Superb MK2 door panel removal
Superb detail and will be very useful at some point. Thankyou Hamesh
Hashem too!
Fantastic guide Hashem, and please post your other two guides...
  • 2 years later...
Great link and better than the U tubes I’ve looked at - my drivers electric window cable has become disconnected - motor is going something clunking inside cable snapped unhooked .  Will have a look and take it off tomorrow.
I understand that you can just get a cable kit for £30 rather than the whole motor and cable kit @ £120?
You might find that the cable is corroded as water drips down onto the spool by the motor. This is what happened to me, though thankfully it was a warranty job.
On 27/11/2015 at 18:10, HashemM said:
I was having trouble removing the door panel as were some owners, i've searched and found a thread with dead pictures, so with careful disassembly i've managed to remove it. and decided to make a how to.
HERE is a direct link. and will post a pdf when the instructable is published.
i've also removed and disassembled the mirror, and replaced the courtesy light, if anyone's interested :)
Fantastic work. I've got a couple of annoying door rattles that need addressing - Thanks!
I had the same problem mate and used this kit, it is a bit of a pig of a job though.
https://www.ebay.co.uk/itm/SKODA-SUPERB-2008-2015-RIGHT-FRONT-WINDOW-REGULATOR-3T0837462A-NEW/202033860843?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
