Freezing windscreen in the inside!?
Hi guys, I have a citigo 2012 and have noticed on those very cold days the windscreen freezes in the inside, there isn't any excess moisture inside the car, so I don't really get it? I would understand if it was an old car but it's not. Does anyone else get this issue?
Jodie :sun:
I think it helps to leave the aircon permanently on as it works as a dehumidifier.
But won't that cost much more on fuel? I still don't think it's normal for a modern car to do this, a/c on or not.
I don't think the AC runs on fuel on the citigo, I think it's off the battery :) try buying a couple of dehumidifiers
Correct its electric.
And my son's Citroen C3 does exactly the same if he switches off the AC.
And where exactly does the battery get its charge from?
All right smarty pants :P yes the AC technically speaking runs of fuel because the battery chargers from the engine, but it is electric
Mine doesn't do this.
Modern aircon isn't like the old days where it uses a lot of fuel and had its own seperate clutch. As said its electric and you won't use anymore fuel with it switched on [emoji4]
It will use more fuel as the alternator provides the electrical power and that uses some of the mechanical energy produced by the engine.
You can here the effect increased electrical load has by turning everything electrical on together (heated rear screen, headlights, fog lights etc.), listen to the engine note and revs.
I know that but it's not using any more than any other electrical component. It's spinning all the time but it's not like the old clutch driven units that really zapped the power out of the engine.
Back on topic. It would be best as said to buy the dehumidifier packs [emoji106]
It would be worth checking the spare wheel well and all the carpets, if you haven't already done so.  Also try airing out the car when the weather is OK.  Our Leon has always suffered from condensation and putting a fan heater in the car for about 10 minutes normally clears it up for a couple of weeks.  That and stopping the kids leaving damp stuff and drinks in the car.
Jodie :sun:
Have you replaced pollen filter? And is window clean? Dirty window will collect more moisture. Rubber mats would be good if you don't already have them.
The energy that is fed into the battery via the generator, is ultimately driven by the engine. Hence, the fuel consumption will increase using the AC.
However, the AC compressor does not start at subzero temperatures anyways. You must open a window a little and run the fan at full speed and high temperatur for a while.
The cold outside air contains very little humidity, and when it warms up, the relative humidity will drop - then it will reduce the humidity inside. When you breathes, you exhale humidity. As long the cabin is still cold, the relative humidity will rise causing the humidity to condense and freeze at you cold windows. There is no other workaround to this problem. I have used my car at - 25 degrees Celcius for some days - it is a problem, not only at this car but any car I have had.
Br.
Vidar
Edited by Citigo2032
I'm interested in all this "misting up" and "freezing up inside"...because I don't use the aircon much in Winter and my Citigo doesn't mist up any more than any other car I've owned.
Mine was frozen inside this morning, just a thin layer on windscreen, first time this has happened since I had a ford escort van 30 yrs ago!
Edited by barnie
Why do folk worry about the miniscule amount of extrafuel they may use if the aircon is on?
Yes maybe at idle but when your wafting along I doubt there is any noticable difference.
Mines on permanantly and I have tried it without, I can't tell any difference in the fuel it's using.
It is strange though reading folk who seem to have misting/freezing up problems whilst others, same make, model have nothing to mention in terms of these problems. Not just the Citigo model either.
Edited by MickA
I use aircon almost 100% of the time, and I still get up to 76mpg. It should not be a concern or consideration, the fuel usage of using aircon is barely measurable. And at that level of subtlety, I choose vision over Loss of 0.0001mpg... I'm sure I can spare that tiny bit of fuel so that I can actually see while driving :D
Mines in a garage always at 10 degrees [emoji106]
I don't get any moisture whilst parked outside at work for 8 hours. The only time I did it was on recirc and it mists badly. I forgot to switch it back [emoji6]
AC compressor is belt driven, I just checked. It's under the alternator.
I don't like to use AC on cold weather, as it takes longer to get warm air out of heater.
Mines absolutely roasting after a couple of miles driving, I'm reaching for the "turn the heat down knob" I settle for around 22 c. ^^^^^^But we aren't in Finland^^^^^^ :think: Bet it's like summer to you if you came over here now. :sun:
This was the interior of my Rapid:
Before buying one of these
It used to take me 10-15 minutes to scrape the inside of the windscreen
Now I don't get any condensation on the front windscreen and only occasionally on the back. I have the aircon on all of the time and before I park up I switch the blowers to the floor, to full cold and the fan to zero so stop any air coming through.
Edited by Delberthot
My Toyota Yaris ices up worse than the wife's Citigo neither have any leaks but neither of us use the AC, perhaps we should. Wish my Yaris diesel warmed up as quickly as the Citigo!
You park up with a nice warm car inside with lots of moisture inside due to breathing. The windscreen cools down faster than anything else so the moisture condenses on the windscreen and then freezes when the temperature drops. The only way to avoid this is to remove the moisture or cool the air in the car to close to outside temperature after stopping, flap the door a couple of times. One other thing, if you don't open a window very slightly you don't get the full effect of the blowers on the heater as, like the old beetle, these little cars are virtually airtight.
There is exit vents in the boot, so ventilation isn't as poor as it is in old beetle. :notme:
Well, all I can say, is that if you put the blower on then open a window very slightly the airflow from the blower increases considerably. Try it.
