Rob's Ur Quattro
7 hours ago, DarkPeakCycles said:
It's great to see a grin, long may they continue 👍
+1 to that, good to see a smile, makes the journey worth it.
Edited by kentphil1
  • Replies 1.7k
  • Views 175.2k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Out of the garage again for insurance valuation. Any excuse for a few quick phone pics.
Had a quick run down the road and back. First issue was fuel pump not running - wiggled a wire and that came right so I need to fix that !!
Then at the bottom of the street I stopped and it stalled at idle. Coaxed it back to life and got back to my drive and stalled again. It took 5 mins to get it to re-start with half the car sticking out into the road. Fun!
Also when it hits boost it's pulling back, so something isn't sealed properly I suspect. Maybe the BoV.
I'm going to get it transported to Wellington European next week for an expert to fix
76697432_2114655505301401_62583650035611
74288131_2114655548634730_87804337861951
75380189_2114655488634736_28803399392606
74617602_2114655675301384_17090223810554
76677999_2114655745301377_10844317527866
75233895_2114655755301376_13189389256532
Edited by RobClubley
More power to your elbow :)
Btw how are the baby Kiwis these days?  Still super cute I trust :)
I was about to go to bed and now I can retire to bebo's a happy bunny. :)
Out for a sneaky run to the pie shop after my mate Peter found a very small vac leak, which seemed to be part of the running issues. I found a broken wire to the air intake temp sensor. After fixing those it idles and runs without stalling. It makes rather wonderful whooshing and dumping noises too but is holding back under boost.
74344994_2121513677948917_89995056282840
Mog was less impressed with my clean car than she was with the warm bonnet. Damn cats!!
75569731_2121548204612131_88369175840046
74617536_2121548214612130_34686272147260
IS a black car crossing the path of a cat bad luck for the cat?
it made more sense in my head
Driving my urquattro makes me grin :)
75418866_2123634391070179_66577467023818
Fantastic looking car inside and outside, so jealous.:nod:
Quattro noises.
If you don't mind looking up my nose :)
4 minutes ago, RobClubley said:
Quattro noises.
https://www.youtube.com/watch?v=KckWoQOLl_c
Sounds like my stage 2 Vrs245 but with less power of course.:tongueout:
Way less :D
22 hours ago, RobClubley said:
Way less :D
But 5000% more character ;)
Which is more important....
So the ABS faults - what happens is when you brake there's a kind of vibration in the pedal, there's a pump noise, the pedal feels hard, and no braking happens. turn off the ABS and all is well.
WoF man said remove the warning light from the dash, LOL. That is a possibility - removing the ABS and just having non-ABS brakes, and getting the car certified that way. Or a nice set of 4 pot Wilwoods :D
I pulled the plug out of the ABS computer and the braking is fine. Not a WoF solution though. It's likely sensor spacing or wiring. Or dirt in there somewhere, thought it has all been apart and cleaned. I've tested sensor resistance and they're all in spec.
78669047_2144025905697694_93383277470652
78534446_2144025842364367_38843077002547
  • 3 months later...
4 hours ago, RobClubley said:
How the heck am I totally missing the ABS sensor spacer cap on one rear wheel?
This may be relevant to ABS not working!
No idea, but I'd almost guarantee it's relevance to ABS not working!
Yikes!, as Ken said ....................not good - at least you found it though :thumbup:
Yay, the ABS sensor caps arrived just in time for Level 4 lockdown :)
90895746_2377351879031761_18802297933377
Had a little drive - down  the drive about 30m.
90658035_2383063448460604_23801405103008
At least it's clean, and the dash wasn't working as I pulled back into the garage. Always a new challenge.
91179255_2383457385087877_47774337971320
91392658_2383457781754504_41200335829765
90267865_2383458028421146_27787935722147
On 09/03/2020 at 04:46, RobClubley said:
88180778_2337579609675655_25008214591615
Never mind the awesomeness of the car and everything else in this thread, I do believe I'm experiencing torque wrench envy! 🤢
Gaz
Can't go to the garage without checking out the urq and having a little talk to it.
91692676_2397617323671883_33030896961454
91384830_2397617440338538_20987671654013
She is looking really good Rob.
92029874_2404159399684342_39444355587715
The dash only fires up if I hold the reset button. Been told that this is normal behaviour when ignition is off, meaning I may have a broken switched live to the dash.
https://www.facebook.com/ProjectRustyquattro/videos/2503944286484854/
Somewhere in here lies my problem, probably.
93200109_2423987897701492_75330150897465
Seats out !
For two reasons - get to the wiring more easily and the car has developed a really pungent smell inside - which I think must be coming from the seat foam as I've replaced everything else, and will be related to its 10 years of sitting around and previous housing of rodents.
The foam is also starting to break down into powder so I need to get it sorted. It's so bad that after sitting in the car for 10 minutes, just standing next to my partner started to trigger her asthma. Bit of a concern!
92959932_2425827030850912_23390641002119
93118484_2425827237517558_27255194764800
Your dedication is praiseworthy :)
