Electric boot struts.....
I will be on my third pair when the car gets serviced. I look forward to excuse offered by the dealer with regards to yet anther strut leak. I think its tine to escalate the issue beyond dealer level.
  • Replies 111
  • Views 29.8k
  • mines getting checked next week when in for a service due to the amount of oil on them
  • The good news is it looks like the part may have been revised - so fingers crossed that this is the end of the leaking boot struts saga.   ......and you believed something a dealer told you? Regardl
  • That's good service. If a dealer is willing to order a back ordered part without first diagnosing the fault it must be a known issue. I'll keep an eye on mine.
Do all the seat VW and Audi struts leak with the same alarming frequency?
Got new ones!
I will be surprised if they don't leak within a few months
Bargain basement parts! I doubt the Audi badge company car men/woman suffer the same frequent problems......
As I said before the same part is used across VW group, made by the same manufacturer to the same standards and quality. But again you post as though the parts Skoda use is of inferior quality when they are exactly the same.... I get that you have had issues with your car and are angry and fed up with it but many of the parts are shared across the 4 brands of the VW group
Just asking.
Have used electric boot lid now 5 months (MY2015b). No oil leaking struts, but I use only the height position 2 and I'm just 189 cm tall.
If the struts are leaking, are you using the highest possible opening (top position of the lid)?
Height pos. 2?
I didn't know they are pos to change?
There aren't as such, you can reprogram the lid to open to a lesser amount if you have a low garage roof or are vertically challenged and can't reach the button if it opens fully. It's in the manual, P61.
Sent from my HTC One_M8 using Tapatalk
If there is an issue with the boot going to the top position then I will try this on my third set. Good advice Cheers.
By default it doesn't go all the way, you should be able to open by hand another inch or two.
True checked that today. Also visited my dealer who is suprised once more that mine are leaking.
On a good note he arranged for two minor scratches to be polished out on the spot. Good stuff
The new ones are stil oil-free! I'm happy :)
  • 2 months later...
This was done by the previous owner of our car. Not cheap at all.... and by the looks of it the struts look to be the old model? Was there ever a service bulletin/recall on these in the UK?
No recall that I know of, I'm currently awaiting another new set no issues with dealer they had a look and ordered another set
So far *touch wood* mine are fine, the boot gets open most days it's used.
Though I'd be worried about this option out of warranty after seeing the above bill!!
That equates to £584, while no small sum it's not the end of the world....
I realized after my initial shock that it wasn't UK£ but NZ$, so yes not as bad as I first thought.
I think the parts are around £450 per side according to my dealer. I have one side that's ok and one side leaking oil both sides are the revised parts with the new part number.
That didn't last long (again).
Touch wood, my replacements seem fine at the moment.
There was some oil on them after they had been fitted but it was put down to being there to protect them during transport. Dealer cleaned it off and one side has remained fine one side is leaking badly, I also need to get my door seals looked at due to water retention
So my car had its first service and I asked the leaking boot struts to be checked over and replaced due to the leak but I'm informed that they are not leaking enough to warrant replacing.
Sounds a trivial matter but if someone gets hurt if they fail?
Edited by octavianestate
Put a photo up showing the leak
Will do tomorrow in the daylight
Will do tomorrow in the daylight. These pair not as bad as the original set that leaked but even so, it's a warranty job. Less than 6k on the clock it should not occurr.
  • 5 months later...
I believe my struts are leaking but Skoda say they are fine - Please can people advice on the pics I have linked, if people had them replaced under warranty were they much worse than these.
I have spoken to skoda customer care as well but they just speak to the garage and take their view,  going for another garage .to check tomorrow hopefully.
So far I have been told -
1.. First time they were checked - over packed with grease from factory , wiped off but 1 week later oil present.
2..Second visit - They are meant to be like that, self lubricating and oil will be present.
Now I think this is bull,I dont feel oil should be where it is, advice please
[/url]">http:// [/url]">http://http://s1239.photobucket.com/user/mickeyfinagin/media/DSC_0277.jpg.html'>DSC_0277.jpg
Edited by Dirtydogg
