Using LEDs for indication instead of bulbs
I have the £4.49 ones and they flash just as bright as OEM and look better when they are not illuminated. I would recommend them easily.
Sent from my SM-N9005 using Tapatalk
Cheers, one more thing.. How hard is it do change the front and back bulbs? Like how do you take the head unit off and the rear as well to get to the bulbs? Is there any videos/instructions anywhere?
Its very easy don't worry.
Back; the whole cluster needs to be removed. To do this look at the rear of the cluster from the inside of the boot and you will see a large screw head that you turn with a coin. Unscrew it completely and then pull the cluster away from the outside, it might be a bit stiff but give it a wiggle and it will come off. Unclip the wiring harness and you've done it. Fitting the bulb is straight forward. Then replacing the cluster is the reverse.
Front; the bulb just unscrews from the front cluster, simple.
+1
:thumbup:  :thumbup: :thumbup:
