Octavia MK1 - Door Lock Failed & Deadlocked!
Thanks for that, my passenger door is being temperamental at the moment, sometimes unlocking when I unlock the car and othertimes not.  I've found that holding the lever open on the inside passenger door whilst I press the unlock button on the keyfob seems to bring it back but I'm wondering how long that'll keep working!
I'm happy to have a go at anything on a car (just finished rebuilding the engine in my quattro as a first attempt at engines!) but something about door cards that I just plain dislike working with.  Probably because they're such a PITA to get off and back on as they're supposed to!
Sounds like you've got the same issue I had before it completely stopped unlocking.
Sometimes I used to be able to drive around over bumpy ground and it would unlock if I pressed the drivers convenience panel unlock button.  One day it just completely failed.
When I eventually had the door open and got the lock mech out, I re-plugged the lock mech into the electrical system and tried testing to see what the issue was.
The motor would engage the lock, but then wouldn't unlock.
So the PCB was working and the motor was semi-working.
This is the reason I had to go into great detail on how the deadlock works.  I was trying to work out where it was broken.
Maybe one of the two microswitches had failed or rusted inside, or the motor windings/bushes had degraded.   Really not sure.
It was like it was semi-broke, as it just wouldn't unlock.
Plugged the new (used) one I got off fleaBay and it worked first time, no issues.
It's still working now.
I hated removing the door inner, don't like bending it around, plus I broke a small plastic tab on the grab handle thing.
But, needs must, to get the MOT passed!
Plus, the dealers would have done it the same way, except they wouldn't have cared as much about damage.
Wow, rebuilding engines!
This is where I don't go.  Don't have the patience in the end.
Which is weird if you think about it, because I'll happily change the things that allow me to stop the car, but not the things that make it go   :think:
  • 10 months later...
This was a great help when mine dead locked,hammer ect. failed.Though I didn't use a hacksaw,I observed where the cogwheel was from your pics and drilled there with a 13mm bit and used two screwdrivers to turn the cog,took a little time,but I got there.Thanks
My door didn't work for months with the same intermittent symptoms then dead lock. It also had an EML of Lambda Sensor which never went away even when cleared. Car stood for 4 months or so dead battery. Battery pack started it recently, all doors unlocked and EML hasn't reappeared. Electrical gremlins !!!
Just hi jacking this! Anyone tried the ebay locks??? My doors are all going as well
  • 8 months later...
I just purchased an EBay special for the front drivers door. Works perfectly and for £20 posted a bargain.
Fitted a few of these now on different Octavias and have been fine so far!
Dan
Wow just come in from breaking my n/s/f door lock motor off, what a pig and im a techie (Toyota) Day off so thought i would have a go at fixing it but motor is completely pooped. I put ebay door motor into search to see if the ebay ones are any good so this will be my next port of call. Just had to dead lock the door to keep it shut until new motor arrives
Ebay ones are fine. I've fitted a few in the last couple of months. And yes a pig of a job if it's dead locked and you have to smash the old one off !
You dont need to smash the lock, just cut top open and wind the deadlock screw pin back (tricky as it wants to spring back the whole time but its possible)
Ebay locks are grand too,
Problem i had was getting the 2 spline bolts out of the actual door lock. Totally seized had to drill them out and get new ones
Cheers for advice all, fitted ebay one that was delivered within 2 days for under £20 and all works fine again..... just hope my 2010 vrs doesnt get the same problem
Phil
i have a problem with mine i had a dodgy starter motor it eventually died so i put new one on, car now starts great but when i turn the ignition the cabin light flashes once and sometimes the passenger or rear door locks by itself?? i have since had a health check on the car and they say the battery is on its way out, do you think this could be causing the problems?
Possibly. A new battery from TPS is not that expensive. Give me a shout if you need a hand as I'm in Kent too.
hi mate thats very kind of you to tell you the truth from the start the car has been a bit of a lemon [a green unlucky colour one] i had a focus before and it lasted five years even though i bought it with 120,000 on the clock, someone crashed into it so i got 700 off the insurance and went car hunting but as i didn't have a car to look for one i was in a rush [not good] my wife is slovakian and iv'e been there a few times, every other car is a skoda and plenty of octys, i heard they were reliable since vag took them over and my mate had a diesel in the uk which was lovely, i didn't specifically go out to get one but saw one advertised 4 months ago  at cross st garage gillingham for 1450 i knocked him down to 1300 cash and he said he'd put new mot on it and also change the starter motor which sounded like it was on it's last legs
when i collected the car the following day after arranging insurance i asked him about the starter to which he replied it was cleaned up and fine, it sounded fine so i drove away two weeks later the starter gave up the ghost i rang him due to it being still in warranty he said he had another that he would fit so i took it over there
it was fitted but no better than the old one? i bought a new one had it fitted and thats when the central locking started to play up i rang dealer and he agreed to refund 50 back after threatening him with trade descriptions
got my mechanic to give once over for £120 he said belts are fairly new and bearings are fine it's a good car
was driving in Sheerness and something banged on the undercarriage? i carried on driving then in evening went to herne bay, the steering failed i looked under the bonnet and power steering fluid everywhere!
towed it home through joining AA [118 quid] then mechanic looked at it saying new high pressure pipe needed due to leak near banjo joint, he said get one off ebay 28 quid all in but it was the WRONG one when sent and for the vrs
, they did however accept returns and i asked at the time if it was for all the 1.8ts which it wasn't i rang skoda main dealer they said £91 but i had other used quote from internet for £50 so i purchased that over phone, an hour later they said they took it off shelf but was damaged so they refunded £50 i called skoda again and they said they made mistake it was £191!!!  i told mechanic and he said he'd weld it, he came round following day and it turned out to be a perished rubber pipe join?? so after all that he charged £30
since that time perfomance has been woeful and a vibration on accelerator pedal and straining feeling from engine
eml went on coming back from rochester called aa who put their tester on it and it was one of the coils plugged into the spark plug that had popped up 10mm? was looking for possibe cause on google and luckily on this site i read they had recalls for this [lucky] i got in touch with skoda motorline rainham and they booked it in for last monday they said they were original so they changed them and i supplied new plugs for them to change for tenner,
they did a 'health check' and superbad news but i don't trust them completely as they are not only service technicians but salesmen, the list is
rear pads 90% worn £115
wipers £29
battery £109
heat shield on cat insecure £139
spring rear offside rusty £200
drive shaft boot osf split £191
new tyre old one 4mm tread £64
and finally .............
lower engine/gearbox not bolted on properly possible damaged threads £2,205
grand total £3052
iv'e obviously not accepted the quote and have already changed the wipers for a tenner and tied up the heat shield with a large jubilee clip for 2 quid, i bought the rear brakes for £15 but need to get rewind tool i think it's laser 1214 or i may decide to let mechanic do it he's fairly cheap i want him to look at thes bolt missing on gearbox but he can't come till after christmas possibly early january it's potentially dangerous so i will have to poodle around again
the drive boot only needs the circlip around one end it's not split as they said
the rear spring costs £24 free delivery off parts gateway online so i might get that one
it's keeping me busy thats for sure
Edited by abudabi555
Lomg list there.. but, if changing the spring - do both. Itl cost an extra few quid, but you wont have to replace the other one due to ut failimg shortly.. and, you wont have uneven rear suspension due to age difference on each side...
Good news on the coil packs though!
thanks yes i will it makes sense
so just had mechanic round this morning he tapped a new thread out and fixed the dogbone then put new pads and discs on the back and put a new clip on the gaiter all drives lovely now back to normal speeds without the vibration and noise, did it for 50 quid and i supplied the parts which i got cheap off a site called scpock? its a boot fair type site and they had some discs/pads for 20 quid so i bought those and took the pads i previously bought back to cat componenets for refund of guess what? 20 quid :} so free discs essentially
how on earth can main skoda dealer quote 3000!!!! ridiculous
so all that needs doing are the rear springs but to tell you the truth they dont look that bad so i might just leave them
i was too lazy to change the brakes myself and he knows his job better than me anyway
Thanks for such a helpful guide, I ran out of daylight but I've managed to get my doorcard off without (much!) damage, just gotta get the hacksaw out tomorrow and wind that gear around, it will be nice to be able to open the passenger door again(even my 43 year old vw can do that!)
has anyone got any other idea , i have followed the thread, got to the cog, turned it to the right all thw way , the left, - no change!
when i operate the central locking the button on the door goes up and down , but still deadlocked. this is a new lock i bought a few months ago, but only had it fitted 3 weeeks ago, it worked for a week!
if i get it unlocked do folks recommend replacing it , or should it be ok?
Edited by jon davies
  • 3 years later...
Thanks for posting this, great detail and pictures.  worked for me I used multiple drill holes and pliers to make the hole to turn the wheel.
Great work, thanks again  🙂
  • 6 months later...
Apologies for digging up this old thread but it's the top result in google for Octavia door deadlocked and I thought I would share what worked for me on my MK1 and potentially save someone quite a bit of hassle removing the door card.
Operated the central locking from the button on the drivers door repeatedly, whacked the area where the locking mechanism is on the inside of the passenger door with a torque wrench at the same time.. door unlocked 😎
  • Administrators
Please be aware that whacking the door lock doesn’t always work. And here’s why...
Corrosion on the pins and both connectors blocks. It was so bad that two of the pins have snapped which doesn’t allow power to the lock (yet the window works).
as above.
if the whacking works, get the door stripped immediately and replace the unit and/or strip the harness.
Edited by mac11irl
Currently doing this on rear passenger door - great fun!
Has anyone got a link to the best ebay replacement locks for a Mk1 vRS estate?
