has anyone come across this error before and maybe a cure?!
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5J0 920 840 D    HW: 5J0 920 840 D
   Component: KOMBI         H20 0220
   Serial number: 00000000000000
   Coding: 120A00
   Shop #: WSC 13765 031 00047
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 2A51695D4D1A844EEA7-807F
1 Fault Found
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 134
                    Mileage: 114872 km
                    Date: 2048.14.04
                    Time: 13:06:14
Can you check or post it on ?Ross Teck wiki
I've tried searching U1111 on Ross tech site nothing appears
The code is 12648448 not U1111.
If you clear it does it come back?
I cleared it and it hasn't come back yet only an hour or so ago
I wouldn't worry too much. Have you had any battery problems?
No battery problem but Google may have answered it the car was remapped a month or so ago so could have been old warning dpf or something
I think it relates to different controllers not talking properly to each other. Probably won't come back.
