Complete VCDS Guide - v1.2 - Updated 10/1/17
I present to you a complete VCDS Guide originally written for the MK4 Seat Ibiza and Cordoba Models. This is still a work in progress and if you have any requests or additions, pop me a PM and I'll update the file!
This has been compiled with months of work for a free distribution. This VCDS guide may also work with Fabia and Polo models, however, this is untested.
>>>>>DOWNLOAD HERE<<<<<
Version
V1.2
Change Log
Version 1.2
Added
·         [01] – Engine
o   ECU Swap (Immobiliser Coding)
·         [17] – Instruments
o   Instrument Cluster Swap (Immobiliser Coding)
Changed
·         [01] – Engine
o   Cruise Control Activation
o   Key Programming / Matching
Minor Amendments.
Contents
[01] Engine
- Idle Speed - Raise/Lower
- EGR Valve - Reduce Flow (Diesel Only)
- ECU Swapping (Immobiliser Coding)
- Throttle Body Alignment - KW-1281 and KWP-2000 (Petrol Only)
- Cruise Control - Retrofit Activation
[02] Auto Trans
- Coding
- 01M (4 Speed) - Basic Settings
[03] ABS Brakes
- Coding
- ABS Pump Bleeding
- Steering Angle Sensor Calibration - Bosch 5.7 & 8.0
[08] Auto HVAC
- Basic Settings
- Output Tests
[09] Cent. Elect.
- Coding
- Tow Bar Electrics - Activate/Deactivate
- Drip Wiper Function
- One Touch Indicators
- Terminal 30G - Interior Power Supply Discharge Protection
- Heated Windscreen Activation Time
- Heated Wing Mirror Heating Time
- Rear Screen Heating Time
- Boot Lid Remote Unlocking
- Headlight Washer Activation
[15] Airbags
- Airbag Activation/Deactivation
[17] Instruments
- Coding
- Output Test
- Instrument Cluster Swapping (Immobiliser Coding)
- Key Matching - (IMMO3) & (IMMO2)
- Service Schedule - Adaptations and Resets (2002-2006)
- Service Schedule - Adaptations and Resets (2006-2008)
[44] Steering Assist
- Steering Weight - Heavier/Lighter
[46] Central Conv.
- Coding
- Anti-Hijack - Auto Lock/Unlock, Bleep and Indicator Flash
- Selective Unlocking
- Remote Fob Syncing
[55] Xenon Range
- Headlamp Adjustment - Manual Adjustme
Edited by badger89
  • 1 year later...
I updated this to v1.1 a while ago and has had over 9000 downloads.
Enjoy
  • 3 months later...
Link in first post updated - Enjoy
Been an idiot - guides now working!
Great guides.
I may check a few of these and see if they work on my Fabia and report back, unless it has been tested since your first post?!?
Yeah, few Fabia owners have tried it and they work just as good, I ideally need a Fabia and Polo myself to test and confirm :)
v1.2 Uploaded - Enjoy
Added
·         [01] – Engine
Changed
·         [01] – Engine
Minor Amendments.
Link updated - now working!
This guide has been downloaded over 10,000 times!
