Lofty's Sprint Yellow Fabia vRS Mk1 - "Project Daffodil"
I've done a fair bit of digging regarding the supposedly correct way of aligning the PD injectors in the head. General opinion was to just lob them in and be done with it but the official VW workshop instructions give precise measurements for the injector bodies which is measured from the outside RHS edge of the cylinder head..
This meant sourcing a suitably long vernier caliper which came today.
The suggested tolerance is 0.8mm so these are as damned close as I can get them. They all sit now ever so slightly off square which is apparently how they're supposed to be.
The retaining bolts (new genuine ones of course) have been torqued down to 12nm then 270degree tightened.
  • Replies 775
  • Views 140.3k
  • In the style of Jim from Friday Night Dinner.... "Hello All....."   It's been a while, nearly 12 months in fact since I gave a proper update, it's been a busy old year. We moved house mid No
  • Update time. Nothing exciting like actually starting the engine up yet but part of the whole getting ready to move house bit means I needed to sort the loft out, and there just happened to be the fron
  • Update time!   Back in post #52 you will recall a picture of a rather grubby looking 1.9 PD engine from a Fabia vRS. This has been purchased for a number of reasons, most of them totally log
13 minutes ago, Lofty said:
Rear beam has been collected today, as usual Bournes powder coating has done a lovely job.
They masked all the threads that I asked them to and it'll be much nicer once all the new bearings and stub axles are built up
Will be a shame to put that on! Looks awesome!
Got the air con pump fitted back up and loosely fitted the top engine mount.
Had a call from Camcoat, the tubular manifold and turbo housings are done and will be back here Saturday.
Wicked motor mate just picked my 07 mk1 vrs up the other week looking to lower it and put some nice shoes on it soon and maybe a map. What fmic is that ?
The front mount that was on it was the Forge one. Not got to the point of sorting a front mount out for this build yet but have a feeling it'll be something bespoke
Love this car u got it from the same place I got my mk2 I remember seeing it there lol
The build is epic ,time ,effort not to mention hard earned money ,will be one of the greats when finished top work .
Really is a work of art mate, I visit this thread to satisfy My OCD.
Cheers guys, ordered the GTB spec TIP this morning, along with the required 80mm silicon pipe work so I can run the standard air box.
Looking at the crankcase breather next, I'm 100% keeping the engine cover so there will have to be some clever thinking to route the breather hoses out of the way
That engine is a work of art, outstanding mate. I need to up my standards on my build haha!
Understand about the cover for oe look ,but needs to be left off to show it off
You big tart!!! It's all about knowing it's underneath lol...
Love the attention to detail on this build, get excited whenever I get an update notification on it, can't wait to see it finished.
^^now THAT is high praise Matt!! ;)
I keep been distracted by the other daily Fabia that's sapping my attention and enthusiasm but I have been progressing albeit slowly. The black one needed new suspension and it made sense to take the ultra low mileage Bilstein B8 from the yellow one and fit that to it.
The suspension had got to come one off the daffodil as I need to start the underneath resto in earnest so it's now sat in the garage with all four corners empty and just the rear beam, fuel tank and heat shields left on. I'll make a start prepping and painting in the next few weeks but the need to source new suspension has been satisfied by the arrival of these...
Bilstein B14 PSS coilover kit. Having run Bilstein dampers on the last 6 cars of mine I know the quality and performance of them is beyond reproach hence pulling the pin on these.
Ill update more with pretty and not so pretty pictures of the car as we progress
Exact same kit I fitted on mine, I wasn't disappointed with the ride qualify at all.
Front legs built up using new strut top mounts and bearings.
Had to order a cranked 22mm ring spanner so I can tighten the top mounts up properly but apart from that almost ready to go back on the car... eventually lol
What stuff did you use on engine to clean up then to paint etc
Used everything I could find! To get the grub and grime off the block I used Bilt Hamber Surfex, quite a strong mix, pressure washed off, then attacked the block with scrapers, wire brushes, scotch pads etc. The heavier rust actually chips off easy with a screwdriver and a small hammer.
Get as much crap off as you can then a few coats of Bilt Hamber hydrate 80 rust convertor then zinc primer etc
