320 miles to a full tank?
Had to drive from Aberdeen out to Ikea in Edinburgh, so filled the tank. Range the computer gave me was 320, but sitting around 72-75mph on the cruise control got me 340 miles.
Is this sort of range correct for a 2006 petrol saloon vrs?
Yes.
Ouch!
That's a bit low if you ask me. Should be able to get 400 ish
Sent from my Galaxy S5
Seems very low to me, even our Jag gets more than that
There are a few factors that if known may be helpful;
How long have you owned the vehicle?
What is your usual driving conditions, mostly in town/motorway?
When was it last serviced?
Had it been serviced correctly, items replaced when stipulated?
What sort of mileage/range were you expecting?
If it makes you feel any better, I had a 1989 Rover 216 that would give 15-17 mpg in town and about 32mpg on the motorway.
Took it to several Rover garages that couldn't find anything wrong with it, but did compliment me on how clean it was!
Really, is that what you get from a petrol vrs?! When I fill my 1.8 up the trip computer usually says 455 miles! :|
Also what fuel are you using?
I'm getting around 320 to a tank in my 07 so seems about right to me.
Right, completely standard car. I always use shell v power/super unleaded. Serviced it myself 6k ish miles ago myself and did all fluids and all filters (including fuel) usually do a mixture of both motorway and town driving.
The whole journey out to Edinburgh I was getting around 33mpg, a little less on the way back as I was going a bit quicker.
Around town I get high 20's and any country road driving I can usually get up to 40mpg when taking it easy.
What you need to know is how many litres you'd need to put back in the tank to fill it up again after your 340 mile journey.
Sorry you're post hadn't come through before I posted. 33 mpg sounds about right to me.
I would say the figures were low.
My 55 plate 1.6 FSI manages between 440 and 460 miles per tank, less when towing.
Where as my 06 plate 2.0 FSI manages up to 440 miles.
Both with mixed driving.
More if at motorway speeds i.e. 70 mph.
I know they are not VRS but I would have expected up to 400+ miles.
I'd be expecting at least 400 miles too, considering the size of the tank and car.
As the other VRS owners have said. That's similar to what I get.
I'm surprised they're that bad tbh.
I can easily get more than double that from a tank on a long run.
Phil
I'd say that's about right. Mine is the tsi version but the absolute most I have had to a tank is 350 miles and worst was around 220 :D Always used Momentum 99.
And how big is the tank in the Jag?
Exactly this.
The best tank I ever got out of mine was before it was even stage 1 mapped - I don't think I'd had it very long and I drove from Leicester to Hull and back and did another couple of long(ish) journeys, all at about 65 mph, and it cracked 400 miles to a tank. On average I see between 260 and 320 miles from a tank and I rarely squeeze more than 50 litres into a tank, normally between 45 and 48 - I expect to see about 350 out of this one, whever I finish it off.
Edited by j0hn
Mine is 320/340, but had 450 once on a weekend trip to Cornwall taking it very easy (but with a loaded car)
Just checked fuelly, and my 4 yr average is 31.5mpg but a lot of my driving is around town
****Edited - Just checked that trip to Cornwall, it was 415 miles not 450
Edited by sdwilliams72
I have come to the conclusion my car is either a) Possessed or B) Broken I get 250 miles from empty to brim :( mainly town driving but still seems uber low!
When I fill up my 07 Octy vRS the range usually reads around 430 miles.  I actually get between 300 and 350 miles from a tank full, depends on the type of driving I'm doing.  Not done a long motorway trip yet so I'll see if I get any more doing that.
Edited by SkodaKitteh
I get between 310-330 between fill ups, my record is 372 so sounds about right, averaged about 29mpg over the last 20 odd thousand miles, mostly A road driving.
That's your problem - mine doesn't like stop/start traffic at all, town driving is hopeless and returns between 11 and 14 mpg.
About 350 miles to a tank from my stage 2 vRS. Pretty much all types of driving included in that figure.
exactly why I bought diesel. Same mpg as my 1998 Civic VTI-S
