Windows open vs. AC
So it's that time of year where the sun is starting to shine but what uses more fuel, having your windows open thus disrupting air flow or having the AC on? And will wind deflectors help to stop a brake in the air flow, thought it'd be interesting to hear peoples thoughts on this (Bare in mind I've only been driving solo for just over a year so I'm still new to all this driving stuff)
Windows open one minute or so after start. Then windows closed and AC on. Actually AC on all the time. When the time comes that I have to worry how much AC consumes fuel, I would sell the car.  ;)
Keeping in mind that AC works longer if you use it often, if not all the time.
Windows open below 40mph air con on over 40mph
Sent from my SM-N9005 using Tapatalk
Air con always - but I do suffer from hay fever.
Should you mix some heat to incoming air? Citigo doesn't do it automatically, so it's left for the driver to do.
Only if you are cold  :giggle:
This works for better economy. I was quite happy with the A\C yesterday during a dual carriageway lesson. Had to mix in some warm air so it wasn't too cold after 30 minutes.
this seems like the best thing to do :)
Sent from my GT-I9305 using Tapatalk
all depends on the air temp outside
windows open to help get rid of the really hot air where the sun has cooked the car in the sun but have the aircon on to start to cool down the matrix then once you can feel the cool air from the aircon shut the windows
seem to work for me
Air con on all the time and window open slightly for about the first 1/2 mile just to help expell the warm air when it's like a greenhouse in there.
I used to think or was lead to believe air con uses more fuel, like what has been said above, it doesn't worry me with this car or infact any other car now. It must be  a miniscule amount.
I have driven some small engined Jap/Korean motors in Cyprus where if you turn the air con off the performance on the engine increases by a significant amount i.e they will actually go up the hills. I haven't got air con in my Citigo but I'm hoping for an Up with air con when I go to Cyprus shortly so I'll report back on the effect.
Usually AC is turned off automatically when you push pedal to the floor. It's kind of safety feature when you have to overtake. I'm pretty sure Citigo do the same.
Air con for me, does a good job!
The American armed forced did a study... 2 windows open below 40 and air con over 40.
In mine, if I switch the air conditioning on while in 1st or 2nd gear, there's a small blip of "engine" braking as it starts up. Other than that, and a small increase in engine noise at lower revs, I've not noticed any performance loss.
Is the CitiGo's air conditioner pump run off the electrics or the accessory belt?
Edited by ettlz
I cant be bothered with this window open malarky. On a warm day it aircon all the way!
been working all day in 20C plus.
a mix of windows open and A/C and still got over 55mpg  :sun:
I don't open windows if I can help it. I don't want to lose the new car smell :)
Sent from my PID using Tapatalk
I lost that ages ago, it now smells of a Ronald Mcdonald air freshener, surprisingly nice [emoji106]
well I got 71 MPG with sunroof open, windows open about an inch and air con off :) was well chuffed :P
I believe it's driven off the engine by belt.
In all VAG cars they disengage the A/C at high engine loads/speeds.
Phil
  • 4 weeks later...
I'd read that in testing 30mph was the "changeover point" where it was better to switch from A/C to windows, but I think that was on a 1990's Peugeot.  Aerodynamics are a little different now!  Likewise I understand the A/C systems are also more efficient, so probably little change in the speed needed.
I'm not a fan of A/C personally - only use it to get rid of the initial heat then keep the windows open an inch or two, dependant on speed and temperature.  Makes me drowsy so instead to buying a coffee at alternative motorway services, I'll lose the 3mpg..
Does anyone find their engine "growls" a briefly if you switch on the air conditioning just after starting up?
Not noticed this, mine only tends to growl when an Up! drives paat :giggle:
im not over impressed with the air con, it doesnt get me that cool on a very hot day. fans on 3 or 4 as well. Ive had cars where the aircon can give you goosebumps...
