Rob's Ur Quattro
Ken got there before me..
Heard it reported on the radio this morning leaving for work. I always have NZ as being the Ireland of the southern hemisphere.. get on with thine neighbour and dont get overly excited about anything in particular.
That even NZ can end up with people brainwashed by hatred into acting in such a violent manner.
Edit..  he was an Aussie it seems..
Edited by mac11irl
New info available..
  • Replies 1.7k
  • Views 177.8k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Re-assembled everything, started the engine, ran it for 3-4 minutes. Oil leaking. Not sure here from. But the turbo was smoking! And the timing is not right - as soon as it gets warm the idle drops and it stalls, then it doesn't want to start. Time to admit I need help from someone who knows what they are doing.
53869225_1722972007803088_71968598020587
3 minutes ago, RobClubley said:
I've had a lot going on at home and just haven't had the time or the energy to work on poor Rusty. So I've had to admit that the daily will be going on this Gumboot Rally. It just wasn't worth trying to rush things and potentially breaking down and not making it anyway. So, next time!
56360460_1743077029125919_37568066439757
The context is sad, but the meme is funny :D
I think I had the companion book. 'I can drive a Lancia and still afford food - plus 101 other fabulous jokes (all new Fiat section just added) '
and I'm not knocking Fiats, I've owned several, but blimey the 130TC cost a fortune
56453097_10156891784290977_6878450855381
Well, that could be oil getting to the outside of the turbo housing from the rocker cover seal. Check those bolts aren't loose first.
  • 4 weeks later...
Thanks to Wellington European for the loan of their smoke tester. It pointed me straight to the seal that I have totally left out. Not sure how that happened!
58543292_1778205132279775_44371662500570
58842402_1778205248946430_88806337840729
58542969_1778205368946418_53006483881679
58379702_1778205455613076_74192699332482
57429689_1779731955460426_77702044267399
 It runs much better and will warm start. Got an exhaust leak at the waste gate and it's still dripping oil when warm, and there are a couple of heat shields rattling. So I have work to do.
Must get this thing sorted
61320428_1826315750802046_58045384052157
Edited by RobClubley
How was other Audi on the Gumboot??
Really good, it's a great car for that sort of thing. Comfy, fast enough, even pretty economical on a long run. And there was 60km of gravel road, which was great fun.
Rusty will be tip top for next years :clap:
Next one is in September. The theme is "Because Rally Car".
Backed Rusty out of the garage. This happened.
61853494_1831166943650260_80868327572855
Not sure the water pump is even working properly. I drove down the street and back. Things are not right
I think it's time to get Rusty to Wellington European, and stop putting it off. Because I really don't want to pull it all apart again myself. But I don't think I can really afford that.
https://www.facebook.com/ProjectRustyquattro/videos/338270913523823/
I did give it a wash though.
62077060_1832593080174313_26725673959182
61674966_1832955000138121_53281073424519
  • 2 months later...
Is there a possibilty you could borrow a cooling system pressure tester from somebody over there Rob?. It would make life a lot easier to spot any leaks as the motor won't be running.
That sounds like a useful tool! Will investigate.
Just need time to start it now :D
68307516_1954169194683367_16290093350592
That is a bit more of a meccano set than the pro kit, but it will do the job at the end of the day.
Just make sure you eliminate all air leaks at the tool joints before you go leak hunting or you could be chasing phantoms for hours.
Test the system cold, as more leaks tend to seal as the engine warms up, and make sure you don't pressurise the system higher than the cap running pressure or you will add to your issues
Good luck buddy.
Edited by kentphil1
Coolant system pressure testing kit has arrived. Just need to find some time now to use it!
69996204_1982014855232134_19598897285976
  • 4 weeks later...
How cool is this
14 hours ago, DarkPeakCycles said:
How cool is this
Car is super-fantastic. Next stage for sure flat out maximum attack!
How's the old girl doing Rob, or should we just call her Snoozy Quattro now :sadsmile:
