it was a replacement. I'm sure it was a forced regen. Either way, its given me no trouble :)
Took her for a run 4th gear @ 70 mph for 10-15 mins. Light cleared !! Result.
Having scanned the car and following advice in here of going to blocks 068 and 070 and 075 I get info but nothing referring to soot/ash , only a % Lambda and a number with no reference (in 068). Are these the figures I'm looking for ?
What version of VCDS are you using?
10.6
that may be why. You should update it, unless you have a hooky version.
I think from looking its at 21.7%
On newer versions what would it be displayed as ?
You may be missing the relevant label files so the measuring blocks aren't correctly identified.
Ash content is in grams, soot in %
