VCDS 12.12.0 Park/Steer Assist
Hi everyone, I'm new in the forum and I have some problems.. I hope somebody could help me 'cause I'm very worry about my car :sweat: .
I have a Skoda Rapid Spaceback 1.6 TDI  with manual 5-speed transmission.
I bought a 12.12 wire (cable) and VAG 12.12.0 VDCS software. The fact is when I plugged it, I did a AutoScan and I could see all features that the program had.
The next day I tried to start the car and suddenly, the car gave me a message, something like "Select gear in the P / N position," as if it were an automatic car. Also, the display in the driver position doesn't show the information about the optimal gear. It's like the car was thinking that it is automatic, instead of manual. And the worst thing is that parking assistant is not working. It's like the module were turn off, when I select the reverse gear the navigator display doesn't show anything.
Later I connected the wire between the car and my PC, I press the module button 10-Park/Steer Assist, I make a Test Output and on this way the Navigator screen works like always it used to do: showing an image of the car, the proxime objetives, the sound when something is near...
In the program, the module 02-Auto Trans is enabled when it's an error, it should be disabled, obviously because my car is not automatic
When I get into the 01-Engine module, there are some different options and some of them and checked. This options are selected:
- Manual Transmission
- Manual Transmission 5 speeds
Also, I don't have a copy in the Debug Folder because I reinstall the program.
Another important thing is that the wire I have is a pirate Chinese :ph34r:  wire, very similar to the original that www.ross-tech.com (owners of the program VDCs) is selling and works
only 12.12.0. version. I have to also say that today I bought the original wire, and I hope could to run the latest version of the program.
I write here 'cause I don't have more ideas, is somebody with similar problems??
Sorry for my english, thank you for any help!!
There is an autoscan file.
Wednesday,30,July,2014,15:49:52:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: TMBEL6NH3F4504333   License Plate:
Chassis Type: NH (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 2E 37 44 56
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LM    HW: 03L 906 023 LK
   Component: 1,6l R4 CR td H33 9972
   Revision: --H33---    Serial number:
   Coding: 00114016002400080000
   Shop #: WSC 73430 031 00043
   ASAM Dataset: EV_ECM16TDI02103L 003010
   ROD: N/A
   VCID: 7CF7127BF71EBCFEC8B-8029
No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 F    HW: 1S0 614 517 F
   Component: EBC 460 ESP   H16 0022
   Serial number: A00LUZO
   Coding: 93CC487889AD00F5C9FD12F891AC00404F0D00
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: N/A
   VCID: 326BFC4365DABA8E527-8067
No ASAM data for: "EV_Brake1ESPEBC460TRW" (SE25)
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 5JA 907 044     HW: 5JA 907 044
   Component: Climatronic   H05 0106
   Revision: A1001000    Serial number:  1403262A-0348
   VCID: F8FF8E6B4B2610DE2C3-80AD
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0725
   Revision: B9074001    Serial number: 0671 147140626
   Coding: 62980B0000010000010806302ECB0EC00F80600F60822140020000024800
   Shop #: WSC 73430 790 00043
   VCID: 2F6DF5377EE897663D9-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150514 05  54  0403
   Coding: 0230ED
   Subsystem 2 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
   Component: E221__MFL-PR6  H04 0130
   Coding: 820000
Address 10: Park/Steer Assist (J446)       Labels: None
   Part No SW: 5JA 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 3K  H11 0005
   Revision: --------    Serial number: 32901414405632
   Coding: 100003
   ASAM Dataset: EV_EPHVA14SK25X0000 001002
   ROD: EV_EPHVA14SK25X0000_SE25.rod
   VCID: 4487AA9BCF6E043EF0B-8011
Address 15: Airbags (J234)       Labels: None
   Part No SW: 34D 959 655 B    HW: 34D 959 655 B
   Component: AirbagVW20    005 0366
   Serial number: 003K7R03U2AG
   Coding: 88CCC00000000000540000C8000000000065
   ASAM Dataset: EV_AirbaVW20SMEVW253 001110
   ROD: EV_AirbaVW20SMEVW253_SE25.rod
   VCID: 3467FA5B9FCEB4BE40B-8061
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 413 105 14
   Component: SideSensor_Df  003 0148
   Serial number: 349001A01A4DD9B4DC3Y
   Coding: 2D2D2D
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 412 205 14
   Component: SideSensor_Pf  003 0148
   Serial number: 350001A01845D6E55DAH
   Coding: 2D2D2D
   Crash sensor for side airbag; rear driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 413 105 14
   Component: SideSensor_Dr  003 0148
   Serial number: 351001A01A4DD512EFDP
   Coding: 2D2D2D
   Crash sensor for side airbag; rear passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 413 105 14
   Component: SideSensor_Pr  003 0148
   Serial number: 352001A01A4DD9351D4B
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5JA 920 840 E    HW: 5JA 920 840 E
   Component: KOMBI         H04 0709
   Serial number: 00000000000000
   Coding: 111A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3C77D27BB79E7CFE88B-8069
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-19.lbl
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0725
   Revision: B9074001
   Coding: 932200
   VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
01315 - Transmission Control Module
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 1243 km
                    Time Indication: 0
                    Date: 2001.14.06
                    Time: 21:04:31
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0709
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666341744
   Coding: 030100
   VCID: 2B55E1274AF0EB46111-807E
Address 37: Navigation (J794)       Labels: None
   Part No SW: 5JA 035 192 P    HW: 5JA 035 192 P
   Component: RNS315-EU   H80 0500
   Serial number: SKZAZ2P0302610
   Coding: 040004110207000001000005
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V6  0062
Address 44: Steering Assist (J792)       Labels: None
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3111
   Serial number: CE6E1012
   Coding: 0003
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_SE25.rod
   VCID: 4683B093F952362EEEF-8013
Address 56: Radio
Cannot be reached
End   ---------------------------------------------------------------------
Assuming that you have now bought a genuine VCDS interface having found that a counterfeit version can introduce problems which weren't there before, download VCDS Release 12.2.2 and post the scan result again. If you can't download that release then the second VCDS interface (original wire) is also counterfeit and you will not get any help on this forum. Ross-Tech provide technical support by email for owners who register their genuine interfaces with them.
So there's your problem
"Pirate copy"
Not good.
Jaja, the Pirate wire is a bad option. With the Pirate wire does not work the VCDS 12.12.2 version. I already bought the genuine wire, bring me in a week. When I get the new cable I will make a autoscan. If I have not solved the problem I will send the new autoscan file. Thank you very much for your help.
Hi, I just fix the problem. I connected the VAG-COM wire to the car and entered in the module 19-CAN Gateway. This module contains a lisf of enable modules. I disabled the module 02-Auto Trans (Automatic Transmission) and the problem has solved.
Greetings and thanks!!
