Things a bit screwy since RVC installation
Today I installed a reversing camera into my 2015 Superb Outdoor wagon and used tutorials here from all those before me.... thanks Briskodians for a long day.  I found I had to use parts of most guides as all our cars are quite different underneath.
I had some frustrating moments and none more so that what confronts me now.  I should say that installation was successful and reverse camera works as expected.
However......
Since the install I have been troubleshooting errors... namely...
1/  License plate lights don't work now and throw a check bulb warning on dash
2/  TPM error on dash
3/  Steering Angle Sensor error and ESC error on dash
I've checked fuse at position 4 (courtesy of owners manual) and it's ok - multimeter test confirms
Checked bulbs and they are ok.
Hooked up to VCDS ran an Autoscan and cleared relevant fault codes.  Started her up and errors showed up.....did this a few times and it seems I am just going around in circles....
Here is my latest Autoscan ....
Saturday,20,August,2016,19:16:25:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: TMBMF93T2F9027151   License Plate:
Mileage: 14970km-9301mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 2E 36 37 42 44 46
          47 52 55 56 61 62 6D 72 77
VIN: TMBMF93T2F9027151   Mileage: 14970km-9301miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RS    HW: 03L 906 018 MH
   Component: R4 2,0L EDC   H28 5357
   Revision: 41H28---    Serial number:
   Coding: 001D0032042701080000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM20TDI01103L906018RS 003003
   ROD: EV_ECM20TDI01103L906018RQ.rod
   VCID: 0C103C1FA758F05E31-8058
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 016 D    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4013
   Revision: 05653104    Serial number: 00001409040719
   Coding: 0000020
   Shop #: WSC 33361 790 00078
   VCID: 1526597B3C9231969E-8040
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 863D601609240001610C06E9901A0092A1095023
   VCID: 0400143F8708B81E79-8050
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 14975 km
                    Time Indication: 0
                    Date: 2016.08.20
                    Time: 19:02:58
             Freeze Frame:
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 41216
                    Count: 0
                    Count: 65280
                    Count: 0
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0345823220
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G.rod
   VCID: 377AB3F38E5E2386AC-8062
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 CE    HW: 3T0 907 044 CE
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010000003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 77FA73F3CEDEE3866C-8022
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
   Component: BCM PQ35  H+  112 0771
   Revision: AF112771
   Coding: 4C190ABCE85BF1C0400800C0310089EC497100AE677D85F080814704A041
   VCID: 7DF661DBE4E2C9D636-8028
   Subsystem 1 - Part No: 3T2 955 119 B
   Component: Wischer 07091  26  0700
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 061014 05  54  0403
   Coding: 0630ED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 122
                    Mileage: 14975 km
                    Time Indication: 0
                    Date: 2016.08.20
                    Time: 19:04:44
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.45 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
Address 10: Park/Steer Assist (J791)       Labels: 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 D    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0005
   Revision: --------    Serial number: 56231425901153
   Coding: 349102
   ASAM Dataset: EV_EPHVA2CAS46X0000 001003
   ROD: EV_EPHVA2CAS46X0000.rod
   VCID: 3E74A6D7A16412CE6F-806A
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LDQ VW10 HI   2518
   Revision: 26020000    Serial number: 003LEPJW6R7P
   Coding: 0017489
   VCID: 428CD2271D9C762E0B-8016
   Subsystem 1 - Serial number: 6332MTS647302664
   Subsystem 2 - Serial number: 6342MTS609602674
   Subsystem 3 - Serial number: 6351HTS66KA36DKJ
   Subsystem 4 - Serial number: 6361HTS6PCD66DKJ
   Subsystem 5 - Serial number: 63727TS6FM3H2DKJ
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 DT    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0140
   Revision: FF010042    Serial number: 20140929301985
   Coding: 1002140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 010E1D2B901AAD3652-8054
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
   Component: E221__MFL-PR6  H05 0130
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 841 M    HW: 3T2 920 841 M
   Component: KOMBI         H08 0811
   Coding: 111E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 071014F1001208
   Coding: 359303
   VCID: 7F0A9BD3EEEEDBC624-802A
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   Shop #: WSC 00000 000 00000
   VCID: 4586C93B0CB241162E-8010
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H08 0811
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADC5A878D6C4E6EE3-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000260308003
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 306888EF6B30F4BEED-8064
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666660927
   Coding: 010100
   VCID: 2B529F834A169766D8-807E
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3101
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 377AB3F3865E2386AC-8062
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 S    HW: 3T0 035 680 S
   Component: RNS-MID       H23 6276
   Revision: AB001001    Serial number: SKZ6Z7P7261121
   Coding: 00060042000000811000
   VCID: 4088D82FD390643E1D-8014
   Subsystem 1 - Part No: 3T0 051 859 P
   Component: AUNZ V6  7920
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 52ACE2670DFCE6AEBB-8006
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 196    3501
   Revision: 00H22000
   VCID: 397EB5CB704A35F65A-806C
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 14975 km
                    Time Indication: 0
                    Date: 2016.08.20
                    Time: 19:02:02
             Freeze Frame:
                    Battery Volts: 11.6 V
                        DD
                    Temperature: 20.0\B0C
                    Count: 2
                    Steering Angle: 0.00\B0
                    Count: 1
                        SteerAng n.Init
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0020586
   ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 2858608F53E0BC7E35-807C
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   VCID: 51AEED6B08FA9DB682-8004
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0111
   Coding: 01CE00003F000000
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
   ROD: EV_HeadlRegulVWAFSPt_SK46.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: 8E0000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: 8E0000
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1653
   Coding: 330F785A
   VCID: 71EE4DEBA8BABDB6A2-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H08 0415
   Coding: 010C00200001001000
   VCID: 50A8E86F03F094BE8D-8004
Address 6D: Trunk Elect. (J605)       Labels: 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 262400423
   Coding: 082301C002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK46.rod
   VCID: 3B72AFC3B27607E648-806E
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H08 0415
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666667639
   Coding: 0201000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3D76A1DBAC6209D676-8068
End-------------------------(Elapsed Time: 04:56)--------------------------
Can anyone offer any clues on what is ailing my not so Superb (for now anyways)???  :sweat:  :sweat:  :sweat:
I'd check that you didn't damage any wires or grounding points when you were pulling the wires through for the camera. A bunch of those faults could be caused by a wire being cut.
Personally I would download the latest software (currently 16.8.0) and see if you can clear the fault codes.
I checked the wiring path for the license plate lights and they run down the left side of the tail gate and I ran the wiring down the right side (and that was a bugger of a job getting past the foam covered wire to the window demister).
Any clues on where I would find the earth points for these items??
Crisis averted!!
I drove to get replacement license plate bulbs and on the journey the TPM and ESC lights went out.  I replaced the bulbs and there are no more errors!!  Woo Hoo!!
I am now a happy little vegemite....
Case closed!!
Edited by crankoz
For the TPM/ESC lights, you can turn the steering wheel all the way to the left, then to the right and back to the center.
Completely normal if you've had the battery removed :-)
Ah yes you it wasn’t clear that you hadn’t driven the car since removing the battery!
