Lofty's Sprint Yellow Fabia vRS Mk1 - "Project Daffodil"
What paint did you use for the crackle black?
  • Replies 775
  • Views 140.4k
  • In the style of Jim from Friday Night Dinner.... "Hello All....."   It's been a while, nearly 12 months in fact since I gave a proper update, it's been a busy old year. We moved house mid No
  • Update time. Nothing exciting like actually starting the engine up yet but part of the whole getting ready to move house bit means I needed to sort the loft out, and there just happened to be the fron
  • Update time!   Back in post #52 you will recall a picture of a rather grubby looking 1.9 PD engine from a Fabia vRS. This has been purchased for a number of reasons, most of them totally log
Rob- it's VHT crackle black, bought it from Frosts.
So with the 'cone in a box' you just fit the standard airbox top on the lower part in your pic?
Struggling to see how that's any better than a panel filter TBH,as surely that cone has less surface area than a panel?
Edited by coskev
I think, it flows better, like the s2000 filter but doesn't draw any hot engine bay air through it like the exposed cones do??
Don't quote me on it though
But yes Kev, the standard air box lid goes on top.
  • 4 weeks later...
It's been fairly quiet on the daffodil front, Work, family and other stuff keeps getting in the way but I have been doing the odd pre-build up job now and again..
Sneaky peak of the front hubs I've been working on in the garage
From this ...
7517928B-B857-4CBC-8B1C-0F7CCF4DFD84_zps
2114DDCC-9EC8-4D34-AC4D-880E4D03E4A7_zps
405FA0C6-54A7-4E6C-8A8E-56161124D35D_zps
To this...
030558E4-D331-4CBF-8C46-BB01D25E82C3_zps
Not just a quick wire brush and flick of paint.. special tools have been purchased (Gen2 wheel bearing fitting tool for one), and many hours of soaking, scrubbing, treating and then finishing off.
I'll get some finished pics up over the weekend hopefully
Edited by Lofty
Love a teaser pic like that. Sounds like another level of dedication. Great stuff
That looks brilliant.. Going to start doing this to my Fabia when the engine comes out.
Attention to detail on this project is amazing.
Its almost sad its going to get used on the road, It needs to be kept in a museum so its the cleanest VRS in the country!
Getting stuff done can seem like extraordinarily hard work at times..
The Gen2 wheel bearing kit I bought has been supplied with a 66mm insertion clamshell tool instead of the correct sized 72mm one despite both the advert and the box saying 72mm so I've had a battle with the eBay seller over that.
The SKF wheel bearings/flanges have also been supplied wrong with no spring loaded securing ring fitted so they've had to go back as well, folks can't get nothing right it seems!
Upshot is that the hubs are ready apart from the correct bearings which should be here tomorrow, so I've chased out all the threads on there with the right size tap, and fitted the two new ABS sensors as they broke trying to remove them, well one did but I've put two new in.
C5B36877-8B09-47D3-9C09-4FFAD2BBA176_zps
6CBF217E-53EB-481D-A475-CF7EABB21B6E_zps
New Febi Bilstein drop links and track rod ends have arrived and they've all been rubbed down, etch primed and painted ready for the big build up.
Next purchase is a set of all four CV boots from TPS, so that I can refresh both driveshafts when they're off the car soon.
Edited by Lofty
It truly is going to break my heart when you actually drive this car for the first time after all this work and things start getting dirty :-(
Lol, it's got a date at the ring next year so it'll get used properly don't worry
That hub looks awesome, i'll attempt to get mine like that when it gets stripped, not going to happen though.
Hats off to you though, and a number of the other members on the forum for that matter. The attention to detail and commitment on some of these project cars in phenomenal.
Track rod ends...
As they come they are lightly painted which soon wears off and they end up looking shabby very quickly.
A1CE735D-781E-4192-A899-10EC024F1D11_zps
284CE7AD-39F6-48C8-9C35-DCF381D36117_zps
So a good rub down, then carefully masked up..
05477B7C-35D4-43A0-A8D8-DD708182BFDF_zps
Two good coats of etch primer, light rub down then a good coat of hard wearing VHT wrinkle black. Should keep them looking smart for a bit longer.
0AF13F7E-C1A8-47EB-BC44-5B4B12624E05_zps
A7BDEB32-1A8B-4C01-9A8E-8BC27BCB637B_zps
Edited by Lofty
Amazing work as always!
I do like the wrinkle paint.
Just wow
Kind of getting somewhere, had one wheel bearing delivered by a courier, god knows where the second one is?? Who am I to question two lots of postage when one would've done but hey ho, it's all fitted now and looks half decent.
EEAEF9A0-E190-447B-AB4B-516708F0D808_zps
BD0A45E2-1312-440D-B2B0-059291E7B909_zps
06542EE2-E42A-4E9A-9785-245F9E978058_zps
You can see where the spring / retaining collar sits in the top groove of the hub, you here a click as it bottoms out and the tangs pop out
And the inside edge and the ABS sensor pick up.
Next update will hopefully be a big one, the daffodil is donating its heart and lungs (engine and box actually) to the black one on the drive, that's happening next week so at least I'll be left with an empty engine bay to crack on with.
Edited by Lofty
Where did you get the new bearing?
Phil- off eBay, it's an SKF one
I wonder how mad people will get when I say I fitted one of these bearings with a press and not a gen 2 tool.
I even used 2 hook tools to lock the "lock ring" in place. I didn't even die.
#Butdidyoudie #sorrynotsorry
Edited by hutchysrs50
Your car, your choice tbh.
