I'll see what I can do tomorrow morning, if no-one else chimes in first.
Thank you mate hopefully to here back tomorrow
Well I have to be honest, the permutations of cars, engines and ECUs is baffling my brain this morning but looking at an Octy wiring diagram for a 2006 BXE, the N75 valve is driven by ECU pin 29.
Thanks mate so the plug for the n75 one wire goes to pin 29 the other wire goes where mate it that ground
Other wire 12V not ground, same 12V as any other solenoids, probably off fuel pump relay.
Thank you very much mate 👍 ur a 🌟 last one do you no what wire out the 2 go to pin 29 please and the other then will be 12v
  • 2 months later...
Hi everyone. I am new here...
Have a problem with my vac.sol.block on my Touran 1,9/90/PD/08/BXF.
Changed onse with a used one abit better, but still not perfect.
Is there any mechanical problems with it, that can be cheked with a vacuum, and how if someone knows.
Thank's
hi guys new here i have done a touran bkd engine swap into a bls caddy and use the touran ecu and clocks   i am not fitting the touran vac box as i only need to work the turbo so usuing my vans n75 does anyone know where the two wires form the n75 valve should go on the touran ecu to wire it in ?
  • 3 years later...
Did you ever get to the bottom of yours sean2800? I've just done the same swap and now I'm stumped
Hi, welcome.
I hope the following helps.
You can call out to sean2800 by adding the at symbol to the start of the name - example @nta16 = @nta16
sean2800 only made the one post and last visited the site 4 April 2022, you can find this information by putting your cursor (finger?) on the name or logo - but if you call out perhaps you might get a reply (if the email contact is still active).
Normally I'd point you to the relevant model and year forum on this site but the Felicia Fun didn't go up to 2007 and wiring vary a lot model to model and (part) year to (part) year.
Being a General Maintenance forum this probably wasn't the best forum for an answer to such a technical question particularly on a non-Škoda model but perhaps someone might have known in the more specialised forums on the this site that relate to tuning and performance modifications, projects relevant to the model and year or generals electronics but I don't now what'd relate to a Touran or 2007 Caddy, if you do you could try that forum.
Good luck
