Amunsen MIB1 Firmware
Any ideas if this is the most up to
date version for this non satnav unit?
its on a 2016 Octavia SE
many thanks
  • Replies 982
  • Views 231.1k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
Hi All
Pretty new here and to Skoda.
Finally found a thread on FW updates !!
I have a 2014 Octavia with an Amundsen MIB1 installed (have updated maps already,) Current FW shown below.
Any ideas as to the latest version released how to get a copy and install it ..?
Any problems or things i should be looking out for during or after the update ?? Is there a change log for bug fixes and enhancements \ improvements ??
Lastly can i go direct from my current version to whatever is the latest available ?
Kr
Paul
many thanks
And what I should have added is please can someone forward me the link to the update (if there is one) as a PM on here. Or [email protected] is email is better. Many many thanks
  • 5 weeks later...
I just bought a 2014 Skoda, I very happy overall but I found an issue.
When I call someone using bluetooth car system the sound I ear is ok but some receivers complain about some "sound distortion".
I read on this forum that there is a newer firmware than mine, and I Hope it can correct the issue.
I think it's Amundsen MIB1 and if someone can send me a new firmware version I would be great.
See you.
Hi guys,
Anyone has an update for this old Amundsen version (First version of the Octavia MK3 June 2013)
Part number: 5E0035874
Hardware: 039
Software: 0171
Thanks in advance !
Hello!
Can anybody help me with the firmware update?
Hardware number: 5E00035840A
Hardware version: 041
Software version: 0435
My email address is    [email protected]
Thank you!
Hello Aki78 or someone else ,
can you send me the link where i can download the newest firmware for my Skoda Amundsen MIB 1  (0490). I prefer 0490 if this is the newest if you have only 0475 then send me this link.. I have 0465 version in my car
Best regards,
Steve
Hi, I have the same issue. Need to update the infotainment system. Have no Android, no Navi on It.
Please email to [email protected] as explained I need Amundsen MIB1 0475 or better 0490 firmware
Hey guys, i got some problem with my canton sound system, i cant head anything from the speakers behind and the sound from the radio is really bad.
I heard a firmware update could solve the problem.
Please send me a link with the neuest update for my Skoda Octavia (12/2016 not the facelift) with Amundsen to my email [email protected]
Thanks a lot !!!
Looking for a newer Firmware Version. Navi quitted....please Help.
Sziasztok
Firmware frissítés keresek Amundsenhez
[email protected]
Köszönöm
Would appreciate if someone could send me or point me to the mib1 update :) many thanks
@pab567
Do you still need firmware update?
If yes, can you get image of Software Train installed in the car.
Use this video to locate the value
MIB Infotainment version check (MIB1 MIB2 MIB2.5 MIB2Std MIB2High)
On 24/06/2022 at 08:21, firga70 said:
Sziasztok
[email protected]
Köszönöm
You may wish to ask your question in English, and follow the link above to get the Software Train information needed and part number to verify.
Please follow the above video guide on getting the hardware part information and Software Train installed.
On 11/27/2021 at 4:17 PM, leskopeter said:
can someone send me the newest firmware?
IMG_20191126_160825.thumb.jpg.cb795abc4ad922c278ef81012ed96fd5.jpg.510056228c8322ebbf0fecd4afe8cc18.jpg
I successfully updated from 0435 to 0490, everything works. Does anyone know what to set on vcds?
Do you have some problem?
The only thing that occurs during updates is a fault code will be set for SVM (Software Version Management) where your car cannot update the SVM server with your new software version.
The fault code will not stop the radio working, and you can clear it with VCDS with some calculations.
5 minutes ago, leskopeter said:
SVM Check, not a physical fault as mentioned, it's the car complaining it cannot talk to the SVM server to acknowledge the update of firmware.
Fix B210A SVM "Fault"
Thank you, you have helped me a lot!
