DIY 6 Speed DSG Oil & Filter Change
Don't suppose you've got another off cut of that pipe I could have please phil. I will pay P&P.
  • Replies 55
  • Views 14.3k
  • I've just done my DSG gear oil change.   On a difficulty rating of 1 to 10 (10 being the hardest) I'd say it was about 3. No harder than doing an engine oil change.   The fiddliest bit was removin
  • As Phil said, his dealer quoted him £169. My local VAG independent quoted £150 so there is still quite a saving doing it yourself
  • Comma oil is a very good product i work for Dorset Auto Spare and they are our main supplier now high recommended we sell 5 ltr of that for £42.54 so thats not a bad price
I certainly do!
PM me your address and I'll pop my off cut in the post for you. Feel free to share it when you're done with it too!
Phil
  • 2 years later...
BUMP :D  So, a DSG service involves that filter and seal kit. plus 5 litres of the right oil.
The thing which surprises me above with the heavy labour charge is oil @ £8.60 a litre when it looks to be £12 a litre in most places.
Correct. Just search for DSG filter on eBay and buy a genuine one. They come with the new seal.
And yes 5 litres. Again have a look on eBay. You can get it a little cheaper. Buy the genuine stuff though as aftermarket doesn't save much cash.
I might even have a full unopened bottle you can have and I can do you a little offcut of the pipe I used as it was a perfect fit over the filter tube (have to use this as just pouring it in will take hours).
I recommend running basic settings on the box afterwards with VCDS where it runs through all the actuators and re-calibrates the clutch biting points.
It's easier than my Saab box that will need doing soon... I need 11 litres and to do it three times with a drive in between (as over half stays in torque converter when drained).
  • 1 year later...
So... 40,000 miles later this needed doing again.
I did it myself this time.
It's just as easy as a normal oil change, only with the extra time required to remove and refit the airbox and battery.
I had a Pressol oil funnel in my garage and found that the tip fit perfectly in the hole at the top of the filter housing. It still took a while to fill up though.
A bungee cord held it in place which meant it was a lot easier to just fill the funnel and leave it to drain in.
4.3L drained, 4.4L filled up.
Ah. Ignore my PM then. I see you've managed to do it!
That's one good thing I've found with doing the gear oil changes on the Saab is that I don't have to remove the battery or air box or anything which greatly speeds the process up.
