woman driver needs help
hi i have a skoda fabia classic and just recently the engine seems to have got loud only as the car goes faster, idling its still quiet but when i get to about 40 its loud and seems to vibrate but not through the steering wheel, it doesnt happen when i rev just when im moving
Welcome to the forum.
A Mod might move your post to the Fabia 1 Section where you can maybe get some help.
george
Moved
Definitely the engine and not a wheel bearing? Try driving it and dip the clutch to see if it still does it
A member with "zero" posts, yet I'm reading one... argh! Are you The Doctor's new assistant? :) Do you have the keys to the Tardis?
Not a very nice answer to a damsel in distress.
Julie666 why not state your area, someone near to you may be able to help/advise.
DB.
Beware of white knights, stalkers and perverts on here  :D
May I suggest you locate an independent specialist near you because your problem could be caused by any number of things, there's no easy diagnosis without getting the car up in the air and having a poke about so to speak.
Im guessing its exhaust related sounds like its blowing. worth checking the oil, friend of mine came round the other day
complaining of noisy engine and when I checked he had none in it. I had to put 2 litres in before it registered half way up the dipstick it was
quiet as a mouse after that.
Edited by Damo
needless remark removed
Im in the gravesend area of kent...definitely not the exhaust because it doesnt do it when I rev it feels like im driving on a flat tyre
Definitely sounds like a wheel bearing to me however diagnosing faults on an opinion can be tricky lol :)
Post count is still out... I can see two posts but only 1 credit. Is this how the moderators improve their score?
Back to the car....
When driving, try dipping the clutch, allowing engine revs to die back. Does it still vibrate and make the noise? If so it's something other than the engine.
Problem could be virtually anything unfortunately. Would be safer to do some basic checks like checking the tyre pressures and having a look around the tyres to see if there's obviously a problem.
If I had to guess, I'd say rear tyre or wheel bearing.... Utter guess though. Ah, or brakes....
J.
Edited by vindaloo
If this lady jacked up a wheel and span it would a bearing be noticeable?
Edited by Damo
sounds to me like a wheel bearing. yes it would be noticeable if it was jacked up and spun by hand. the wheel should spin smoothly with no rough grinding noises or feel. if you grab hold of the spring with one hand and spin the wheel with the other you will feel if rough through your finger tips.
if your not good with jacks. just think not to put yourself under where you can get crushed if cars slips (bottom of wheel with fingers or with legs crossed sitting down )
Edited by Damo
sexist remark removed
Only post, if you intend to help with the OP's question.
Any other sexist or unhelpful posts will be deleted and could incur warning points
You have been warned
Think yourself lucky that Damo stepped in as I wasn't going to be so considerate.
This is because we moved it from the 'Introduce Yourself' section that doesn't tot up the posts. :thumbup:
Motion to have the introduce yourself section acrue membership points... :)
All in favour....
I was injecting light hearted banter most people have a sense of humour, the smiley directly after the sentence was to show it was in jest.
I doubt anyone took that comment in anything other than the context it was intended. Remove any life from the posts and your gonna create
a stale environment that's no fun to be in. The post was in general area when I first looked it might have been moved now to the correct area
but at the time I though it was fair game.
When you rev the engine in neutral its not under any load, it could still be engine related if it happens at speed.
I was injecting light hearted banter most people have a sense of humour, the smiley directly after the sentence was to show it was in jest.I doubt anyone took that comment in anything other than the context it was intended. Remove any life from the posts and your gonna createa stale environment that's no fun to be in. The post was in general area when I first looked it might have been moved now to the correct areabut at the time I though it was fair game.
A report was made about the comments left by some members, so we act according to how we see fit.
Im not doubting you made them light heartedly, but some people see things differently to how they were intended.
The question asked is all the OP is after, nothing else
We are not trying to kill any humour/atmosphere from the site, but there is a time and a place for it, which this didnt require (I also understand you saw it when it was in another section)
Just to reiterate, we acted on a report and dealt with as we saw fit, and moderation isnt to be questioned on a thread. If you still feel aggrieved, feel free to PM me
Damo
Damo
No problems here, Although I would say perhaps the title of the post could have been worded differently if it wanted to avoid humorous responses given that gender has nothing to do with the problem. Or does it? :peek: (awaits removal).
Also I have just noticed Briskoda membership has expired this month. I have made way more controversial borderline comments in the past and never had them removed or moderated. Do I need to pay for the privilege? :notme:
Edited by Scribbler
All in favour....
No.
You get people spamming everyone on there with the "hello and welcome" message and they clearly didn't actually read the original post in the first place and offer no help/advice where requested.
Its just an easy way of bumping up post counts, for those that care about such things.
I'd say either wheel bearing or binding brake perhaps.
Sometimes a stone can get between brake pad and brake disc and make a surprising
racket. After a run are any of the wheels much hotter than the others?
Oh and welcome to the forum,
and no relation btw :)
Lol
No.
Bu66er :( ;)
