LED Bulbs For Reverse Lights & Fog Lights
Thanx for your feedback. I just ordered same bulbs for reverse light from AliExpress. Is there any other suggestions for other bulbs?
Edited by varicak
  • Replies 169
  • Views 38.9k
  • Hi all,   just put the same reversing bulbs as recomended look to be much brighter, I found a little dab of lube on the pegs made the light pop in very easy. I have attached some pics t
  • I have these: http://www.aliexpress.com/item/HotSale-2pcs-lot-super-brightness-High-Power-1156-led-30W-CREE-XBD-p21w-led-ba15s-Reverse/2036956876.html Cheaper, no bulb out error (did not need VCDS co
  • Nice one for the info I just brought them from Aliexpress I used my debit card that has hardly any money in that account, I transfer funds to that account (exact amount) that way I know my card has
Read my post maybe ? I mentioned all the bulbs :)
Of course i read it. One of them are sold, rest are available but thee is to expensive shipment to my country.
Hey fat4l, I have received my order which was all interriorled light bulbs from LedPerf. But their fitting instructon is in French language. i have sent them an email, no one replies. what confuses me is they have sent me few resistors along with those light bulbs. i couldnt figure out what to do with those resistors. If i do not use them would i get any error message in the dash or in the diagnostic report?
Hi. Interior lights ?  For those theres no resistors requiered. These are not canbus monitored.
I liked all the interior lights including glove box and boot. little more brightness in the boot would have been nice though, but no complain so far. i will now check your exterior bulb's links.
  • 3 months later...
380 Super Bright LED Car Bulb Halfords Advanced Twin Pack,
just fitted these, no bulb out warning for reversing lights, as bright as cree
  • 5 months later...
4 hours ago, haris said:
hi,
I ve read all the post but, which one should I choose?
https://www.aliexpress.com/item/32395328134.html?spm=a2g0s.9042311.0.0.27424c4dnG33Bi
or
https://www.aliexpress.com/item/2036956876.html
also I ve read that no coding needed , but is it completely safe? these bulbs say 30 watt and p21w is 21 watt
Don't worry, the real power is only about 6-7 Watts.
The absolute maximum power rating of those LED chips is 5 Watts so the seller uses this number because it looks better (5x6=30 Watts). So it's marketing BS. :)
There's an internal LED driver inside the bulb which limits the LEDs power to about 1 Watt per chip otherwise they would overheat. The heatsink (aluminium body) is too small for higher power.
The car is still happy with the bulb despite the much lower power. Probably it's a positive side effect of the built-in LED driver.:)
Edited by aki78
 Well i ll buy the second one and no need for coding...
Just bought these and will fit at the weekend. Thank you for posting about them.
Halford  now sell them had one of mine pack in so looked there  and got a pack of 2 , showed  the fitter how  to fit one
The Local Council upgraded the lamp posts in my road @ the beginning of last year.
What they actually did was remove the light just in front of my house, halved the number of lamp posts and spread the remaining ones further apart. So I ordered 2 of these "18W PY21W BAU15S 1156 BA15S T20 7440 35 SMD 3030 LED 1.5A Auto Reverse Backup Stop Lights Rear Turn Signal Lights No Hyper Flas" before Christmas, but have only just gotten around to installing them. They are very white and bright and ideal for reversing through the narrow gates and onto my drive at night, now that its pitch black out there (or nearly).
I got them from aliexpress for about £11 inc postage, link attached , but I have since seen them on Ebay (well at least they look the same) for about £3 each. I am however happy with the ones I got.
https://www.aliexpress.com/item/32848923725.html
PS I additionally fitted a powerful halogen flood light powered via a radio remote controlled power switch inside the house (DEWENWILS Remote Control Plug Sockets) link attached. So I carry the controller in the car and flood the actual drive as well. There are none so blind as cannot see.
https://www.amazon.co.uk/dp/B07SR3KL8D/ref=pe_3187911_189395841_TE_dp_1
10 hours ago, GregSKO said:
I ordered 2 of these "18W...
So you now, illegally, have 4 reversing lights?
ok, i've read through the thread and am still confused
i have a mk3 vrs and want to upgrade the front fogs to LED. i know i need 4 bulbs. bumper is coming off soon and I want to do this when it is off
i'm still not sure what fitting is required for direct replacement? H11 or H16? and H16 seem to have a JPN variant as well
if anyone has a current link for aliexpress or somewhere in the uk for the ones i need please let me know!
thanks
thanks
bumper don't need to come off , see tube for vids, H8 required
  https://www.autobulbsdirect.co.uk/h8-35w-led/?finder_tab=abd_bulbs&finder_end=front&finder_type=led_bulbs
Edited by skippy41
possibly planning to get honeycomb grille fitted - will i need a new surround as well as the new grille? or does it just clip in when the existing one is removed
i'm also looking to relocate a siren to the gap behind the front grille from its current position in the engine bay - might need to bodge up a bracket for it
this is why i envisaged removing the bumper and doing foglights at same time
just ask tube you will find any vids required
So if i understand correctly, for changing reverse standard bulbs with LEDs without CANBUS for error free, you have to code VCDS like this:
09-Cent. Elect. / Security Access – 16 (code: 31347) / Adaptation – 10
Then you search for:
Leuchte28RFL LC11   and change to   43-allgemeine LED
Leuchte29RFL RA64   and change to   43-allgemeine LED
Do you have to change dimmwert from 100 to 127 for both to, like you have to change ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 from 100 to 127 for LED licence upgrade?
If you have to change dimmwert for both reverse LEDs, what two options you have to change to 127 for both reverse LED bulbs?
Anyone maybe know why you have to change dimmwert from 100 to 127 for LED because it doesnt looks like it changes brightness? (was testing on LED plate lights)
